POV-Ray : Newsgroups : povray.binaries.images : A lamp Server Time
1 Apr 2026 08:59:37 EDT (-0400)
  A lamp (Message 9 to 18 of 18)
<<< Previous 8 Messages Goto Initial 10 Messages
Subject: Re: A lamp
Date: 12 Oct 2004 05:42:22
Message: <Xns95807715E8EFFraf256com@203.29.75.35>
kas### [at] gmxde news:416b8296@news.povray.org
> recursion_limit 2 brightness 3.0}
Uhm, I'm afraid ushc settings are totaly psychical incorrect - surfaces
diffuse up to x3 times more light then their get.
If You would set higher quality (i.e. recursion_limit 5) probably entire
scene will be totaly white / overlighted, since walls will recive about
3*3*3*3*3 * 1 RGB light
http://www.raf256.com/3d/
Computer Graphics
Subject: Re: A lamp
Date: 12 Oct 2004 06:31:15
Message: <416bb273$1@news.povray.org>
Remember that Pov-RAY tries not to simulate reality but to produce
(photo)realistic images. There are many limitations that might cause one
to use higher brightness than 1. For example, sometimes it is not
feasible to set the lightsource ambient value more than 1 as it might
get clipped. Then the only way to get enough illumination is to increase
brightness value. Megapov's exposure setting might help with this -
haven't tried it though.
This is all about getting the desired result, not about actual values
being used. You are seriously limiting yourself by allways using just
brightness 1 (and fade_power 2 etc.).
It all depends. Usually increasing the recursion limit beyond a certain
value doesn't affect the result almost at all. When diffuse
inter-reflections are calculated, the intensity gets smaller and smaller
at every iteration (depending on the surface color, diffuse, ambient
etc. values) and finally has no influence on total radiosity value. I
think there aren't many "normal" scenes that look practically any
different with recursion_limit 10 or 20.
Severi
Subject: Re: A lamp
Date: 12 Oct 2004 06:40:01
Message: <web.416bb39b2e59f77667c1c3ff0@news.povray.org>
Even as ray tracing is a pretty snappy algorithm and POV-Ray does it very
well indeed, it seems to me (from my own experience and the works of
others) that the best results often are obtained with a little bit of
'un-physical' modelling.  There are so many approximations that have do be
done that this is not really surprising either.  For example, see this post
for a convincing example:
http://news.povray.org/415b0865%40news.povray.org
In my rad room I stil have recursion_limit > 5 (I plan to decrease though)
with brightness in the 2+ range.  Unphysical?  Could be, but I get the
pictures I want.
jussi.kantola
Subject: Re: A lamp
Date: 12 Oct 2004 09:04:08
Message: <416bd648@news.povray.org>
If I want my 4 spotlights to light the entire room, without overexposing the
places they point at, I have no choice but to reduce light intensity and to
increase radiosity brighness. Or have I? I do not plan to use higher
recursion_limits, it will slow down the whole thing to much. For the final
renders I'll choose :
radiosity { Rad_Settings(Radiosity_Final, off, off) recursion_limit 2 brightness 3.0}
The lighting is how I want it to be, and Radiosity_Final will make sure that no
artifacts are left...
Manuel
Subject: Re: A lamp
Date: 12 Oct 2004 10:54:39
Message: <Xns9580AC07D69BFraf256com@203.29.75.35>
kas### [at] gmxde news:416bd648@news.povray.org
> t 2 brightness 3.0}
>> surfaces diffuse up to x3 times more light then their get.
>> entire scene will be totaly white / overlighted, since walls will
>> recive about 3*3*3*3*3 * 1 RGB light
> overexposing the places they point at, I have no choice but to reduce
> light intensity and to increase radiosity brighness. Or have I?
I think that increasng light intensity _and_ using
light_exposure should give good efect, it is what it's designed for AFAIK
Computer Graphics
Subject: Re: A lamp
Date: 12 Oct 2004 16:02:40
Message: <416c3860@news.povray.org>
OMG, please stop posting photographs!
But seriously, this is darn cool! The only thing I don't like is that
pure white interior of the lamp facing the camera. Either put a light
bulb in there, or something else, lens-flares (don't think it would look
good) or scattering media in the whole room, so that it's not simply a
white lamp-interior, but a beam of light.
Florian
camera{look_at-y*10location<8,-3,-8>*10}#local a=0;#while(a<999)sphere{
#local _=.01*a-4.99;#local p=a*.01-5;#local c=.01*a-4.995;<sin(p*pi)*5p
*10pow(p,5)*.01>sin(c*c*c*.1)+1pigment{rgb 3}}#local a=a+1;#end
/******** http://www.torfbold.com ******** http://www.imp.org ********/
Subject: Re: A lamp
Date: 12 Oct 2004 16:21:51
Message: <416c3cdf$1@news.povray.org>
The light bulb might actually be there but you can't see it as everything is
totally white. Megapov's exposure feature might help to get it visible.
Severi
Subject: Re: A lamp
Date: 12 Oct 2004 17:13:17
Message: <416c48ed@news.povray.org>
Thank you!
> But seriously, this is darn cool! The only thing I don't like is that pure white
> put a light bulb in there, or something else, lens-flares (don't think it would look
> so that it's not simply a white lamp-interior, but a beam of light.
Yes, I know what you mean. However, the lamp wasn't meant to be
the scene, it was meant to be part of a much bigger scene. If it were
just for the lamp, I'd agree with you. To see a very WIP of my scene,
look at:
http://home.arcor.de/mad_onion/002%20rund%20-%20lighting.jpg
It's an ultra-wide-angle camera in order to make all the walls visible.
Manuel
Subject: Re: A lamp
Date: 12 Oct 2004 17:39:33
Message: <416c4f15@news.povray.org>
OK, maybe you're right. But as long as I can achieve what I want in pure POV3.6.1 I'll
stick to that.
Manuel
Subject: Re: A lamp
Date: 14 Oct 2004 00:19:08
Message: <416dfe3c@news.povray.org>
Another lamp, from
http://www.rubygarden.org/ruby?FractalLifeEngine/LampTutorial
In retrospect, I think I picked the deep red to fit that site's "Ruby"
theme.
  Phlip
  http://industrialxp.org/community/bin/view/Main/TestFirstUserInterfaces
Download 'treeLampDetail[1].png' (466 KB)
Preview of image 'treeLampDetail[1].png'
