POV-Ray : Newsgroups : povray.binaries.images : A lamp Server Time
1 Apr 2026 08:59:37 EDT (-0400)
  A lamp (Message 11 to 18 of 18)
Subject: Re: A lamp
Date: 12 Oct 2004 06:40:01
Message: <web.416bb39b2e59f77667c1c3ff0@news.povray.org>
"Rafal 'Raf256' Maj" <spa### [at] raf256com> wrote:
> kas### [at] gmxde news:416b8296@news.povray.org
> > recursion_limit 2 brightness 3.0}
> Uhm, I'm afraid ushc settings are totaly psychical incorrect - surfaces
> diffuse up to x3 times more light then their get.
Even as ray tracing is a pretty snappy algorithm and POV-Ray does it very
well indeed, it seems to me (from my own experience and the works of
others) that the best results often are obtained with a little bit of
'un-physical' modelling.  There are so many approximations that have do be
done that this is not really surprising either.  For example, see this post
for a convincing example:
http://news.povray.org/415b0865%40news.povray.org
In my rad room I stil have recursion_limit > 5 (I plan to decrease though)
with brightness in the 2+ range.  Unphysical?  Could be, but I get the
pictures I want.
jussi.kantola
Subject: Re: A lamp
Date: 12 Oct 2004 09:04:08
Message: <416bd648@news.povray.org>
> If You would set higher quality (i.e. recursion_limit 5) probably entire
> scene will be totaly white / overlighted, since walls will recive about
> 3*3*3*3*3 * 1 RGB light
If I want my 4 spotlights to light the entire room, without overexposing the
places they point at, I have no choice but to reduce light intensity and to
increase radiosity brighness. Or have I? I do not plan to use higher
recursion_limits, it will slow down the whole thing to much. For the final
renders I'll choose :
radiosity { Rad_Settings(Radiosity_Final, off, off) recursion_limit 2 brightness 3.0}
The lighting is how I want it to be, and Radiosity_Final will make sure that no
artifacts are left...
Manuel
Subject: Re: A lamp
Date: 12 Oct 2004 10:54:39
Message: <Xns9580AC07D69BFraf256com@203.29.75.35>
kas### [at] gmxde news:416bd648@news.povray.org
> t 2 brightness 3.0}
>> surfaces diffuse up to x3 times more light then their get.
>> entire scene will be totaly white / overlighted, since walls will
>> recive about 3*3*3*3*3 * 1 RGB light
> overexposing the places they point at, I have no choice but to reduce
> light intensity and to increase radiosity brighness. Or have I?
I think that increasng light intensity _and_ using
light_exposure should give good efect, it is what it's designed for AFAIK
http://www.raf256.com/3d/
Computer Graphics
Subject: Re: A lamp
Date: 12 Oct 2004 16:02:40
Message: <416c3860@news.povray.org>
OMG, please stop posting photographs!
But seriously, this is darn cool! The only thing I don't like is that
pure white interior of the lamp facing the camera. Either put a light
bulb in there, or something else, lens-flares (don't think it would look
good) or scattering media in the whole room, so that it's not simply a
white lamp-interior, but a beam of light.
Florian
camera{look_at-y*10location<8,-3,-8>*10}#local a=0;#while(a<999)sphere{
#local _=.01*a-4.99;#local p=a*.01-5;#local c=.01*a-4.995;<sin(p*pi)*5p
*10pow(p,5)*.01>sin(c*c*c*.1)+1pigment{rgb 3}}#local a=a+1;#end
/******** http://www.torfbold.com ******** http://www.imp.org ********/
Subject: Re: A lamp
Date: 12 Oct 2004 16:21:51
Message: <416c3cdf$1@news.povray.org>
The light bulb might actually be there but you can't see it as everything is
totally white. Megapov's exposure feature might help to get it visible.
Severi
Subject: Re: A lamp
Date: 12 Oct 2004 17:13:17
Message: <416c48ed@news.povray.org>
Thank you!
> But seriously, this is darn cool! The only thing I don't like is that pure white
> put a light bulb in there, or something else, lens-flares (don't think it would look
> so that it's not simply a white lamp-interior, but a beam of light.
Yes, I know what you mean. However, the lamp wasn't meant to be
the scene, it was meant to be part of a much bigger scene. If it were
just for the lamp, I'd agree with you. To see a very WIP of my scene,
look at:
http://home.arcor.de/mad_onion/002%20rund%20-%20lighting.jpg
It's an ultra-wide-angle camera in order to make all the walls visible.
Manuel
Subject: Re: A lamp
Date: 12 Oct 2004 17:39:33
Message: <416c4f15@news.povray.org>
OK, maybe you're right. But as long as I can achieve what I want in pure POV3.6.1 I'll
stick to that.
Manuel
Subject: Re: A lamp
Date: 14 Oct 2004 00:19:08
Message: <416dfe3c@news.povray.org>
Another lamp, from
http://www.rubygarden.org/ruby?FractalLifeEngine/LampTutorial
In retrospect, I think I picked the deep red to fit that site's "Ruby"
theme.
  Phlip
  http://industrialxp.org/community/bin/view/Main/TestFirstUserInterfaces
Download 'treeLampDetail[1].png' (466 KB)
Preview of image 'treeLampDetail[1].png'
