POV-Ray : Newsgroups : povray.binaries.images : rock formations WIP Server Time
19 Jun 2026 18:37:24 EDT (-0400)
  rock formations WIP (Message 1 to 6 of 6)
Subject: rock formations WIP
Date: 26 Sep 2004 11:51:30
Message: <4156e582@news.povray.org>
A very, very WIP, it started as a test to find a viable technique to do
the things that height fields couldn't.  I have always wanted to do natural
bridges, caves, overhangs, and all sorts of different rock formations in
POV, but never really found a good way to do that sort of thing...
  As it turns out, this sort of thing can be done in Wings (if one is
patient enough as once you start getting a lot of faces, operations get
slow).
Anyway, as I said, it has a way to go, but it is nice to know the technique
has potential...
The model geometry stats were highlighted after screenshot was taken, decent
quality radiosity (but no aa) was used along with a fancy normal in POV (the
shadow-line artifact is present in quite a few spots).  Might re-run it with
soft shadows and aa, but i should probably work on actual scene elements...
Reactor
Download 'rock_form_wings.jpg' (77 KB) Download 'rock_formation.jpg' (44 KB)
Preview of image 'rock_form_wings.jpg'
Preview of image 'rock_formation.jpg'
Subject: Re: rock formations WIP
Date: 26 Sep 2004 12:08:50
Message: <4156e992@news.povray.org>
Yeah, that's looking nice. I love looking at other peoples Wings
models.
Can you not 'bridge' the arch to the main rock? Too many faces?
  ~Steve~
Date: 26 Sep 2004 12:26:18
Message: <4156edaa$1@news.povray.org>
"St." <dot### [at] dotcom> wrote in message news:4156e992@news.povray.org...
> models.
>   ~Steve~
I am not fully sure what you mean, the arch is a natural bridge... or do you
mean bridge in the wings sense of the word?
    Reactor
Date: 26 Sep 2004 12:51:52
Message: <4156f3a8@news.povray.org>
"Reactor" <rea### [at] hotmailcom> wrote in message
news:4156edaa$1@news.povray.org...
> > models.
> >   ~Steve~
or do you
    Yes, sorry, the wings 'bridge' command. If you can move the arch
enough, the end of the arch will have many faces, so you delete all
the lines to leave one flat face with a certain amount of vertices.
Then, you do the same to the main rock, hopefully leaving the same
amount of vertices. Select both faces, and hit 'bridge' in the command
menu. You can then select your arch vertices and move them towards the
main rock and fiddle around with it at the 'seam' as it were.
     Either that, or delete your arch and 'grow' a new one out of the
main rock. Whichever is easiest.  ;)
    I'm sorry, I wouldn't be so picky, but it just sticks out a mile
for me. But an excellent idea, nonetheless... Thanks.
    Looking forward to seeing some more of this idea.
     ~Steve~
>     Reactor
Date: 26 Sep 2004 13:08:23
Message: <4156f787$1@news.povray.org>
"St." <dot### [at] dotcom> wrote in message news:4156f3a8@news.povray.org...
>      ~Steve~
Ah, ok... yeah, the main arch does seem to stick out a bit too much.  It is
funny, I originally started modelling from a picture of a natural bridge
along a coastline which had a very long, very thin bridge to a rather
largish sea stack... which looks nothing like this.  Oh well. I might have
to try the re-bridging the bridge trick, I've been making insets and moving
them using magnet ops, sort of like a smooth extrude.  I am actually
abandoning that model, but if i weren't I'd probably make the part closest
to the main "wall" much thicker vertically, and maybe move it a bit closer.
Also, since each formation was done at different times, the harder, less
eroded rock sticks out at different levels... There is a lot that could be
done, but it seems that wings is up to it.
       Reactor
Date: 26 Sep 2004 13:39:47
Message: <4156fee3@news.povray.org>
news:4156f787$1@news.povray.org...
the
It is
bridge
rather
  It doesn't matter. That complete rock and arch could be from
anywhere around the world, so I'm not saying that it sticks out too
much, I'm saying that the seam or join between the arch and the main
rock is easily seen (to me) - it just wouldn't be there in real life.
Also, if you think about erosion, would the sea 'really' degrade that
rock like that? Maybe, maybe not. From what I remember, most holes in
weather/sea worn rocks are fairly small and round-ish in appearance.
Maybe drag a bunch of vertices down at the end of the arch and into
the main wall. Doing this in all directions might hide this entirely.
moving
closest
closer.
less
could be
  I think I said most of that above, but yes, wings will do it. Give
it a go.
    ~Steve~
>        Reactor
