POV-Ray : Newsgroups : povray.binaries.images : Casette Tapes Server Time
16 Aug 2025 18:25:12 EDT (-0400)
  Casette Tapes (Message 1 to 10 of 31)
Subject: Casette Tapes
Date: 25 Sep 2004 13:44:31
Message: <4155ae7f@news.povray.org>
I began this project 12 days ago and it turned out fairly well I think, so I
would like to share it with you all. Suggestions and comments are welcome.
It seems that I have a fondness for small, shiny, plastic things. But there
is not much concept behind my images, except I strive for beauty and
photo-realism (usually). I'm trying to come up with some bigger ideas and
personal designs, but they certainly take more time.
Hugo
Download 'CasetteTapes.jpg' (99 KB)
Preview of image 'CasetteTapes.jpg'
Subject: Re: Casette Tapes
Date: 25 Sep 2004 14:13:15
Message: <4155b53b@news.povray.org>
Photorealism?
CHECK!
Andrew @ home.
No, really... it's cool.
Date: 25 Sep 2004 14:22:40
Message: <4155b770$1@news.povray.org>
Now that is realy great!
Did you use a modeller like Moray, or is it hand-coded?
Greetings,
JWV
"Hugo Asm" <hua### [at] post3teledk> wrote in message
news:4155ae7f@news.povray.org...
> Hi,
I
there
> Regards,
> Hugo
Date: 25 Sep 2004 14:47:50
Message: <4155bd56@news.povray.org>
Thank you! There is no doubt that POV-Ray is the best renderer in the world.
I used Wings3D, which is a freeware polygon modeller, very easy to use with
a user-friendly interface. It's a powerful yet simple application, suited
for modelling all kinds of shapes; organic or not.
Actually, I wrote this in the lower left side of the image, but the text is
so light grey, that apparently you didn't notice. That's fine as it was
intended to be discrete.
Hugo
Date: 25 Sep 2004 14:51:58
Message: <4155be4e$1@news.povray.org>
Thanks for that, but please don't post photographs in this forum.
That's an incredible render.  Great job.
-->Jeff
jgentry46 [at] yahoo --dot-- com
Date: 25 Sep 2004 15:11:38
Message: <4155c2ea$1@news.povray.org>
That's really impressive.
I have to wonder how you got all the little cut-out areas on the *inside* of
the casing to look right in Wings3D. Wasn't it hard to shape the inside of
the casing when the outside was in your way?
 - Slime
 [ http://www.slimeland.com/ ]
Date: 25 Sep 2004 15:28:17
Message: <4155c6d1$1@news.povray.org>
Hugo Asm wrote:
> Hi,
> Regards,
> Hugo
I can't find a single thing wrong.  Beautify.
Maybe a tutorial showing how you handled some of the trickier things in
Wings?
Date: 25 Sep 2004 15:35:00
Message: <web.4155c73b1a70a274804806c0@news.povray.org>
>  - Slime
Probably only half of the tape was modelled, and then mirrored... I guess
Subject: Re: Casette Tape - opened
Date: 25 Sep 2004 16:06:04
Message: <4155cfac@news.povray.org>
Hi Slime,
Well, the outside was not in my way. As Wagner says, I modelled half the
casing and copied it. Then I flipped the copy and moved it into position,
and began tweaking it to look like the other part (as the two halfs are not
fully similar).
I find it's generally a good idea to split an object into smaller objects.
It makes everything much clearer when you can turn off parts that you are
currently not working on. It also maintains fast response from OpenGL and
Wings3D... And finally it's quite realistic, because most man-made objects
are made from smaller parts.
Hugo
Download 'CasetteTape_half.jpg' (31 KB)
Preview of image 'CasetteTape_half.jpg'
Date: 25 Sep 2004 16:20:00
Message: <web.4155d2391a70a274804806c0@news.povray.org>
Beautiful job, congrats!!!
______
Wagner
