POV-Ray : Newsgroups : povray.binaries.images : Life Server Time
15 Apr 2026 00:57:19 EDT (-0400)
  Life (Message 1 to 10 of 24)
Subject: Life
Date: 5 Sep 2004 09:07:10
Message: <413b0f7e@news.povray.org>
I started POVing again, and since I'm in a cellular automata period, I
implemented Conway's Game of Life in POVRay's preprocessing language,
which gives a kind of history of the 2D world :)
Everything works fine, the only problem is that I don't want to define
the initial state of the world in the script. Imagine the quantities of
lines like :
#declare world[5][5] = 1;
#declare world[5][6] = 1;
... etc :/
So, for now I initialise it randomly (the attached picture is with the
seed 1789 iirc).
Do you know if I could for example read the pixel values of a monochrome
picture which would describe the initial state of the world ? A nice
thing would be to have access to a picture like if it was an array, like
<file>[1][56], which would be an rgb vector. That would be nice wouldn't
it ?
Anyway, here's a picture of a 30x30 world, with 50 steps (you can see a
characteristic oscillator on the right) :
(ok, the environment could be improved a bit)
Download 'isix-0.5-640x480-2.png' (424 KB)
Preview of image 'isix-0.5-640x480-2.png'
Subject: Re: Life
Date: 5 Sep 2004 12:40:00
Message: <web.413b406657340d83a8399d8d0@news.povray.org>
SeeSchloss <adr### [at] seeschlossorg> wrote:
> Hi,
> lines like :
> ... etc :/
> seed 1789 iirc).
Subject: Re: Q: blurring bump map image in pov ?
Date: 29 Jul 2004 21:31:16
Message: <41096ca4$1@news.povray.org>
Can be done directly, if very slowly in inside POV.
To get direct access to the pixel data of your map, you can use (untested):
#local Pix = function {
   pattern {
     image_pattern { png "bump.png" }
image is mapped in function from x=0 y=0 to x=1 y=1, so you would get
pixel <50,100> with
#local Value = Pix ( 50.5/mapwidth , 100.5/mapheight, 0 );
(re-posted by jaap)
Subject: Re: Life
Date: 5 Sep 2004 12:55:01
Message: <web.413b43b957340d83a8399d8d0@news.povray.org>
>    pattern {
> pixel <50,100> with
or read it directly from a comma-seperated text file?
Subject: Re: Life
Date: 5 Sep 2004 13:20:38
Message: <413b4ae6$1@news.povray.org>
Most excellent. I've always loved CAs, and I never thought of trying to
show a 2D CA in 3D space, altho 1D CAs in 2D space is pretty common.
Great job!
Subject: Re: Life
Date: 5 Sep 2004 14:04:12
Message: <noe.falzonPASDEPUB-58E8B7.20031905092004@news.povray.org>
In article <413b0f7e@news.povray.org>,
Hey, that is great ! I love it !
Well, it doesn't look bad to me :)
Great idea anyway !
NF
"Je ne deteste que les bourreaux" -- Albert Camus
Pour m'ecrire un mail, veuillez retirer PASDEPUB de mon adresse ;)
Subject: Re: Life
Date: 5 Sep 2004 15:14:47
Message: <pan.2004.09.05.19.14.53.918412@seeschloss.org>
>> Can be done directly, if very slowly in inside POV. To get direct access
>>    pattern {
>> pixel <50,100> with
OK, I've tried what you suggested and it works fine, thank you, I hadn't
thought of using a function to do that...
It may be slow, but since it's only used once at the beginning, speed
isn't a problem.
Thanks again, that's easier to use than a text file or declares :)
Subject: Re: Life
Date: 5 Sep 2004 15:20:14
Message: <pan.2004.09.05.19.20.21.147906@seeschloss.org>
> show a 2D CA in 3D space, altho 1D CAs in 2D space is pretty common. Great
> job!
Thank you, I thought it could make some interesting shapes but I couldn't
really experiment with a random placement of the cells... now that it's
easier, maybe I will find nice things :)
A 3D CA in 4D space would be nice, too, and it's possible with POV...
if you don't care about parsing times :D
Subject: Re: Life
Date: 5 Sep 2004 15:26:31
Message: <pan.2004.09.05.19.26.37.753549@seeschloss.org>
Thank you :)
Heh, apart from the checker (which I used at the beginning to check if
the world evolved like it should), it's a bit empty don't you think ?
On the other hand, I don't think trees and rocks would fit well next to a
cellular automaton ;)
Subject: Re: Life
Date: 5 Sep 2004 16:40:27
Message: <413b79bb@news.povray.org>
Sure ;)
But the checker makes a good floor, I think, because your cells are blocks
that are not seperated. The checker remind that the world is divided in
cells. But I can't find of the floor cells have the same size than the
"living" cells.
It's a bit bare, but is very appealing, it looks as futuristic architecture.
Maybe I'll steal your idea one day ;)
NF
"From the age of Big Brother, from the age of the thought police, from a
dead man... greetings" -- George Orwell -- 1984
Veuiller retirer NO SPAM HERE de mon adresse.
Please remove NO SPAM HERE from my address.
Subject: Re: Life
Date: 5 Sep 2004 17:26:21
Message: <413b847d@news.povray.org>
> Sure ;)
> "living" cells.
Well actually they do have the same size (see the attached picture, with
only one level) but I admit it isn't visible anymore after a few levels.
Do you think leaving a small space between the cells would be better ?
I'll try it :)
Oh, well if you're interested, I can post the source on p.text.scene-files ?
