SeeSchloss wrote:
>> SeeSchloss wrote:
>>> Heh, apart from the checker (which I used at the beginning to check if
>>> the world evolved like it should), it's a bit empty don't you think ?
>>> On the other hand, I don't think trees and rocks would fit well next
>>> to a
>>> cellular automaton ;)
>> Sure ;)
>> But the checker makes a good floor, I think, because your cells are
>> blocks
>> that are not seperated. The checker remind that the world is divided in
>> cells. But I can't find of the floor cells have the same size than the
>> "living" cells.
> Well actually they do have the same size (see the attached picture, with
> only one level) but I admit it isn't visible anymore after a few levels.
> Do you think leaving a small space between the cells would be better ?
> I'll try it :)
>> It's a bit bare, but is very appealing, it looks as futuristic
>> architecture.
>> Maybe I'll steal your idea one day ;)
> Oh, well if you're interested, I can post the source on
> p.text.scene-files ?
Hmm... seeing the attached picture would be easier if there _was_ an
attached picture, don't you think ? :D
Download 'exemple-echiquier.jpg' (25 KB)
Preview of image 'exemple-echiquier.jpg'
In article <413b85bc@news.povray.org>,
Oh, thank you very much, but I think I would do that with an external
little program (that would probably run a lot faster than povray) that
would generate the scene. If I do that quickly, I will keep you aware of
that !
But yes, go on, please.
Yep, certainly :) Thanks !
NF
"Je ne deteste que les bourreaux" -- Albert Camus
> Thank you, I thought it could make some interesting shapes but I couldn't
> really experiment with a random placement of the cells... now that it's
> easier, maybe I will find nice things :)
It might be interesting to start with an image of your name and see what
that looks like three generations down the line.
> that !
Well I posted it, maybe someone else is interested. I've already
done a program which could probably have been modified to output something
usable by POV, but I'm not very experienced at parsing external files with
it... and it was funnier to do it completely with POV :D
SeeSchloss wrote:
> Hi,
> I started POVing again, and since I'm in a cellular automata period, I
> implemented Conway's Game of Life in POVRay's preprocessing language,
> which gives a kind of history of the 2D world :)
> Everything works fine, the only problem is that I don't want to define
> the initial state of the world in the script. Imagine the quantities of
> lines like :
> #declare world[5][5] = 1;
> #declare world[5][6] = 1;
> ... etc :/
> So, for now I initialise it randomly (the attached picture is with the
> seed 1789 iirc).
> Do you know if I could for example read the pixel values of a monochrome
> picture which would describe the initial state of the world ? A nice
> thing would be to have access to a picture like if it was an array, like
> <file>[1][56], which would be an rgb vector. That would be nice wouldn't
> it ?
> Anyway, here's a picture of a 30x30 world, with 50 steps (you can see a
> characteristic oscillator on the right) :
> (ok, the environment could be improved a bit)
I like the idea. I remember looking at some CA stuff a few years ago.
There's a fantastic book related to the subject called:
Growing Artificial Societies: Social Science from the Bottom Up
The book takes you through various algorithms that can used in a CA
environment to simulate various social behaviours. I even wrote my own
VB program to run some of the simulations. It would be great to convert
this to POV, as then you could create some stunning animations!!
Reuben
reu### [at] pearse co uk
news:413b0f7e@news.povray.org...
> lines like :
> ... etc :/
Why don't you do this:
#declare Foo=array[3][3]
    {1,2,3},
    {4,5,6},
    {7,8,9}
- Nicolas Alvarez
nicolas [dot] alvarez [at] gmail [dot] com
>> lines like :
>> ... etc :/
>     {1,2,3},
>     {4,5,6},
>     {7,8,9}
Because I didn't want to have something fixed like this. To change the
size of the world with this system you would have had to completely change
the declaration of the array... and directly editing 30x30 arrays like
this isn't really convenient.
This isn't a problem anymore anyway, since the starting values can now be
taken from a picture.
Hi!
The moment I saw this, I knew that I must try to code that myself. So I did. Here is
one of my images. More at
http://home.arcor.de/mad_onion/life/
Download '003-life.jpg' (185 KB)
Preview of image '003-life.jpg'
Also very cool. I need to scrounge the time to build an animation of
Life growing. R-Pentamino, anyone?
In most cases outputting the final SDL as an include-file from your
program is the easiest way to go.
HTH,
Florian
Optimum Requirement #1: You are Linus Torvalds
(WEB.DE help-wanted ad: Linux Guru)
[------------ http://www.torfbold.com - POV-Ray gallery ------------]
