POV-Ray : Newsgroups : povray.binaries.images : Office finished (191KB) Server Time
15 Jul 2026 14:54:18 EDT (-0400)
  Office finished (191KB) (Message 42 to 51 of 51)
Subject: Re: Office finished (191KB)
Date: 30 Jul 2004 03:28:44
Message: <4109f8ac$1@news.povray.org>
emkaah wrote:
> Very, very impressive. The only unrealisting thing I can see is that the
> office is too clean. Especially if this is in Spain. I mean, Spain, and
> only one tiny bit of paper next to the bin, yeah right :). But again,
> very impressive.
   Ah... spanish offices are no more what they used to be. Now
everything is clean and people don't smoke. I've heard that now they
even work occasionally! :)
Jaime Vives Piqueres
http://www.ignorancia.org/
Date: 30 Jul 2004 03:34:43
Message: <4109fa13@news.povray.org>
Tek wrote:
[message saved as /home/jaime/raytracing/scenes/office/to-do.txt]
   ...and I thought I was finished with this one!
   Many thanks for the good and detail criticism, it must be really
useful if I decide to do one more final render.
Date: 30 Jul 2004 15:55:42
Message: <410aa7be$1@news.povray.org>
"Jaime Vives Piqueres" <jai### [at] ignoranciaorg> wrote in message
news:4109f79b$1@news.povray.org...
> Hughes, B. wrote:
> > Trying to think of what might could use a change... Those fluorescent
> > lights, possibly. I'd expect them to show the actual bulbs, with a
> > blue-green glow in the diffuser panels, since there's sunlight
illuminating
> > the picture. Also, the ceiling panels could be textured, as many usually
> > are.
>    Here in Valencia it's more typical to have panels like the ones you
> describe, which a have a sort of diffuser grid instead a flat plastic
> cover hiding the tubes. But of course the later was much easier to do...
> anyhow, you made me try the other kind:
>    http://www.ignorancia.org/images/personal/office-13.jpg
>    I tried also to decorate the ceiling panels, but radiosity didn't
> like it... all sort of artifacts appeared, so I left them untextured.
> I've also increased the sunlight intensity to please Christoph. :)
Hey now, that's so much better than seeing only blank light panels. Really
improves it.
What were your radiosity settings? Must be a way to clean up those walls.
Seems to me that recursion_limit shouldn't be too high. I like using 2 most
because of how 3 or more tends to react negatively in shadowed places. And
error_bound should be kept low (I like 0.2). Are you loading a saved
radiosity file with always_sample on to try and refine it?
Looking at POV's rad_def.inc file for an example, it has a small
pretrace_end for indoor high quality. All the choices have half of default
adc_bailout.
Bob H.
Date: 30 Jul 2004 16:27:53
Message: <410aaf49$1@news.povray.org>
> improves it.
   I'm glad you like it.
   Radiosity setting were the following:
   pretrace_start .05 pretrace_end .01
   count 250
   nearest_count 10
   error_bound .5
   recursion_limit 1
    On the WIP 12 count was only 150. Increasing it on WIP 13 helped,
but not much. I will try your suggestions and some more things... will see.
   Thanks!
Date: 30 Jul 2004 17:05:02
Message: <ceed3t$1f2$1@chho.imagico.de>
>   count 250
>   nearest_count 10
>   error_bound .5
>   recursion_limit 1
>    On the WIP 12 count was only 150. Increasing it on WIP 13 helped, but
Try a reduced low_error_factor (0.3 or 0.2) with a lower pretrace_end.
If that gets too slow use lower nearest_count.
Weren't you usually using a two pass method for your scenes?
Last updated 06 Jul. 2004 _____./\/^>_*_<^\/\.______
Date: 30 Jul 2004 20:32:03
Message: <410ae883@news.povray.org>
Wait, are you saying that  image is NOT a photograph???
How long did it take to render?
- Nicolas Alvarez
nicoalvar0 [at] hotmail [dot] com
news:41038bdb@news.povray.org...
> Hi all:
>    I got my old office scene finished thanks to Wings3d. I used this
> scene to practice/discover techniques with Wings3d, creating some more
> objects that were somewhat challenging to do with CSG.
>    I'm going to do the final render at this size but with better
> radiosity settings, to get ride of the artifacts on the walls upper
parts.
> P.S.: Yes, the boss in not coming to the office today... ;)
> Jaime
Date: 31 Jul 2004 06:35:49
Message: <410b7605@news.povray.org>
   Thanks for the tips... I will try them.
   Yes, these were the settings for the first pass. The second pass uses
the same settings for the load, but with always_sample off and a little
increase of brightness.
Date: 31 Jul 2004 06:40:46
Message: <410b772e$1@news.povray.org>
   It can't be... at least to my knowledge, no one ever published a
magazine called  POVMAG. :)
   It's on the signature: about 10 hours.
Date: 31 Jul 2004 07:05:02
Message: <cefubu$5fi$1@chho.imagico.de>
Well - then forget about low_error_factor, just use a lower error_bound
in the first pass.
Date: 1 Aug 2004 10:55:54
Message: <410d047a$1@news.povray.org>
Very very good looking. (I can never get my scenes to look "sunny" like
that... *sigh*) Only real critisism is the light cast on the pillar in
the middle - surely it shouldn't look quite that sharp...
Andrew @ home.
