POV-Ray : Newsgroups : povray.binaries.images : Modelling in Wings Server Time
29 Dec 2025 20:16:50 EST (-0500)
  Modelling in Wings (Message 1 to 7 of 7)
Subject: Modelling in Wings
Date: 17 Jul 2004 12:13:49
Message: <40f9503d@news.povray.org>
hehe...
This is my first attempt at doing mesh-based models. The picture is a
capture of my wings interface. I'm modelling the skull of a cow, and so
far I think I'm doing okay.
Any advice to a Wings newbie so I don't wind up screwing up my model?
I've decided to take the approach of modelling to the line of symetry,
then when I have the model sufficiently completed, mirroring along the
axis and joining the two halves. It took me a while to figure out how to
cut the eye-hole, but I eventually figured it out. There's still a lot
of refinement needed, but this is just the first rough stages of the model.
I have to say, Wings is very cool and easy to use. And... best of all,
FREE! Hehehe..
Yes -- This is for my IRTC entry, btw...
I'm a bit excited about creating a mesh!
Download 'modelling.jpg' (100 KB)
Preview of image 'modelling.jpg'
Subject: Re: Modelling in Wings
Date: 17 Jul 2004 13:46:43
Message: <40f96603$1@news.povray.org>
"Michael Raiford" <mra### [at] hotmailcom> wrote in message
news:40f9503d@news.povray.org...
> hehe...
a
so
model?
  Yes, save your Wings file as 'cowskull2.wings/obj',
'cowskull3.wings/obj', etc. - Wings does have a tendency to just
evacuate now and again with near drastic results in my case... You can
then call on these once you've re-booted.
     Nice start.
     ~Steve~
Date: 17 Jul 2004 15:16:40
Message: <40f97b18$1@news.povray.org>
>>hehe...
> a
> so
> model?
>      Nice start.
>      ~Steve~
I agree with Steve.  I typically save copies of models at ever major
point of departure along the path of development. I have evolved a whole
standard of nomenclature to track the variations on the model as I
develop it.  Frequent saving of external copies is the single most
important thing I believe.  This way you can always return to a lighter
version of your model rather than try to wrestle with over heavy
geometry.  Save often and cut you loses quickly.
Make sure also, that you have plenty of depth in your undo buffer.
I use the mirror tool shamelessly but selectively.  I just maintain a
loop along the plane(s) of symmetry.  I can model with mirror off.  If I
have created some geometry I need relected, I do the loop cut, create
the mirror, freeze the mirror and continue on my way.  If I need to see
how the new geometry looks reflected in real time I leave the mirror on.
Some tools are more effective with the mirror on, some without.  Often I
mirror in more than one plane (not simultaneously of course).
I also loop cut then weld back different parts of the model for
different reasons usually to expose inner geometry or the limit the
scope of the magnet tool. This would be helpful I would think with a
subject such as yours with so many internal surfaces. These are more
advanced techniques, but ones that I wish I'd been more bold to take
advantage of earlier on.
A technique you also might find will save time and keep you out of
trouble with a model like yours is the use of the "bounding box" and
"center" tools in unison.  You might take 10 minutes with a practive
model to see how they work.  Basically the "center" tool will shift the
model so that the highlighted part of it, say a face you are working on,
is located at the origin.  This makes that area easier to examine with
the camera.  If you need to shift the model back to some original
location, you will have saved its "bounding box" and return it there.
The bounding box is only a need if you have several objects in a
specific relation to each other.
A cow's skull is an excellent, though challenging, subject for a Wings
model.  To infinity and beyond!
Date: 17 Jul 2004 22:55:04
Message: <40f9e688@news.povray.org>
Cow Skull, Rendered in POV-Ray
The textures are waay wrong, but this is a quick render of the Wings
model I just created.
I'm not entirely happy with it, I think I'll go back and do a few things
differently, namely find a way to mirror it without the seam. It
actually resembles the object I set out to model, though ;)
Download 'skull1.jpg' (19 KB)
Preview of image 'skull1.jpg'
Date: 18 Jul 2004 00:53:43
Message: <40fa0257$1@news.povray.org>
You froze the mirror first, then smoothed, right?
Date: 18 Jul 2004 01:03:24
Message: <40fa049c$1@news.povray.org>
How'd you ever guess? ;)
Date: 18 Jul 2004 10:17:37
Message: <40fa8681$1@news.povray.org>
Just checking, *smoothing before freezing* will cause a ridge.  If you
have properly removed/frozen the mirror before smoothing, and still get
a ridge, then you do need to be more careful about the angle of the
faces at the axis.  I have never had that give me much trouble, to be
honest, so I have never given it much attention.  Perhaps, after you
freeze the mirror you could select the dividing edgeloop and run a bevel
along it, then smooth?
