POV-Ray : Newsgroups : povray.binaries.images : Focal blur experiment (~45k) Server Time
13 Nov 2024 06:32:15 EST (-0500)
  Focal blur experiment (~45k) (Message 1 to 10 of 10)
Subject: Focal blur experiment (~45k)
Date: 7 Jul 2004 13:01:59
Message: <d8ntr1-d91.ln1@phillip.local.net>
This is a simple picture I made to experiment with focal blur, made out
of a picture that I made to experiment with glass. It's funny that
rendering this with focal blur on my new box is roughly 2 or 3 times
faster than just rendering normally on my old box, but I guess dual
Opterons and a Gig of RAM will do that :P I'm pretty sure I've got some
settings all wrong, and I'm still not too satisfied with the blur, but
this is the best I can do so far.
Scene contains 3 frame level objects; 1 infinite.
Statistics for check.pov, Resolution 800 x 600
Pixels:          519400   Samples:        16785793   Smpls/Pxl: 32.32
Rays:        1874649567   Saved:         181951612   Max Level: 200/200
Ray->Shape Intersection          Tests       Succeeded  Percentage
Cone/Cylinder               4151165419       955712561     41.21
CSG Intersection            4247033337      2798462427     65.89
CSG Merge                   4247033337      2983452192     70.25
Plane                       1322661856       383814742      6.83
Torus                       4199099378       617616430      7.27
Torus Bound                 4199099378       739529240      8.71
Bounding Box                 420591888      4268275552     47.37
Roots tested:            739529240   eliminated:           283896962
Calls to Noise:         1383597139   Calls to DNoise:     2154095944
Shadow Ray Tests:        134905375   Succeeded:           2158591940
Reflected Rays:          917455130   Total Internal:       130615242
Refracted Rays:          609348309
Transmitted Rays:          5378335
Radiosity samples calculated:    1628410 (5.17 percent)
Radiosity samples reused:       29867188
Smallest Alloc:                 18 bytes   Largest:           130816
Peak memory used:        290309806 bytes
Time For Trace:    6 hours 14 minutes   0.0 seconds (22438 seconds)
     Total Time:    6 hours 13 minutes  58.0 seconds (22438 seconds)
Download 'glass-focal-6july04.jpg' (45 KB)
Preview of image 'glass-focal-6july04.jpg'
Subject: Re: Focal blur experiment (~45k)
Date: 7 Jul 2004 16:00:44
Message: <40ec566c$1@news.povray.org>
I can see some noise at the bottom at the glass. Could it be that the glass
is touching the surface beneath?
Date: 7 Jul 2004 16:57:10
Message: <j25ur1-o02.ln1@phillip.local.net>
ooooo... I thought it was reflecting the sky, but that makes much more
sense. lol, I'm not so good with POV-Ray yet :P Thanks
Date: 7 Jul 2004 19:52:07
Message: <40ec8ca7$1@news.povray.org>
bob nous apporta ses lumieres ainsi en ce 07/07/2004 13:01... :
> out of a picture that I made to experiment with glass. It's funny that
> some settings all wrong, and I'm still not too satisfied with the
> blur, but this is the best I can do so far.
Why is the water at an angle? And why is'nt it visible true the glass,
but only over the top of it?
Date: 7 Jul 2004 20:02:57
Message: <7vfur1-nu2.ln1@phillip.local.net>
> Alain
That is not water, it is a reflection of the sky. I think I set the IOR
a little wrong :-P
Date: 8 Jul 2004 08:42:08
Message: <40ed4120$1@news.povray.org>
bob nous apporta ses lumieres ainsi en ce 07/07/2004 20:03... :
>> glass, but only over the top of it?
>> Alain
> IOR a little wrong :-P
What made me think of water is: 1 the meniscus around the top of the
angled part, 2 the refraction difference betwen the angled part and the
rest of the glass. But it may only be some strange reflection of the
near side.
Date: 8 Jul 2004 20:12:30
Message: <7t41s1-j32.ln1@phillip.local.net>
bob wrote:
>> glass
Thanks, I moved it up to 0.0001 and now there is no blue.
Date: 9 Jul 2004 04:33:39
Message: <40ee5863$1@news.povray.org>
> It's funny that
If you're using the standard POV-Ray build, I think you'll find that
only 1 processor is actually doing any work...
(Well, *actually*, only 1 processor is doing the rendering; I'm sure the
other one is handling stuff like updating the display and powering the
GUI, etc.)
Also, I would imagine for this particular thing, it didn't use an aweful
lot of RAM...
(...on the other hand, it reports a peak memory usage of roughly 290 MB,
so what would I know?)
Andrew @ home.
Date: 9 Jul 2004 13:22:41
Message: <b303s1-771.ln1@phillip.local.net>
Andrew C on Mozilla wrote:
>> It's funny that rendering this with focal blur on my new box is
>> roughly 2 or 3 times faster than just rendering normally on my old
>> box, but I guess dual Opterons and a Gig of RAM will do that :P
> GUI, etc.)
> lot of RAM...
> Andrew @ home.
I was very much aware of that, but either way, running on one of two
Opterons (with all the system overhead moved to the other) and a gig of
ram sure beats the 866Mhz CPU and 256Megs of RAM on my other system.
This way I can have it running in the background while still having a
normal system (as this is my main box) I can even play UT2004 whithout
losing much speed on POV-Ray :-D
(I also think it is using all that ram because of all the reflections in
the glass and because I don't know how to use radiosity right :P)
Date: 10 Jul 2004 03:43:13
Message: <40ef9e11$1@news.povray.org>
*Drool*
Reflections shouldn't make much odds. (Calculated completely seperately
for each individual ray.) Radiosity might - not sure how it stores all
those lovely samples it takes...
Andrew @ home.
