POV-Ray : Newsgroups : povray.binaries.images : Erm... yeah (~200 KB) Server Time
10 Sep 2025 22:42:15 EDT (-0400)
  Erm... yeah (~200 KB) (Message 1 to 1 of 1)
Subject: Erm... yeah (~200 KB)
Date: 4 Jul 2004 11:26:41
Message: <40e821b1@news.povray.org>
Well... it's a picture anyway. I don't know what it is... and it doesn't
look quite how I wanted it... but hey.
(And it "only" took 1 hour to render! :-S)
Redirecting Options
   All Streams to console..........On   and file Liz6.txt
   Debug Stream to console.........On
   Fatal Stream to console.........On
   Render Stream to console........On
   Statistics Stream to console....On
   Warning Stream to console.......On
Parsing Options
   Input file: D:\Orphi\POVRay\ForLiz\Liz6.pov (compatible to version 3.60)
   Remove bounds........Off
   Split unions.........Off
   Library paths:
     C:\Program Files\POV-Ray for Windows v3.6\INCLUDE
     C:\WINDOWS\Fonts
Output Options
   Image resolution 640 by 480 (rows 1 to 480, columns 1 to 640).
   Output file: D:\Orphi\POVRay\ForLiz\Liz6.png, 24 bpp PNG
   Graphic display......On  (gamma: 2.2)
   Mosaic preview.......On  (pixel sizes 64 to 8)
   CPU usage histogram..Off
   Continued trace......Off
Tracing Options
   Quality:  9
   Bounding boxes.......On   Bounding threshold: 3
   Light Buffer.........On
   Vista Buffer.........On   Draw Vista Buffer....Off
   Antialiasing.........On  (Method 2, Threshold 0.300, Depth 3, Jitter
1.00)
   Clock value:    0.000  (Animation off)
Render Statistics
Image Resolution 640 x 480
Pixels:           312000   Samples:         1040491   Smpls/Pxl: 3.33
Rays:           11778789   Saved:            386067   Max Level: 13/15
Ray->Shape Intersection          Tests       Succeeded  Percentage
CSG Intersection              30419785        11731926     38.57
Plane                       4106670975      2585255351     62.95
Sphere                        21762762        21762762    100.00
Clipping Object               15531123        15531123    100.00
Bounding Box                  76737571        57609470     75.07
Light Buffer                  46085173        32337234     70.17
Vista Buffer                   4758970         3435511     72.19
Calls to Noise:            56864280   Calls to DNoise:        71114100
Shadow Ray Tests:          17183456   Succeeded:               3779918
Reflected Rays:             5245746   Total Internal:          2983399
Refracted Rays:             2986109
Number of photons shot:         2506443
Surface photons stored:         2004187
Priority queue insert:         81551284
Priority queue remove:         36393518
Gather function called:         7756532
Gather radius expanded:         2518665
Smallest Alloc:                  18 bytes
Largest  Alloc:              327696 bytes
Peak memory used:          41021158 bytes
   0:41:02 Reclaiming memory
Total Scene Processing Times
   Parse Time:    0 hours  0 minutes  0 seconds (0 seconds)
   Photon Time:   0 hours 16 minutes  2 seconds (962 seconds)
   Render Time:   0 hours 41 minutes  2 seconds (2462 seconds)
   Total Time:    0 hours 57 minutes  4 seconds (3424 seconds)
CPU time used: kernel 16.03 seconds, user 3353.00 seconds, total 3369.03
seconds
Render averaged 91.18 PPS over 307200 pixels
Download 'liz6-final.jpg' (193 KB)
Preview of image 'liz6-final.jpg'
