Well... it's a picture anyway. I don't know what it is... and it doesn't
look quite how I wanted it... but hey.
(And it "only" took 1 hour to render! :-S)
Redirecting Options
All Streams to console..........On and file Liz6.txt
Debug Stream to console.........On
Fatal Stream to console.........On
Render Stream to console........On
Statistics Stream to console....On
Warning Stream to console.......On
Parsing Options
Input file: D:\Orphi\POVRay\ForLiz\Liz6.pov (compatible to version 3.60)
Remove bounds........Off
Split unions.........Off
Library paths:
C:\Program Files\POV-Ray for Windows v3.6\INCLUDE
C:\WINDOWS\Fonts
Output Options
Image resolution 640 by 480 (rows 1 to 480, columns 1 to 640).
Output file: D:\Orphi\POVRay\ForLiz\Liz6.png, 24 bpp PNG
Graphic display......On (gamma: 2.2)
Mosaic preview.......On (pixel sizes 64 to 8)
CPU usage histogram..Off
Continued trace......Off
Tracing Options
Quality: 9
Bounding boxes.......On Bounding threshold: 3
Light Buffer.........On
Vista Buffer.........On Draw Vista Buffer....Off
Antialiasing.........On (Method 2, Threshold 0.300, Depth 3, Jitter
1.00)
Clock value: 0.000 (Animation off)
Render Statistics
Image Resolution 640 x 480
Pixels: 312000 Samples: 1040491 Smpls/Pxl: 3.33
Rays: 11778789 Saved: 386067 Max Level: 13/15
Ray->Shape Intersection Tests Succeeded Percentage
CSG Intersection 30419785 11731926 38.57
Plane 4106670975 2585255351 62.95
Sphere 21762762 21762762 100.00
Clipping Object 15531123 15531123 100.00
Bounding Box 76737571 57609470 75.07
Light Buffer 46085173 32337234 70.17
Vista Buffer 4758970 3435511 72.19
Calls to Noise: 56864280 Calls to DNoise: 71114100
Shadow Ray Tests: 17183456 Succeeded: 3779918
Reflected Rays: 5245746 Total Internal: 2983399
Refracted Rays: 2986109
Number of photons shot: 2506443
Surface photons stored: 2004187
Priority queue insert: 81551284
Priority queue remove: 36393518
Gather function called: 7756532
Gather radius expanded: 2518665
Smallest Alloc: 18 bytes
Largest Alloc: 327696 bytes
Peak memory used: 41021158 bytes
0:41:02 Reclaiming memory
Total Scene Processing Times
Parse Time: 0 hours 0 minutes 0 seconds (0 seconds)
Photon Time: 0 hours 16 minutes 2 seconds (962 seconds)
Render Time: 0 hours 41 minutes 2 seconds (2462 seconds)
Total Time: 0 hours 57 minutes 4 seconds (3424 seconds)
CPU time used: kernel 16.03 seconds, user 3353.00 seconds, total 3369.03
seconds
Render averaged 91.18 PPS over 307200 pixels
Download 'liz6-final.jpg' (193 KB)
Preview of image 'liz6-final.jpg'
