POV-Ray : Newsgroups : povray.binaries.images : Milk again Server Time
29 Dec 2025 22:11:01 EST (-0500)
  Milk again (Message 1 to 5 of 5)
Subject: Milk again
Date: 4 Jul 2004 10:33:39
Message: <40e81543@news.povray.org>
Here's an improvement to the milk image:
It only took about a day and a half to render. Media is slow ;)
Below is the image statistics for the sene:
Scene Statistics
   Finite objects:            2
   Infinite objects:          6
   Light sources:             2
   Total:                    10
Render Statistics
Image Resolution 800 x 600
Pixels:           640005   Samples:         3667051   Smpls/Pxl: 5.73
Rays:           39635582   Saved:          13136056   Max Level: 20/20
Ray->Shape Intersection          Tests       Succeeded  Percentage
Cone/Cylinder              49164245976     21559078398     43.85
CSG Intersection           36051436252     17027385429     47.23
CSG Merge                  13112809724      9789099713     74.65
Plane                      80537260428     40268627016     50.00
Torus                      24582122988       152329202      0.62
Torus Bound                24582122988       185455838      0.75
Bounding Box               26845753476     24722417705     92.09
Roots tested:             185455838   eliminated:             58493936
Calls to Noise:                   0   Calls to DNoise:              10
Media Intervals:         3376775954   Media Samples:        3454524020
(1.02)
Shadow Ray Tests:       13396697460   Succeeded:            9977634949
Reflected Rays:            18737177   Total Internal:             4468
Refracted Rays:            12346472
Transmitted Rays:           4204640
Radiosity samples calculated:            15977 (0.21 %)
Radiosity samples reused:              7425740
Smallest Alloc:                  24 bytes
Largest  Alloc:               38416 bytes
Peak memory used:           2802551 bytes
Total Scene Processing Times
   Parse Time:    0 hours  0 minutes  0 seconds (0 seconds)
   Photon Time:   0 hours  0 minutes  0 seconds (0 seconds)
   Render Time:  34 hours 54 minutes 20 seconds (125660 seconds)
   Total Time:   34 hours 54 minutes 20 seconds (125660 seconds)
CPU time used: kernel 89.48 seconds, user 125008.92 seconds, total
125098.41 seconds
Render averaged 3.84 PPS over 480000 pixels
POV-Ray finished
Download 'milk.jpg' (44 KB)
Preview of image 'milk.jpg'
Subject: Re: Milk again
Date: 4 Jul 2004 11:24:17
Message: <40e82121$1@news.povray.org>
Impressively real... (Not sure about the bright front edge of the milk
though.) Would perhaps look better if the floor plane wasn't infinite...
I don't know... (Also, the checkers being that size give a slightly
bizzare impression of scale - like the glass is 20 feet tall or
something. ;-))
Andrew @ home.
Date: 4 Jul 2004 14:21:58
Message: <40e84ac6$1@news.povray.org>
> something. ;-))
> Andrew @ home.
Hmm.. Yeah, I should adjust the size of the checkers. Or just flat out
use another pattern.
As for the floor being infinite ... it should be cut off by another wall
behind the camera. If you look at the output there are 6 infinite
objects... 6 planes forming a box. I'm thinking picnic table plaid may
be a good option here for the floor surface. I don't like the
frappuchino colored walls either. Oh, the ways you change your mind when
a long render is taking place.
I'm wondering of the meniscus should be thickened a little for the milk
or that my density is still off. Hmm.
Back to the drawing board.
Thanks for the comments ;)
Date: 6 Jul 2004 10:41:43
Message: <40eaba27$1@news.povray.org>
the milk itself looks a lot better. the reflections on the glass are pretty
distracting though. i would do something like reflection {0.05, 0.2} or
less. what are these settings?
Date: 6 Jul 2004 12:15:02
Message: <40ead006$1@news.povray.org>
yeah, I think I have it at 0.1,1.0. I'm running another render at the
moment, with a changed floor and wall texture. I might try your
suggestion on the reflection, though... The image takes a day and a half
to render becuase of the media.
I have to wonder if POVRay used the photon mapping technique described
by the site linked to by a reply to my previous post, if there would be
a significant speedup.
