POV-Ray : Newsgroups : povray.binaries.images : [Wip] Grand Bi 1870 Server Time
18 Nov 2024 06:22:58 EST (-0500)
  [Wip] Grand Bi 1870 (Message 1 to 6 of 6)
Subject: [Wip] Grand Bi 1870
Date: 25 Jun 2004 09:06:08
Message: <40dc2340@news.povray.org>
Only made with moray, rendered with MLPov 0.83
Comments?
Luis
http://www.lightning-generator.org
Download 'bi.jpg' (64 KB)
Preview of image 'bi.jpg'
Subject: Re: [Wip] Grand Bi 1870
Date: 25 Jun 2004 09:09:29
Message: <mn.cb8d7d46581e6996.14125@please.com>
> Comments?
> Luis
The background photo should be in a better resolution in order not to
appear "stretched" and "aliased".... Otherwise the model is really well
done !!!!
The floor is also a bit "poor" and flat, but looks good enough for the
scene...
Dark Skull Software
http://www.darkskull.net
A+
Date: 25 Jun 2004 11:00:07
Message: <40dc3df7@news.povray.org>
I'm sure Luis will do very better. I think he started the drawing yesterday
in the evening!!!
Such a drawing with so efficiency in a so short time....
news:mn.### [at] pleasecom...
> > Comments?
> > Luis
> done !!!!
> scene...
> Dark Skull Software
> A+
Date: 25 Jun 2004 11:10:55
Message: <40dc407f@news.povray.org>
news:40dc3df7@news.povray.org...
yesterday
> in the evening!!!
I really began this morning  :)
Yesterday I especially sought images on the Web for model.
Still much of work.
Many thanks
Luis
Date: 25 Jun 2004 11:18:40
Message: <40dc4250@news.povray.org>
"Luis" <NOS### [at] ifrancecom> wrote in message
news:40dc407f@news.povray.org...
> yesterday
> > in the evening!!!
> Still much of work.
> Many thanks
> Luis
looks good so far. I would suggest some light comming from behind the
camera.
Date: 25 Jun 2004 12:22:02
Message: <40dc512a$1@news.povray.org>
Nice model Luis.  Your scene is just a little too dark.  In order to get the
best lighting from your HDRI map I would suggest increasing the ambient to
the level where all of the trees are in the range of the monitors brightness
(bright and green).  The sky is going to be completely washed out to white,
but that's the way it should be.  You could also try adding a faint
shadowless pointlight.  This will give you a little better contrast and some
specular highlights if you need them, although your model is reflecting the
HDRI quite nicely.
As others have mentioned, the background is a little distracting.  HDRI are
typically low resolution and I believe they need to be in order to work
efficiently.  Try rendering from an angle that shows only the floor, or put
a flat box with no_reflection behind the bike, just large enough to cover
the background.  That way it won't interfere with the lighting since you
can't see the other end of the bike anyway.
Skip
