POV-Ray : Newsgroups : povray.binaries.images : Saucer full of Secrets Server Time
15 Apr 2026 13:10:22 EDT (-0400)
  Saucer full of Secrets (Message 1 to 8 of 8)
Subject: Saucer full of Secrets
Date: 30 May 2004 08:36:02
Message: <40b9d532@news.povray.org>
It's my dad's birthday tomorrow - so I thought I'd use POV-Ray to
construct an interpretation of the title of one of my favourite Pink
Floud albums. (My dad likes Floyd too - and this image is now on his
birthday card.)
The resulting image isn't nearly as cool as I'd hoped. The spilt tea
doesn't look like tea - or even particularly like a liquid. The saucer
took me many hours to create, but doesn't look much like any saucer I've
ever seen. I'm quite pleased with the cup. (Maybe should have put some
gaps in that ring round the base...) And the black bit in the center was
supposed to be like a glowing space nebula... or... something. But
actually it just looks daft. (Oh, and the wood texture sucks.)
Anyone else have any comments?
Andrew @ home.
Download 'saucerb-small.jpg' (53 KB)
Preview of image 'saucerb-small.jpg'
Subject: Re: Saucer full of Secrets
Date: 30 May 2004 08:57:03
Message: <40b9da1f$1@news.povray.org>
> birthday card.)
I don't know much about Pink Floyd and their album's, so I've got no clue
what you're after. But I'll try and help some with the technical stuff:
The spilt tea is just to thick. Make it much thinner, with proper relation
in thickness to the cup. Some more drops, formed to show some sort of
puddle, might do some wonders as well, rather than just two cylindrical
drops. Perhaps you'd want to use a particle system for it, there's Rune's
and mine.
The saucer, well I'm not sure what you're after with that one, so I can't
comment much on that. As for the wood: try using a repeat-warp to simulate
some tiling, add some black-hole warps for branch-holes. Rotate the plane so
that the wood-grain doesn't run along an axis.
Keep it up!
Tim
"Tim Nikias v2.0"
Date: 30 May 2004 10:14:23
Message: <40b9ec3f$1@news.povray.org>
I agree, I thought it was a coaster at first.
Date: 30 May 2004 11:33:58
Message: <40b9fee6@news.povray.org>
40b9d532@news.povray.org...
> birthday card.)
Aaah Sid Barret's era...
Nice idea
For the tea, it looks like it has a filtering pigment.
Did you try a completely transparent pigment (transmit 1) and interior with
a fade_color?
Most liquids have no surface pigment but an interior color which grows with
the thickness.
I'd lower specular roughness as well
Happy birthday to your dad :)
Marc
Date: 30 May 2004 15:16:46
Message: <40ba331e@news.povray.org>
Well, the actual album cover work doesn't feature any saucers... (It is
rather cool though - and fits the dark mysterious mood of the album.)
The idea was to have a saucer, with a spilt cup of tea next to it
(hopefully leading to am impression that something... weird just
occurred). Next to it, a saucer, with some sort of liquid in it, and
some sort of mysterious colour effect going on inside the liquid (hadn't
decided exactly what yet).
...and then there's the image I actually constructed.
The saucer took forever. The cup wasn't actually too bad to do. (BTW, it
*isn't* hollow - but since it's facing away, you can't tell.) I fiddled
with the water/tea for ages, but in the end, the best I could do was to
add a sky plane and a slight normal pattern to the water. If I leave it
transparent, it's almost invisible.
The "secrets" (black liquid) was the last part to be added. Original
plan was some strange arrangement of tealeaves - I hadn't thought any
further than that. But what I ended up doing was a slightly spacey blue
crackle pattern with a scattering of stars (which is *also* a crackle
pattern).
*checks source*
Yes, it's supposedly 1 cm thick. Maybe that is a little excessive...
(The cup is supposedly 5 cm in radius - maybe that's a little small.)
> drops.
Yes, I think it probably does need more drops...
> and mine.
Will maybe try that in future, but it's too late now. (The event is
*tomorrow* ;-))
Well, doesn't look very much like a saucer, does it?
I think maybe the edge should have a lip on it - but it took me a few
hours of CGS with various cones to get the dip in the middle to work.
(Now I've seen the final image, I could probably have done it a simpler
way... *sigh*)
Does POV-Ray have a pattern that draws concentric cylinders?
The "cylinder" pattern only draws 1 cylinder. In the end, I used "onion"
with uneven scaling. The idea was to then slice this at a slight angle
to create V-shapes - and then add some turbulence.
I should probably add that the LCD display on my laptop is *lame*. The
image looks like a glass of beer. All the colours are muted and faded.
It wasn't until I tried it on a better screen that I realised the
colours were totally over-saturated and had to turn them down (resulting
in the image you see now, which looks like beer on my laptop).
I think the wood is probably much too orange. (How many kinds of wood
are that insane shade?) Like I say, it looked brown on my screen. I
never did get the scaling and turbulence right to make the rings small
and yet distinct, while still being fuzzy and turbulent...
> Keep it up!
Ah well - thanks for the encouragement anyway! :-S
Andrew @ home.
Date: 30 May 2004 15:19:18
Message: <40ba33b6@news.povray.org>
>>birthday card.)
I'll take your word for it. :-)
(I suppose I could go check the sleave notes, couldn't I?)
> Nice idea
Thanx.
As I say, it's supposed to be a spilt cup of tea, which "something"
freaky happening in the saucer. But you probably wouldn't know it from
the picture... *sigh*
Yup.
> a fade_color?
Nope. But maybe I should...
> the thickness.
Yes - especially something like tea which is a suspension...
Yeah, I think it is perhaps a little too shiny...
What do you make of the texture of the cup?
Thanx :-)
Andrew @ home.
Date: 30 May 2004 15:25:07
Message: <40ba3513@news.povray.org>
40ba331e@news.povray.org...
It is what wood pattern does if you put no turbulence
Marc
Date: 30 May 2004 15:27:37
Message: <40ba35a9$1@news.povray.org>
*slaps head*
Daaaaw!
