POV-Ray : Newsgroups : povray.binaries.images : YACWRS Server Time
22 Mar 2026 21:35:18 EDT (-0400)
  YACWRS (Message 1 to 4 of 4)
Subject: YACWRS
Date: 16 May 2004 12:46:00
Message: <40a79ac8@news.povray.org>
Yet Another Checkerboard WIth Reflective Sphere...
OK, what Alex Kluchikov did the other day was just uncontrollably
fantastic, so I decided to do something similar.
Naturally, my copy doesn't come close to the genius of the original.
I actually did 3 versions, which I'm going to post as replies to this
message... stand by...
(The intension was [obviously] that each image should be a little bit
better than the last... but I think #2 is actually the best of the
lot... ho hum!)
Andrew @ home.
Subject: YACWRS #1 (~140KB)
Date: 16 May 2004 12:48:39
Message: <40a79b67@news.povray.org>
CPU usage histogram.Off
   Continued trace.....Off  Allow interruption..Off  Pause when done.....Off
   Verbose messages.....On
Tracing Options
   Quality:  9
   Bounding boxes.......On  Bounding threshold: 3
   Light Buffer.........On  Vista Buffer.........On  Draw Vista Buffer...Off
   Antialiasing.........On  (Method 2, Threshold 0.050, Depth 4, Jitter
1.00)
Animation Options
   Clock value....   0.000  (Animation off)
Redirecting Options
   All Streams to console.........Off
   Debug Stream to console.........On
   Fatal Stream to console.........On
   Render Stream to console........On
   Statistics Stream to console....On
   Warning Stream to console.......On
Scene contains 122 frame level objects; 0 infinite.
Statistics for D:\Orphi\POVRay\Checker1\Checker1.pov, Resolution 640 x 480
Pixels:          307200   Samples:         3945517   Smpls/Pxl: 12.84
Rays:           9509793   Saved:             16905   Max Level: 8/8
Ray->Shape Intersection          Tests       Succeeded  Percentage
Cone/Cylinder                112756090        51734952     45.88
CSG Intersection              56378045         6140578     10.89
Sphere                         7497505         3092976     41.25
Bounding Box                 152634464        65358168     42.82
Light Buffer                 305952523       107006311     34.97
Vista Buffer                  38658197        26104392     67.53
Calls to Noise:                  0   Calls to DNoise:             10
Shadow Ray Tests:         38533818   Succeeded:              3127352
Reflected Rays:            5564276
Smallest Alloc:                 25 bytes   Largest:           245808
Peak memory used:          1037319 bytes
Time For Trace:    0 hours  2 minutes  47.0 seconds (166 seconds)
     Total Time:    0 hours  2 minutes  46.0 seconds (166 seconds)
CPU time used: kernel 7.73 seconds, user 137.66 seconds, total 145.39
seconds
Render averaged 2112.95 PPS over 307200 pixels
POV-Ray finished
Download 'checker1-final.jpg' (134 KB)
Preview of image 'checker1-final.jpg'
Subject: YACWRS #2 (~150 KB)
Date: 16 May 2004 12:49:39
Message: <40a79ba3@news.povray.org>
Tracing Options
   Quality:  9
1.00)
Animation Options
Redirecting Options
Statistics for D:\Orphi\POVRay\Checker1\Checker2.pov, Resolution 640 x 480
Pixels:          307200   Samples:         4914631   Smpls/Pxl: 16.00
Rays:          13350491   Saved:             16830   Max Level: 8/8
Cone/Cylinder                138870308        62175026     44.77
CSG Intersection              69435154         7637443     11.00
Sphere                        16421574         7019220     42.74
Bounding Box                 220086762        92139029     41.86
Light Buffer                 405262635       143002103     35.29
Vista Buffer                  48874617        33276912     68.09
Shadow Ray Tests:         52319229   Succeeded:              4534706
Reflected Rays:            8435860
Time For Trace:    0 hours  3 minutes  16.0 seconds (196 seconds)
     Total Time:    0 hours  3 minutes  16.0 seconds (196 seconds)
CPU time used: kernel 8.41 seconds, user 173.15 seconds, total 181.56
seconds
Render averaged 1691.99 PPS over 307200 pixels
POV-Ray finished
Download 'checker2-final.jpg' (143 KB)
Preview of image 'checker2-final.jpg'
Subject: YACWRS #3 (~200KB)
Date: 16 May 2004 12:50:56
Message: <40a79bf0@news.povray.org>
Tracing Options
   Quality:  9
1.00)
Animation Options
Redirecting Options
Scene contains 463 frame level objects; 0 infinite.
Statistics for D:\Orphi\POVRay\Checker1\Checker3.pov, Resolution 640 x 480
Pixels:          307200   Samples:        10660739   Smpls/Pxl: 34.70
Rays:          25718009   Saved:             96988   Max Level: 7/8
Cone/Cylinder                437714074       171132233     39.10
CSG Intersection             218857037        23454316     10.72
Sphere                        33932567        13980554     41.20
Bounding Box                 681664956       272111999     39.92
Light Buffer                1912828132       604410052     31.60
Vista Buffer                 119778138        81732131     68.24
Shadow Ray Tests:        181056735   Succeeded:              7256391
Reflected Rays:           15057270
Peak memory used:          2037215 bytes
Time For Trace:    0 hours 11 minutes  10.0 seconds (670 seconds)
     Total Time:    0 hours 11 minutes  10.0 seconds (670 seconds)
CPU time used: kernel 16.63 seconds, user 573.19 seconds, total 589.83
seconds
Render averaged 520.83 PPS over 307200 pixels
POV-Ray finished
Download 'checker3-final.jpg' (193 KB)
Preview of image 'checker3-final.jpg'
