For the foam I gave up the object pattern trick because it is boolean and
not good at close-up
I tweaked a function based on the same image as the isosurface terrain.
This function fills the crackle pattern at hi values and let it empty at low
values.
As usual comments are welcome :-)
Marc
Download 'St_Mathieu.jpg' (110 KB)
Preview of image 'St_Mathieu.jpg'
Marc Jacquier nous apporta ses lumieres ainsi en ce 2004/05/15 11:39... :
>values.
>Marc
Big improvement, a lot more realistic. Your water is great. Time to
concentrate on the ground.
40a6436a$1@news.povray.org...
>Time to concentrate on the ground.
It's in the *to do* next items :)
Marc
That's the best sea I've seen anywhere - well done.
Mick
"Marc Jacquier" <jac### [at] wanadoofr> wrote in message
news:40a6394e@news.povray.org...
low
> values.
> Marc
Hi Marc, that's excellent! Great sea. I would have a go at adding
just a little hint of 'off-yellow', or 'cream' colour, if you will, to
*some* of your surf.
~Steve~
> Marc
I also like the translucency of the waves just behind the surf. Spot
on! :)
~Steve~
news: 40a64d93@news.povray.org...
Me flush
thanks Master
Marc
40a650c2@news.povray.org...
Thanks
Good idea for the cream color at thickened zones of the foam (I think it
happens only when seawater is carrying plankton, though)
Marc
40a6515b$1@news.povray.org...
> on! :)
Hours in front of waves waiting for the take off :)
Marc
> values.
> Marc
curiousity, how tall is a lighthouse typically ?
how tal are the walls around the field ?
do the two and the view angle look correct ?
stephen
