POV-Ray : Newsgroups : povray.binaries.images : Mdia interaction Server Time
11 Sep 2025 10:27:01 EDT (-0400)
  Mdia interaction (Message 1 to 7 of 7)
Subject: Mdia interaction
Date: 11 May 2004 16:59:49
Message: <40a13ec5$1@news.povray.org>
The setup:  A cylinder intersects a sphere, both filled with scattering
media.  However, when I use an empty density for the cylinder (removing all
media) it still casts some sort of ghost in the sphere.  This effect is
present no matter what density is used, and is problematic when you don't
want the cylinder's seem present.  Is there anyway to remedy this problem?
Skip Talbot
//begin code
#version 3.5;
global_settings {
  assumed_gamma 1.0
  max_trace_level 15
  location  <0.0, 0.5, -4.0>
  direction 1.5*z
  look_at   <0.0, 1.0,  0.0>
sky_sphere {
    gradient y
    color_map {
      [0.0 rgb <0.6,0.7,1.0>]
      [0.7 rgb <0.0,0.1,0.8>]
light_source {
  <0, 0, 0>
  color rgb <1, 1, 1>
  translate <-30, 30, -30>
plane {
  y, -1
  texture
      checker
      color rgb 1
      color blue 1
      scale 0.5
sphere {
  0.0, 0.5
  pigment { rgbt 1 }
  interior { media { scattering {2,4} } }
  hollow
  translate 0.5*y
cylinder {
  0*y,  3*y,  0.25
  pigment { rgbt 1 }
   density { } } }
  hollow
//end code
Download 'test.jpg' (18 KB)
Preview of image 'test.jpg'
Subject: Re: Mdia interaction
Date: 11 May 2004 18:46:14
Message: <40a157b6$1@news.povray.org>
Skip Talbot nous apporta ses lumieres ainsi en ce 2004/05/11 16:59... :
>Skip Talbot
>//begin code
>#version 3.5;
>global_settings {
>  assumed_gamma 1.0
>  max_trace_level 15
>camera {
>  direction 1.5*z
>sky_sphere {
>  pigment {
>    gradient y
>    color_map {
>light_source {
>  <0, 0, 0>
>  color rgb <1, 1, 1>
>plane {
>  y, -1
>  texture
>    pigment {
>      checker
>      color rgb 1
>      color blue 1
>      scale 0.5
>sphere {
>  0.0, 0.5
>  pigment { rgbt 1 }
>  hollow
>  translate 0.5*y
>cylinder {
>  0*y,  3*y,  0.25
>  pigment { rgbt 1 }
>   density { } } }
>  hollow
>//end code
Diagnostic: You see the "surface" of your cylinder.
Cure: Bind the two shapes in a merge.
merge{
    sphere{...}
    cylinder{...}
That way, you remove the surface of the cylinder where it's inside the
sphere.
You may now want to use only one texture and density statement for the
complete object.
Date: 11 May 2004 18:50:02
Message: <opr7uxptemzjc5hb@news.povray.org>
> all
> problem?
Increasing either 'intervals' or 'samples' seems to help, but at a big
cost in terms of render time.
The attached images are as follows:
1 - Unmodified scene
2 - samples 200, 200
3 - intervals 20
Render times were as follows:
1 - 9 s
2 - 72 s
3 - 330 s
If you look really closely, you can just make out a very faint outline of
the cylinder on the left side of the sphere in the two "improved" images.
The one with increased 'samples' also shows bright spots at the top and
bottom.
Also note that increasing either 'samples' or 'intervals' makes the sphere
darker. I do not know why this is so, but it happens regardless of the
cylinder's presence (the darkening effect happens even if you remove the
cylinder altogether).
To conclude: media is tricky stuff...
FE
Download 'media_interaction_test_original.png' (38 KB) Download 'media_interaction_test_samples_200.png' (38 KB) Download 'media_interaction_test_intervals_20.png' (38 KB)
Preview of image 'media_interaction_test_original.png'
Preview of image 'media_interaction_test_samples_200.png'
Preview of image 'media_interaction_test_intervals_20.png'
Date: 11 May 2004 19:00:48
Message: <40a15b20$1@news.povray.org>
Brilliant!
Date: 11 May 2004 19:01:11
Message: <40a15b37$1@news.povray.org>
Ah, the render time...  Its worth it though.  Thanks.
Skip
Date: 12 May 2004 05:14:31
Message: <40a1eaf7$1@news.povray.org>
Is this going to be a "twister"?
Date: 12 May 2004 11:16:34
Message: <40a23fd2$1@news.povray.org>
HOW DID YOU GUESS?  I thought I could keep it on the down low using simple
primitives for that example.  I'm not using primitives for the final, but
yes its going to be a "twister."  For the first time I plan to enter the
IRTC this round, so I'm going to wait until the deadline is closer before
posting WIPs or maybe wait until it's done.
Skip
