POV-Ray : Newsgroups : povray.binaries.images : Collage Theorem Demo (35k, 50k, 35k) Server Time
20 Jun 2026 11:23:07 EDT (-0400)
  Collage Theorem Demo (35k, 50k, 35k) (Message 1 to 7 of 7)
Subject: Collage Theorem Demo (35k, 50k, 35k)
Date: 9 May 2004 14:29:12
Message: <409e7878@news.povray.org>
Back in the days when it was easy to write interactive applications, I
made a demonstration (as a Hypercard stack, and in Macintosh Pascal for
the 512K Mac) that allowed the user to click on points to make a source
triangle, and any number of destination triangles, to create an Iterated
Function System.  It also output the coefficients for the affine
transformations.  This was a great way to get to understand the "collage
theorem" (see Barnsley's "Fractals Everywhere" book, among many others.)
  Now I suppose that if I want to do the same thing again, I'll have to
learn JAVA.
In the meantime, using POVRay, one can manually enter the values for the
vertices of the triangles.  If anyone wants the code, I'll post it.
Dave Matthews
(With some work, perhaps I can use the IFS below for my "sig")
Download 'collage01.jpg' (33 KB) Download 'collage02.jpg' (50 KB) Download 'collage03.jpg' (35 KB)
Preview of image 'collage01.jpg'
Preview of image 'collage02.jpg'
Preview of image 'collage03.jpg'
Subject: Re: Collage Theorem Demo (35k, 50k, 35k)
Date: 9 May 2004 14:33:25
Message: <409e7975$1@news.povray.org>
> learn JAVA.
No need - I've got the code already.
Erm - somewhere...
*searches around*
Oh well! I _did_ have it... I guess you could always do it with
PostScript instead! :-D
Neat.
Yes, that would seem an optimal way to do it... ;-)
But hey, see if you can make the shape a lil more interesting first tho
- maybe add a bit of twist or something... I don't know, long time since
I did this stuff. ;-)
Andrew @ home.
PS. Nasty checker texture :-S
Date: 9 May 2004 15:01:32
Message: <409e800c$1@news.povray.org>
> Erm - somewhere...
> *searches around*
Seriously, if you do happen to find the JAVA applet, could you post a
link in off-topic, or e-mail it to me?  I'd really appreciate it.
Although I'm probably going to have to break down and learn a usable
programming language again.  (PostScript?)
I could just flip some of the transforms around, or angle them so that
they rotate inward, or being more radical and following the lead of this
very interesting application,
http://flam3.com/
I could compose it with a non-linear transformation (see his
well-written paper under "math" at the above link).
Mostly, though, I made this POVRay version so that I could make 3D IFS.
  I can arrange ball-and-stick tetrahedra or parallelepipeds and this
should be easier than trying to puzzle out the transformations directly.
Man, no-one likes my baby blue and pink checkers.  Here I am, just
trying to be gender-inclusive.  Oh, well. ;-)
Thanks for the comments.
Dave Matthews
Date: 9 May 2004 15:49:02
Message: <409e8b2e@news.povray.org>
>> Erm - somewhere...
>> *searches around*
I wrote a Java applet to do (hard-coded) 2D linear IFS as part of my
dynamic HTML assignment. As with everything in Java, doing the program
is easy, making the output *visible* is almost impossible! Displaying
text, drawing dots... Java makes these things ridiculusly difficult.
>> tho - maybe add a bit of twist or something... I don't know, long time
>> since I did this stuff. ;-)
> http://flam3.com/
Personally, when I do 3D IFS it tends to be 2D ones, tweaked slightly to
use the extra dimension. Otherwise you seem to just get clouds of stuff
which isn't all that interesting. (Having said that, it's not something
I've had the pleasure of playing with all that much as yet.)
*grins*
Andrew @ home.
Date: 9 May 2004 16:27:47
Message: <409e9443$1@news.povray.org>
That's a shame.  Do you know of any framework (platform specific is
fine) that makes it easy to write clickable graphic applications?  I
used to love the old Macintosh Pascal, because you basically said
something like "open window" "get mouse location" "draw line" -- things
I can understand.
That's been my experience, also.  I'm attaching an IFS that I didn't use
in Paul Bourke's Fractal contest, since it was just a spiral IFS "pushed
up" a bit.  I'm hoping that if I can visualize them better, I'll be able
to make them better.  We'll see.
Dave Matthews
Download 'tdifs005.jpg' (38 KB)
Preview of image 'tdifs005.jpg'
Date: 9 May 2004 23:31:11
Message: <409ef77f@news.povray.org>
"Dave Matthews" <dma### [at] nospamnet> wrote in message
news:409e7878@news.povray.org...
> learn JAVA.
No reason to resort to Java.
Google for pythoncard,  its a mix of ideas from hyperstack and VB,
implemented in python.
Very easy to get your head around. Between this, wxWindows, tkinter, etc.
you can build
stuff like you describe very easily.
There's also pyGame which may be even easier for what your thinking of.
Date: 10 May 2004 09:25:49
Message: <409f82dd$1@news.povray.org>
> you can build
Thanks, I'll check into them.  Sounds like what I need.
Dave Matthews
