Hi folks.
This is supposed to be a an extreme closeup of a small gemstone (a few
mm across), set in a gold setting. But it looks nothing like that - and
I can't figure out why.
The stone doesn't look remotely gem-like. Can't figure that out. It's
transparent, reflective, and reflective. What am I missing?
The setting doesn't look like gold. I've fiddled with brilliance,
specular, roughness, reflection, and turned on metallic (as well as
conserve_energy). Still doesn't look remotely like metal. Why?
Also can't figure out why the metal setting apparently isn't resulting
in any photons. (It makes the photon process hundreds of times slower -
that is, I had to multiply the photon spacing a few hundred times to get
it to render this year.)
This was supposed to end up being a single link in a bracelet - but it
looks so rubbish I hadn't get that far yet.
Any ideas?
Andrew @ home.
Download 'bracelet2.jpg' (53 KB)
Preview of image 'bracelet2.jpg'
"Andrew C on Mozilla" <voi### [at] devnull> wrote in message
news:409e0084@news.povray.org...
> Hi folks.
few
and
It's
Your gemstone needs facets on the back of the stone. Do a Google
search for 'Baguette Cut', 'Emerald Cut', and 'Princess Cut'. You'll
see that your gemstone also needs to be shallower.
It looks like gold to me - it's not that bad, try turning the
ambient and reflection up a touch. The tips of your 'prongs' need to
be bent over the stone too.
resulting
slower -
get
No idea.
it
Perseverance! ;)
~Steve~
> Any ideas?
> Andrew @ home.
>>few mm across), set in a gold setting. But it looks nothing like
>>that - and I can't figure out why.
>>It's transparent, reflective, and reflective. What am I missing?
...so what you're saying is that it's all in the cut?
OK... well just Googling for (e.g.) Emerald Cut gives me a huge list of
shops that will *sell* me an emerald cut gemstone of one sort or
another... I've found a few little black and white 2D outline drawings
and a few photos, but I can't find anything clear enough to make a
POV-Ray model from.
Anyone know where I can find technical drawings with measurements?
I don't know... maybe the lighting is wrong... I already have 3 light
sources, and still can't get it to look right. Oh yes, and I know about
the prongs - but I have no idea how to explain that to POV-Ray.
> Perseverance! ;)
Well, this *is* the POV-Ray NG isn't it? ;-) LOL!
Andrew @ home.
Hi!
Try his link http://www.3dlapidary.com/Home.htm it could of help. They got a
lot of free *.dxf models of gemsone cuts.
Matt
Matt Burns wrote:
> Hi!
> Matt
Thanks for the link. My 25'th is comming up soon and there is just no
way I can afford a real gemstone, so--- POV to the rescue!
(it is a lot better than the silver dime-in-ring joke. I took a 1958
silver US dime and placed it inside my wedding band. She laughed, a little.)
I think it needs a bit of dispersion (1.1, 50 samples)
and maybe a normal ( something like bump 0.1 scale 100 )
so that it warps very gently the surface of the stone.
This should produce interesing highlights.
Best,
S.
Steven Pigeon, Ph. D.
ste### [at] stevenpigeoncom
ste### [at] videotronca
> Hi folks.
> Any ideas?
> Andrew @ home.
Yes - I already found this by Googling.
Trouble is... what the hell is a DXF file??
Andrew @ home.
> little.)
...and why do you think *I* was trying to make a ruby bracelet? ;-)
news:409e26b3$1@news.povray.org...
You'll
Yes, normally. A diamond is the perfect example of refraction. I
forgot to say that you need more facets on the crown, (top, table), of
your gemstone too - depending on what cut you want.
of
drawings
> POV-Ray model from.
Hit 'Images' in Google for all of those terms...
as
to
light
Well, with this reflective surface, you need the gold to reflect
*something*, so, put something behind the camera, put something above
the setting.
Also, try this for a gold texture:
texture {T_Gold_1A }
finish {
ambient 0.035
diffuse .3
brilliance 5
phong 0.41
phong_size 2}}
I'm sure someone can tell you, but I don't know either! :o/
> > Perseverance! ;)
It is??! Sheesh! I've been coming to the wrong place all these
years! :-O
~Steve~ ;)
> Andrew @ home.
Andrew C on Mozilla nous apporta ses lumieres ainsi en ce 2004/05/09
05:54... :
> Hi folks.
> - that is, I had to multiply the photon spacing a few hundred times to
> get it to render this year.)
> Any ideas?
> Andrew @ home.
The IOR for your gem may be to low, ruby's ior is higher than glass,
close to 2 I think. Did you set the fade_distance and fade_power? Do you
use media_atenuation? Sould be on. Now, it look like only the surfaces
have any colour.
This look like a midle-ages kind of cut, no faceting on the under side,
very box like (the had still to develop the needed skils and tools).
Did you set the metal as a target for the photons?
It may be "good enough" as is if it's going to be small in the final
scene. How many links in your bracelet? How large will be the complete
bracelet in your scene? You may do a trial render of the complete
bracelet at the planed scale (no protons, no radiosity, no aa, only 1 or
2 light).
