POV-Ray : Newsgroups : povray.binaries.images : Lighthouse Server Time
15 Jul 2026 07:33:27 EDT (-0400)
  Lighthouse (Message 4 to 13 of 23)
<<< Previous 3 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Lighthouse
Date: 8 May 2004 07:37:21
Message: <Xns94E38A61AF125raf256com@203.29.75.35>
spa### [at] raf256com news:Xns94E38A49E36DBraf256com@203.29.75.35
> wow grete see, how did You did it?
sea
http://www.raf256.com/3d/
Computer Graphics
Date: 8 May 2004 07:40:24
Message: <409cc728@news.povray.org>
409cc5d8$1@news.povray.org...
> Excellent... Really nice work :-))
Marc
Date: 8 May 2004 07:41:25
Message: <409cc765$1@news.povray.org>
Xns94E38A61AF125raf256com@203.29.75.35...
> sea
I'll post the  sea code on p.b.s-f as soon as I'm finished cleaning the code
Marc
Date: 8 May 2004 07:43:44
Message: <409cc7f0$1@news.povray.org>
Xns94E38A49E36DBraf256com@203.29.75.35...
> As for land/rocks... very nice, but... something is a bit wrong imho.. hmm
> colors look a bit to flat IMHO... or like there was a median / oil paint
> filter applied to texture
 I quite agree: I meet some issue adding a normal pattern with a slope
pigmant pattern, I'm trying to find a workaround.
Maybe terrain will end as an isosurface as well
Marc
Date: 8 May 2004 08:17:54
Message: <409ccff2@news.povray.org>
409cc765$1@news.povray.org...
code
Done :)
Marc
Date: 8 May 2004 08:47:04
Message: <409cd6c8@news.povray.org>
"Marc Jacquier" <jac### [at] wanadoofr> schreef in bericht
news:409ccff2@news.povray.org...
news:
> code
> Done :)
Yipee!!!! Comes just in time for a scene I have in mind!!!!!  :-))
Otherwise, I like the picture, and I think the swell is well rendered.
Shouldn't the windphane on the lighthouse point landwards? Of course, the
wind may have changed, and waves are pretty conservative once they are in
motion :-0
What is particularly good is the green transparency in the background swell.
Date: 8 May 2004 10:45:00
Message: <kurtzlepirate-09EE8A.16445508052004@news.povray.org>
In article <409cc307@news.povray.org>,
 "Marc Jacquier" <jac### [at] wanadoofr> wrote:
> Foam is after Jaime's method but I'm not satisfied (not by the method but by
> my use of it for close-up):
  where to get infos of this method ??
  thanks
Date: 8 May 2004 11:23:51
Message: <409cfb87$1@news.povray.org>
kurtzlepirate-09EE8A.16445508052004@news.povray.org...
>   thanks
I just quote Jaime's  april/29/2004 response in "My LOTW project" thread on
this group:
>    Casually, I'm just tweaking this texture. Now I simlified it a bit,
> removing the intersection. The same terrain itself translated a bit is
> enough. There is the relevant part:
>   #declare terrain_coast=object{terrain translate Foam_Level*y}
>   #declare m_water=
>   material{
>    texture{
>     pigment_pattern{object{terrain_coast rgb 0, rgb 1}}
>     texture_map{
>       [0 t_water]
>       [1 t_foam]
>     scale 100 warp{turbulence .3 lambda 3} scale 1/100
>     scale 1000 warp{turbulence .3 lambda 3} scale 1/1000
>    The translation amount depends on your scene scale and how much foam
> you want, and the same can be applied to the warps scale.
the trick is to use an object as pattern
either the calculated point is inside the object and the returned value is 1
or the point is outside and the value is 0
It is a boolean pattern
my complete code for the sea (including isosurface and material) is on the
p.b.s-f group
Marc
Date: 8 May 2004 11:35:06
Message: <409cfe2a@news.povray.org>
409cd6c8@news.povray.org...
I'm glad that can be usefull for somebody :-)
I look forward to see your scene.
> motion :-0
Or maybe the axle is solden by rust :-p
No seriousely I didn't think of that, thanks for noticing it. but it should
be pointing offshore as it is facing the wind.
swell.
Thanks I spent some time at tweaking the absorption and scattering colors
Marc
Date: 8 May 2004 11:54:22
Message: <409d02ae$1@news.povray.org>
"Marc Jacquier" <jac### [at] wanadoofr> wrote in message
news:409cfe2a@news.povray.org...
<snip>
should
Nah, those waves look as if they're being held up by an offshore breeze!
Dave.
