POV-Ray : Newsgroups : povray.binaries.images : Two rings Server Time
15 Jul 2026 05:52:26 EDT (-0400)
  Two rings (Message 11 to 16 of 16)
Subject: Re: Two rings
Date: 5 May 2004 08:59:56
Message: <4098e54c@news.povray.org>
> > Comments are welcomes...
> preciousssssssss
Date: 5 May 2004 11:52:12
Message: <40990dac$1@news.povray.org>
Hugo Asm wrote:
 > Awesome Rolex!! It has a very nice mood and the realism is stunning. I
 > suppose you've used HDRI for lighting? Pure rad and reflections?
HDRI of course
campus_probe.hdr from debevec's website, http://www.debevec.org/Probes/
 > The sky has a nice side-effect in this case...: It makes the rings look
 > almost as if they are shining; as if they have such a bright
highlight, it
 > causes flares on the lens of the camera  = additional realism. You've
been a
 > little lucky with that.
It took many try (textures, HDRI maps, lights) to get this result but,
yes, lucky i am :)
Denis Bodor
http://www.lefinnois.net                      Irc : Lefinnois
Date: 5 May 2004 12:01:24
Message: <40990fd4@news.povray.org>
Felbrigg wrote:
> Very Nice, How'd you do the text?
Lettres are stored in an array and a while loop take each of them,
translate and rotate creating an union used in CSG's difference.
The problem is that each lettres don't use the same space ("i" take less
than "m") so i choose to create another array populated with rotation
values.
Here is a sample code (in hope that's clearer than my poor english) :
#declare MyArray = array[12];   #declare Mydecal = array[12];
#declare MyArray[0]="D";        #declare Mydecal[0] = 0;
#declare MyArray[1]="E";        #declare Mydecal[1] = Mydecal[0]+10;
#declare MyArray[2]="N";        #declare Mydecal[2] = Mydecal[1]+10;
#declare MyArray[3]="I";        #declare Mydecal[3] = Mydecal[2]+10;
#declare MyArray[4]="S";        #declare Mydecal[4] = Mydecal[3]+7.5;
#declare MyArray[5]="&";        #declare Mydecal[5] = Mydecal[4]+10;
#declare i = 0;
#declare nom = union {
#while(i<12)
text {
   ttf   "../TTF/courbd.ttf",  MyArray[i],  1,  0
   scale 0.2
   translate <0,0.182,0>
   translate <0,0,.521>
   rotate y*Mydecal[i]
#declare i = i+1;
Quite ugly but... it works :)
Denis Bodor
Date: 5 May 2004 15:19:52
Message: <noe.falzonPASDEPUB-2CB45D.21182305052004@news.povray.org>
In article <40980cfa@news.povray.org>,
Hello,
your rings are very nice indeed.
I suggest to make a render with the two rings mingled, interwined. Given
the fact that the two names on the rings are *probably* those of two
people in love, this could be a nice thing.
"Je ne deteste que les bourreaux" -- Albert Camus
Date: 6 May 2004 15:49:09
Message: <409a96b5@news.povray.org>
If only obtaining *real* gold rings with your names on them were as easy
(and as cheap)! ;-)
(For that matter, if only it could be a bit easier finding someone who
suitable to have their name put on a ring... *sighs longingly*)
Andrew @ home, alone.
Date: 12 May 2004 21:21:55
Message: <40a2cdb3$1@news.povray.org>
Beautiful Job
