POV-Ray : Newsgroups : povray.binaries.images : Blind Lemon Jefferson Server Time
11 Sep 2025 12:23:21 EDT (-0400)
  Blind Lemon Jefferson (Message 1 to 10 of 15)
Subject: Blind Lemon Jefferson
Date: 29 Apr 2004 18:24:30
Message: <4091809e@news.povray.org>
This was going to be an entry for "Frozen in Time" but
I got lost in time while creating it. Anyway, it's a 1Mb
file, 1280x1024. I was trying to produce moire patterns
in this image and it seems to have worked. It's just
concentric cylinders CSG. I have to rework it because
the record grooves are not where they should be yet (sitting
on top of the vinyl). The record label was found online
somewhere.
http://www.threestrands.com/images/Blind_Lemon_Jefferson.png
=Bob=
Subject: Re: Blind Lemon Jefferson
Date: 29 Apr 2004 19:34:03
Message: <Xns94DBFB59CCD9raf256com@203.29.75.35>
was### [at] threestrandscom news:4091809e@news.povray.org
> somewhere.
I suggest 2 technical changes,
1. much stronger AA (and in addition - render image in double resolution
and then resample down using some good[1] graphics program).
2. add interpolate 4 to image map
http://www.raf256.com/3d/
Computer Graphics
Date: 29 Apr 2004 19:46:56
Message: <409193f0$1@news.povray.org>
"Rafal 'Raf256' Maj" <spa### [at] raf256com> wrote in message
news:Xns94DBFB59CCD9raf256com@203.29.75.35...
[deletions]
: I suggest 2 technical changes,
: 1. much stronger AA
Could you suggest some params? Which method do you think
I should use?
: (and in addition - render image in double resolution
: and then resample down using some good[1] graphics program).
Ok, I will try.
: 2. add interpolate 4 to image map
: Rafal Maj 'Raf256', home page - http://www.raf256.com/me/
I'm trying that now.
Thanks for the suggestions!
=Bob=
Date: 29 Apr 2004 20:23:22
Message: <Xns94DB1811F6ACraf256com@203.29.75.35>
was### [at] threestrandscom news:409193f0$1@news.povray.org
> I should use?
+a0.02 am2 +r2
and double size i.e.
+w1600 +h1200
and resize final render to 800x600
render could take some time but quality should be much better
You also might want to add a layer texture over image map so simulate some
noise/dust/etc, othrwise plain scalled iamge will look unnaturaly blurred
Computer Graphics
Date: 29 Apr 2004 22:31:55
Message: <4091ba9b@news.povray.org>
news:Xns94DB1811F6ACraf256com@203.29.75.35...
: was### [at] threestrandscom news:409193f0$1@news.povray.org
[deletions]
: You also might want to add a layer texture over image map so simulate some
: noise/dust/etc, othrwise plain scalled iamge will look unnaturaly blurred
Thanks! I will try these settings and the texture. I appreciate the help.
=Bob=
Date: 30 Apr 2004 05:23:25
Message: <40921b0d$1@news.povray.org>
I think it is much more efficient to _just_ use stronger AA than to
render the image larger and resize (that is if you don't actually need
the bigger image). Adaptive AA is basically the same as doing a larger
render but is computationally cheaper.
Severi
Date: 30 Apr 2004 07:15:37
Message: <Xns94DB86A729C5raf256com@203.29.75.35>
sev### [at] NOT_THISsibafi news:40921b0d$1@news.povray.org
No, it doesnt.
Try rendering one of most aliasing patter - black&white checke (ambietn 1)
and try if You can rid of aliasing even with very strong aa
Computer Graphics
Date: 1 May 2004 12:04:42
Message: <4093ca9a$1@news.povray.org>
> No, it doesnt.
Umm, yes I can. Just try with "+a0.0 +am2 +r5" for starters - the
checkered plane looks quite good in the horizont at least with 640x480.
Then test how much bigger you have to render without AA and resize to
get same results - 6400x4800 was (obviously) not enough . And read the
description from manual. You won't see good results if you use too big
value with +an.n.
Severi
Date: 1 May 2004 12:07:16
Message: <Xns94DCB8162FA7Craf256com@203.29.75.35>
sev### [at] NOT_THISsibafi news:4093ca9a$1@news.povray.org
> value with +an.n.
I know what +an.n means, and I didnt told to render in higher resolution.
I suggested to render in double resolution *and* with strong AA.
Computer Graphics
Date: 1 May 2004 12:13:19
Message: <4093cc9f@news.povray.org>
>>value with +an.n.
Yes, and I said that you can achieve the same easier and even more
efficiently by just using stronger AA. There is no need for
enlarging+resizing to get rid of Aliasing.
Severi
