POV-Ray : Newsgroups : povray.binaries.images : Blind Lemon Jefferson Server Time
15 Jul 2026 05:54:43 EDT (-0400)
  Blind Lemon Jefferson (Message 6 to 15 of 15)
<<< Previous 5 Messages Goto Initial 10 Messages
Subject: Re: Blind Lemon Jefferson
Date: 30 Apr 2004 05:23:25
Message: <40921b0d$1@news.povray.org>
Rafal 'Raf256' Maj wrote:
> I suggest 2 technical changes,
> 1. much stronger AA (and in addition - render image in double resolution
> and then resample down using some good[1] graphics program).
I think it is much more efficient to _just_ use stronger AA than to
render the image larger and resize (that is if you don't actually need
the bigger image). Adaptive AA is basically the same as doing a larger
render but is computationally cheaper.
Severi
Date: 30 Apr 2004 07:15:37
Message: <Xns94DB86A729C5raf256com@203.29.75.35>
sev### [at] NOT_THISsibafi news:40921b0d$1@news.povray.org
No, it doesnt.
Try rendering one of most aliasing patter - black&white checke (ambietn 1)
and try if You can rid of aliasing even with very strong aa
http://www.raf256.com/3d/
Computer Graphics
Date: 1 May 2004 12:04:42
Message: <4093ca9a$1@news.povray.org>
> No, it doesnt.
Umm, yes I can. Just try with "+a0.0 +am2 +r5" for starters - the
checkered plane looks quite good in the horizont at least with 640x480.
Then test how much bigger you have to render without AA and resize to
get same results - 6400x4800 was (obviously) not enough . And read the
description from manual. You won't see good results if you use too big
value with +an.n.
Severi
Date: 1 May 2004 12:07:16
Message: <Xns94DCB8162FA7Craf256com@203.29.75.35>
sev### [at] NOT_THISsibafi news:4093ca9a$1@news.povray.org
> value with +an.n.
I know what +an.n means, and I didnt told to render in higher resolution.
I suggested to render in double resolution *and* with strong AA.
Computer Graphics
Date: 1 May 2004 12:13:19
Message: <4093cc9f@news.povray.org>
>>value with +an.n.
Yes, and I said that you can achieve the same easier and even more
efficiently by just using stronger AA. There is no need for
enlarging+resizing to get rid of Aliasing.
Severi
Date: 1 May 2004 14:10:36
Message: <4093e81c$1@news.povray.org>
de news: 4093cc9f@news.povray.org...
Doesn't AA make the same thing?
computing more points just as if image size was bigger and interpolating
them just as an image editor when you reduce resolution?
Marc
Date: 1 May 2004 14:44:35
Message: <Xns94DCD2C209EB5raf256com@203.29.75.35>
jac### [at] wanadoofr news:4093e81c$1@news.povray.org
AA tries to do it in smart way (compute as mych extra rays - supersamples
per one final pixel as needed for this pixel), but sometimes this adaptive
method gives wrong results, therefore using it *and* double resoulution is
the fastest way to get rid of heavy aliasing.
Computer Graphics
Date: 1 May 2004 16:38:07
Message: <40940aaf$1@news.povray.org>
What do you mean by "wrong results"? Could you please post a simple example
scene (and AA settings) where AA gives those wrong results? I'd be very
interest to see it.
Severi S.
Date: 1 May 2004 16:54:50
Message: <Xns94DCE8D6CDB08raf256com@203.29.75.35>
sev### [at] NOT_THISsibafi news:40940aaf$1@news.povray.org
> example scene (and AA settings) where AA gives those wrong results?
> I'd be very interest to see it.
Hmm it seems that +am2 works exacly as resizing, *but* this behaviour is
not as it is described in docs. (+am2 results in non-adaptive antialiasing,
always maximum number of supersamples are used even if we are rendering an
empty black scene)
Computer Graphics
Date: 2 May 2004 03:32:47
Message: <4094a41f@news.povray.org>
antialiasing,
> empty black scene)
I think it does follow the docs description - if not, you should maybe
report this at p.d.i. You can't see the adaptation with +a0.0 as all
subsamples are calculated - as written in docs. With non-zero threshold the
adaptation kicks in. I think that is correct functioning. If I misunderstood
your point, please corect me.
Severi S.
