POV-Ray : Newsgroups : povray.binaries.images : Help: Brushed metal: POV Ray 3.1 > 3.5 Server Time
15 Jul 2026 08:17:50 EDT (-0400)
  Help: Brushed metal: POV Ray 3.1 > 3.5 (Message 11 to 13 of 13)
Subject: Re: Brushed metal: POV Ray 3.1 > 3.5
Date: 28 Apr 2004 22:39:08
Message: <40906acc$1@news.povray.org>
Dustin wrote:
>>DAMN, that is a cool lookin' leg!
> Thanks, I *WAS* happy with how things were turning out until I decided to
> upgrade in the middle of the model. Could you post the code to your
> 'brushed metal scene' example? Maybe I can compare and find out where I am
> going wrong...
Doh :-( When I read newsgroups, I keep a file on my desktop called
"test.pov" that is just a temporary file for code. It has long since
been overwritten :-(
There wasn't anything special outside of the original code I put up
there, though. Just a plane w/checker pattern and two lights.
Respectfully,
Dan P
http://<broken link>
Date: 29 Apr 2004 09:14:30
Message: <4090ffb6@news.povray.org>
Tek <tek### [at] evilsuperbraincom> wrote:
> In any case using pigment_pattern allows you to manipulate the pattern before
> pov samples a normal from it. One trick I use is: normal { pigment_pattern {
> granite scale f } 1 scale 1/f }, so that by varying the value of f you control
> the severity of the bumps.
  A simpler solution is to adjust the accuracy of the normal calculations.
This is done by adding the keyword 'accuracy' to your normal block
followed by a small float (try things like .01 and smaller).
  The normal calculations have changed a bit from 3.1 to 3.5 but adjusting
the accuracy will usually give you the same result as in 3.1.
Date: 29 Apr 2004 12:35:38
Message: <40912eda$1@news.povray.org>
Oh, I didn't realise I could do that! Thanks!!!
Okay ignore the second part of my message, but my solution for this particular
case should help because it's non-uniform scaling.
Tek
www.evilsuperbrain.com
"Warp" <war### [at] tagpovrayorg> wrote in message news:4090ffb6@news.povray.org...
before
control
