POV-Ray : Newsgroups : povray.binaries.images : Test your PovRay knowledge! Server Time
30 Dec 2025 09:14:25 EST (-0500)
  Test your PovRay knowledge! (Message 1 to 6 of 6)
Subject: Test your PovRay knowledge!
Date: 22 Apr 2004 12:15:56
Message: <4087efbc$1@news.povray.org>
Heres a test for you.  I've pasted extracts from two scenes into the
attached image.
I changed two things in the scene file to get the two differnt looks.
First I changed the light color from red to white.
Then I changed a single numeric value, can you guess what it was?
Clue : its a radiosity scene.
Good luck.
Download 'WhatsTheDifference.jpg' (20 KB)
Preview of image 'WhatsTheDifference.jpg'
Subject: Re: Test your PovRay knowledge!
Date: 22 Apr 2004 12:40:43
Message: <4087f58b@news.povray.org>
42.
And don't tell me I'm wrong. :-)
Date: 22 Apr 2004 14:31:12
Message: <40880f70@news.povray.org>
"Roberto Amorim" <wol### [at] hotmailcom> wrote in message
news:4087f58b@news.povray.org...
> 42.
    You're wrong! (Heh, someone had to say it...)
    It's 37.55784748595765, and I'm RIGHT!!  I think...    ;)
     ~Steve~
Date: 22 Apr 2004 18:11:52
Message: <40884328$1@news.povray.org>
Ambient?
Date: 22 Apr 2004 19:38:42
Message: <40885782$1@news.povray.org>
> attached image.
> Good luck.
Here's my guess:
You are using a crackles density pattern.
You changed the scale of the density:
scale <1, 1, 1>*n
where n is the number you changed (can be /n as well)
Wild guess, really :-)
Respectfully,
Dan P
http://<broken link>
Date: 23 Apr 2004 04:32:13
Message: <4088d48d$1@news.povray.org>
And the Answer is....
error_bound in the radiosity settings was reduced from 1.2 to 0.1
The intresting thing is that the lower the value the more accurate.  If you
look at the image on the left you can see that swathes of "radiosity" are
pasted across the front of the text, which strictly speaking is wrong
because its the back of the text that is giving off the light.  So the
higher setting of 1.2 was putting light when it should not been.
You may actually have to be a PovRay weenie like me to find that
interesting.
