POV-Ray : Newsgroups : povray.binaries.images : What is it? (55k jpeg) Server Time
21 Aug 2025 07:14:26 EDT (-0400)
  What is it? (55k jpeg) (Message 1 to 10 of 14)
Subject: What is it? (55k jpeg)
Date: 9 Apr 2004 10:34:36
Message: <4076B413.8010205@hotmail.com>
Was playing with isosurfaces yesterday and modeled this. Can you tell
what it is?
-Samuel Benge
Download 'disc.jpg' (55 KB)
Preview of image 'disc.jpg'
Subject: Re: What is it? (55k jpeg)
Date: 9 Apr 2004 10:37:32
Message: <4076b52c@news.povray.org>
"Samuel Benge" <stb### [at] hotmailcom> wrote in message
news:407### [at] hotmailcom...
> what it is?
Looks like some sort of bearing ... but that would be too obvious ... Cool
looking, though. Are you gonna post the source to this one? ;)
Date: 9 Apr 2004 10:39:02
Message: <4076b586$1@news.povray.org>
> what it is?
Square rollerbearings?
Date: 9 Apr 2004 12:17:42
Message: <4076cca6$1@news.povray.org>
> what it is?
Hmmmm.  Splined bore, appears to be rubber treaded outside diameter,
lawnmower wheel?
Greybeard.
Date: 9 Apr 2004 12:50:47
Message: <4076D418.3000505@hotmail.com>
Not a bearing.... in fact friction is the reason those bumps are on the
inside like that. They should have a more saw-toothed appearance than
they do.
I posted the source to povray.text.scene-files. I fixed it some, making
the metal texture a little more obvious and the inside groove a little
bit sharper.
-Samuel Benge
Date: 9 Apr 2004 12:55:13
Message: <4076D521.1040108@hotmail.com>
No splines were used. The source code in povray.text.scene-files shows
how it was made (a lot simpler than using splines).
> lawnmower wheel?
> Greybeard.
It does sort of resemble a lawn mower wheel.... but that isn't it. That
texture is actually a metal texture with a poor environment :(
-Samuel Benge
Date: 9 Apr 2004 15:33:13
Message: <4076fa79@news.povray.org>
hummm ,  an electric shaver blade ?
How do you manage to design the isosurface ? By reading the code I can not
imagine what it will look like ...
Great work.
Pascal.
Date: 9 Apr 2004 22:35:00
Message: <40775d54$1@news.povray.org>
> what it is?
I'd say it's some kind of ratcheting device for use where a ratchet with a
handle won't fit. By the way, when Graybeard used the word "spline", he was
using it in mechanic's terminology, not computer terminology.
Steve Shelby
Date: 9 Apr 2004 23:37:22
Message: <40776bf2$1@news.povray.org>
> what it is?
Looks cool, whatever it is. It looks like a wheel of some sort, though I can't
work out what the grid pattern is for.
Tek
www.evilsuperbrain.com
Subject: A Better Example (32k jpeg)
Date: 10 Apr 2004 00:14:38
Message: <4077744D.2000500@hotmail.com>
I wrote this earlier:
> Can you tell what it is?
Judging by the image I posted, I'd be surprised if anyone could guess
it! I was a little overzealous with my isosurface usage, and my approach
    at it was making a few things difficult to match.
Here's a more accurate representation of the object in question, this
time made with csg. It's much, much closer than the last attempt.
In real life it wouldn't look nearly this big, nor would it be this
clean (unless it was new). It's part of a *very* common object.
-Samuel Benge
Download 'fd2.jpg' (32 KB)
Preview of image 'fd2.jpg'
