POV-Ray : Newsgroups : povray.binaries.images : "What's the spider-like object on the left?" Server Time
25 Feb 2026 17:32:39 EST (-0500)
  "What's the spider-like object on the left?" (Message 1 to 10 of 10)
Subject: "What's the spider-like object on the left?"
Date: 3 Apr 2004 08:56:04
Message: <406ec274@news.povray.org>
A dragonfly! Ok, not a good dragonfly, but that's what it is. Yes, I
do need to improve a lot of things.
  Now to start on the next round... Hmm... "Great Inventions"...
<thinks>...
  ~Steve~
Download 'dragonfly.jpg' (74 KB)
Preview of image 'dragonfly.jpg'
Subject: Re: "What's the spider-like object on the left?"
Date: 3 Apr 2004 22:45:09
Message: <406f84c5$1@news.povray.org>
I like the eyes.  :)
Skip
Date: 4 Apr 2004 03:10:25
Message: <406fb4e1$1@news.povray.org>
> <thinks>...
>   ~Steve~
Cool!
Respectfully,
Dan P
http://<broken link>
Date: 6 Apr 2004 10:07:26
Message: <4072b99e$1@news.povray.org>
"St." <dot### [at] dotcom> wrote in message news:406ec274@news.povray.org...
Looks a little mechanical. Were you going for that?
I'd say a little work on the legs and you've got it nailed.
 -Shay
Date: 6 Apr 2004 16:04:15
Message: <40730d3f@news.povray.org>
"Shay" <sah### [at] simcopartscom> wrote in message
news:4072b99e$1@news.povray.org...
  No, but it looked ok in my original image, (dusk). The shape is
designed on proper shapes of dragonflies, so I was happy with that,
but at the time, I was under pressure time-wise to put something to
the left of the image. The wings have a glass texture and there are
about 120 of them to simulate flapping wings. It kind of works, but
for the life of me, I wouldn't know how to get rid of that solid bit
in the middle of the wings.
  Thanks, and you're dead right about the legs, but I know I can model
them properly.
   ~Steve~
>  -Shay
Date: 6 Apr 2004 20:14:39
Message: <407347ef$1@news.povray.org>
120 glass wings??? just what is your max_trace_level... something like
241 or more? And, how long was the render?
You may be better with only one set of wings and some contained media to
simulate the motion blur.
St. nous apporta ses lumieres ainsi en ce 2004/04/06 16:04... :
>them properly.
>   ~Steve~
Date: 6 Apr 2004 20:53:21
Message: <40735101@news.povray.org>
"Skip Talbot" <sta### [at] uiucedu> wrote in message
news:406f84c5$1@news.povray.org...
> I like the eyes.  :)
   Hey thanks, modeled using Wings. Create a deformed sphere, smooth a
few times, select 'faces', extrude 'normal' a little way out, rotate
'normal' faces left or right as required, 'smooth' the results of
that, unselect and 'smooth' the whole thing. That's how I got the
scales on my dragon.
   ~Steve~
> Skip
Date: 6 Apr 2004 21:38:11
Message: <40735b83@news.povray.org>
"Alain" <aze### [at] qwertygov> wrote in message
news:407347ef$1@news.povray.org...
> 120 glass wings???
 Yes,
  30____0____30
  30____0____30
            0
            0
> 241 or more?
 No, 2. How did you come to that conclusion?
  For this image? About 41 minutes.
media to
I'll give this a go, thank you.
~Steve~
> Alain
bit
model
> >them properly.
> >   ~Steve~
Date: 7 Apr 2004 10:15:48
Message: <40740d14$1@news.povray.org>
St. nous apporta ses lumieres ainsi en ce 2004/04/06 21:37... :
>>120 glass wings???
> Yes,
>  30____0____30
>  30____0____30
>            0
>            0
>>241 or more?
If your wings have any thickness, one going in, one going out of every
wings, plus one for every reflections, it goes up very fast. If the
wings are bicubic patches or other no thickness objects, one per wing,
plus any reflection.
>media to
>~Steve~
Date: 8 Apr 2004 15:51:47
Message: <4075ad53@news.povray.org>
news:40740d14$1@news.povray.org...
> >>120 glass wings???
> > Yes,
> >>241 or more?
every
wing,
      Ah, I see, thanks. So if I'm correct, you expected a longer time
than 41minutes based on what I said about the glass wings?
    Ok, I'm at the stage now where I've tried some sample renders with
the max_trace_level set at 35, and from what I can see, the wings look
pretty good, with a slight density in the centre of the wings, (which
I would expect). I want to render this through the night at 800x600,
a+0.0, because when I stopped the renders, they were at line 200 and
that was nearly two hours later, so I can see at least an 8 hour
render.
    My question is though: If the max_trace_level goes higher, is it
worth it for a better quality image? Would there be a significant
difference if I raised by say, 50% or more?
  BTW, I've modeled the legs to how they should be, and introduced a
little bit of yellow body colouring. It should look pretty good. To be
posted soon.  :)
     ~Steve~
> Alain
