POV-Ray : Newsgroups : povray.binaries.images : The ball, the mirror, and the checkered plane (reprise) [80K] Server Time
14 Nov 2024 06:15:25 EST (-0500)
  The ball, the mirror, and the checkered plane (reprise) [80K] (Message 1 to 8 of 8)
Subject: The ball, the mirror, and the checkered plane (reprise) [80K]
Date: 30 Mar 2004 14:41:35
Message: <4069cd6f@news.povray.org>
Some time ago I posted a small version of this image[1]. This is a bigger
one, with better lighting (I hope) and radiosity settings... There are
still some toothbrushes missing in the glass.
[1]
http://news.povray.org/povray.binaries.images/thread/%3C3fca403d@news.povray.org%3E/
light_source{9+9*x,1}camera{orthographic look_at(1-y)/4angle 30location
9/4-z*4}light_source{-9*z,1}union{box{.9-z.1+x clipped_by{plane{2+y-4*x
0}}}box{z-y-.1.1+z}box{-.1.1+x}box{.1z-.1}pigment{rgb<.8.2,1>}}//Jellby
Subject: Re: The ball, the mirror, and the checkered plane (reprise) [80K]
Date: 30 Mar 2004 14:43:13
Message: <4069cdc4@news.povray.org>
Oops... hit "send" too quickly :)
Here it is:
Download 'earth3.jpg' (77 KB)
Preview of image 'earth3.jpg'
Date: 30 Mar 2004 16:48:23
Message: <4069eb27$1@news.povray.org>
> Here it is:
toothbrush - i assume bristles are cylinders
too new ?
bend the ones at the ends of the brush section along the length of the
toothbrush, and the ones in between splayed out slightly.
have a look at a worn toothbrush maybe :-)
the reflection of the toothbrush has some of the effect i think you need
in the brush head itself
is lake victoria? really that big ?
which lake is it then?
stephen
there are too many people posting mirrored spheres, it makes it hard
thinking of a new variation :-)
someone currently stuck between povray VR and reality
Date: 30 Mar 2004 19:30:51
Message: <406a113b@news.povray.org>
Cool! Make sure you brush too hard between the fault lines or you'll get
receeding plates :-)
Respectfully,
Dan P
http://<broken link>
Date: 31 Mar 2004 03:41:47
Message: <406a844b$1@news.povray.org>
It's a very nice image, but why are your continents about twice as large
as they should be?  It seems you posted a similar globe some time back with
the same thing going on- huge continents.
Cheers!
Chip Shults
Date: 31 Mar 2004 13:53:26
Message: <406b13a5@news.povray.org>
> too new ?
Well, I decided a worn toothbrush would be too hard a model to start with,
so I jusd made a new, unused toothbrush. The bristles are rounded-tip
cylinders, but they're not parallel, they're grouped in "locks" and have
some rotation...
What do you mean? Do you think the reflection looks more worn-out than the
"real" one?
Judge yourself: http://www.yourchildlearns.com/africa_map.htm
It's the second largest freshwater lake, so I guess it's *that* big.
Date: 31 Mar 2004 14:08:48
Message: <406b1735@news.povray.org>
Among other things, Sir Charles W. Shults III write:
>     large
> with the same thing going on- huge continents.
I guess it's an effect of perspective and the way we are used to seeing the
maps...
Here are six different views of the same "ball", which show, I hope, how all
continents look equally "enlarged" when centered.
I also include a view from much further away (and a tighter angle), which
should minimize the effect of perspective.
The model is just a spherical map of an image like this one:
<http://visibleearth.nasa.gov/data/ev116/ev11612_land_ocean_ice_350.jpg>,
so there should be no weird distortion (I hope)
Download 'earthview.jpg' (51 KB) Download 'earthzoom.jpg' (14 KB)
Preview of image 'earthview.jpg'
Preview of image 'earthzoom.jpg'
Date: 31 Mar 2004 20:42:58
Message: <406b73a2$1@news.povray.org>
Point well taken- you are correct, the perspective is the problem.  I
know that spheres can easily throw it off when you get closer than about 10
radii because you do not perceive the diminishing curvature versus radius.
    In a flat image the effect is far more pronounced.
Cheers!
Chip Shults
