POV-Ray : Newsgroups : povray.binaries.images : Forest generation (or; crude packing) Server Time
12 May 2026 10:00:23 EDT (-0400)
  Forest generation (or; crude packing) (Message 11 to 14 of 14)
Subject: Re: Forest generation (or; crude packing)
Date: 31 Mar 2004 06:24:45
Message: <406aaa7d@news.povray.org>
Xplo Eristotle wrote:
> Florian Brucker wrote:
>>> Because of the random nature of the code and the need to test against
>>> every other tree when placing a new one, scenes with a lot of trees
>>> take a long time to parse;
>> A way to improve this would be something like bounding boxes
> I plan to implement something like that, yes...
> ...but not like that. If I'm reading this right, I could accomplish the
> same effect right now by using multiple "forests" stitched together,
> which isn't what I want; the "clear areas" around trees in adjacent
> cells would overlap because those trees don't get checked against each
> other.
> Instead, I would divide the area into sections and only check against
> the trees in the sections near where the new tree is trying to be
> placed.
> .. am I making any sense?
That's what I tried to say with
 >> Of course you have to add an object which overlapps a border into
 >> both cells it touches.
> I suppose if you
> really wanted to be thorough, you could have a second algorithm take
> over when the first one loses its confidence and walk a fine grid,
> testing each point on the grid to make sure something can't fit there;
> at some point this would be far more efficient than random placement
> that fails over and over again.
I think a totally random approach might be a really bad idea. I thought
more along the terms of "Take a set of cylinders which is in perfect
order. Now find some random translations which can be applied on each
cylinder so that the set looks totally random with as little
intersections as possible".
> 3D is easy. The math gets a little more complicated.
Yep
> 3D using cylinders is easy.. kinda. The math that tests for overlap gets
> even more complicated, but the algorithm basically stays the same.
Sure the tests get more complicated. While you can simply compare the
radius with the distance of two spheres, you have to take the direction
of the main-axis into account when dealing with cylinders. It would not
only be harder to implement, it would also take longer to parse :(
> 3D using cylinders under the influence of gravity which not only moves
> the cylinders but also rotates them when they touch other objects..
Yep. That would be the best result of course :)
> And you may want a sumpercomputer to run the
> simulation... ;)
Got one? Hehe.
I once started trying simulating it with SimPOV, but I couldn't get it
to work properly. Perhaps I'll try again.
Florian
Date: 31 Mar 2004 19:20:18
Message: <406b6042@news.povray.org>
cheers! i'd love to get back to it one day.
i think it says it took 21 hours to parse! (the unit is in seconds..)
bp
> Now the second one rocks! Can't see the parsing time properly, but it
> must have been quite some days :)
> Florian
Date: 1 Apr 2004 12:39:45
Message: <406c53e1@news.povray.org>
Hi bp,
I've just written a 'bins' based algorithm - it creates sorted lists of
points in a grid of bins. When you want to add a new point it looks in
the appropriate bin or bins to see if any of the current points are
within a given distance of the new point.
Like yours, this image places 6000 spheres. You don't say what the area
size or the clearance radius is for yours, but the total number of tries
is similar enough to mine that the two can be compared.
That said, mine took a little less time to parse - using official PoVWin
3.5 on my 1Ghz Athlon it was 149 seconds! :-)
The most efficient bin size for the algorithm seems to be about four
times the radius - trade off between length of list in each bin and
having to look in multiple bins more often ...
I can post the code if anyone wants to have a look.
Mike Andrews.
<message_pane>
Scene contains 6228 frame level objects; 1 infinite.
Statistics for C:\Program Files\POV-Ray for Windows
v3.5\scenes\array_fill.pov, Resolution 512 x 384
Pixels:          197120   Samples:         1055304   Smpls/Pxl: 5.35
Rays:           1055304   Saved:                 0   Max Level: 1/5
Ray->Shape Intersection          Tests       Succeeded  Percentage
Box                            1447721          880053     60.79
Cone/Cylinder                   379689           12704      3.35
Plane                          1684004         1055304     62.67
Sphere                         2021823          917211     45.37
True Type Font                   59885           30964     51.71
Bounding Box                   8636084         3431631     39.74
Light Buffer                  32225595        10986256     34.09
Vista Buffer                  33004346        19147603     58.02
Function VM calls:          445244
Calls to Noise:                  0   Calls to DNoise:             10
Shadow Ray Tests:          1350653   Succeeded:               198742
Smallest Alloc:                 25 bytes   Largest:            49840
Peak memory used:          7897321 bytes
Time For Parse:    0 hours  2 minutes  29.0 seconds (149 seconds)
Time For Trace:    0 hours  0 minutes  13.0 seconds (13 seconds)
     Total Time:    0 hours  2 minutes  42.0 seconds (162 seconds)
CPU time used: kernel 29.69 seconds, user 131.26 seconds, total 160.95
seconds
Render averaged 1221.54 PPS over 196608 pixels
POV-Ray finished
</message_pane>
Download 'array_fill.jpg' (53 KB)
Preview of image 'array_fill.jpg'
Date: 1 Apr 2004 15:55:05
Message: <406c81a9@news.povray.org>
For tree "packing" algorithm I would suggest examining this ...
http://www.gingerbooth.com/courseware/pages/demos.html
Especially ...
http://www.cbc.yale.edu/courseware/woods.html
There is a lot of documentation and source code.
Seems a lot more realistic than 2D overhead packing that
relies on only perimeter intersection checking.
