POV-Ray : Newsgroups : povray.binaries.images : Supershapes [jpg, 64k] Server Time
30 Dec 2025 19:28:48 EST (-0500)
  Supershapes [jpg, 64k] (Message 1 to 10 of 13)
Subject: Supershapes [jpg, 64k]
Date: 22 Mar 2004 09:37:38
Message: <405efa32@news.povray.org>
Hi there,
Last week, the heise newsticker had an article[1] about the
superformula. It is told that using this formula, you can describe
(almost) every thinkable shape with only a few parameters. Well, they
had a link to a site[2] where you can download a tool to play around
with, and even export a mesh to pov! I couldn't resist and now I think
I would like to share this with you.. even if only the rendering is
done in pov.
There was also someone who implemented the formula in pov[3],
dynamically generating a mesh. I didn't try that yet.
Ah yes, I was so stupid to not store the parameters to the formula for
this object, sorry ;)
Greets,
Dave V.
[1] http://www.heise.de/newsticker/meldung/45863
[2] http://www.genicap.com/
[3] http://astronomy.swin.edu.au/~pbourke/povray/supershape/
Dave "tPassive" Vogt| ruby -e "nts.to_i;a..n).to_a;a.each{
Linux  user  #225040| |x|puts x;(x*2).step(n,x){|j|a.delete j}}"
____________________|_____________________________             |
PGP Key: http://frozenbrain.com/public_key.asc    \____________/
Download 's3.jpg' (64 KB)
Preview of image 's3.jpg'
Subject: Re: Supershapes [jpg, 64k]
Date: 22 Mar 2004 13:10:46
Message: <405f2c26$1@news.povray.org>
This isosurface should handle the 2D cases of the superformula as
described in http://astronomy.swin.edu.au/~pbourke/povray/supershape/
#declare m  =  7;
#declare n1 =  5;
#declare n2 =  5;
#declare n3 =  5;
#declare a  =  1;
#declare b  =  1;
   isosurface {
     function { pow(
      pow(abs(cos(0.25*m*acos(y/sqrt(x*x+y*y))*abs(y)/y)/a),n2)  +
      pow(abs(sin(0.25*m*acos(y/sqrt(x*x+y*y))*abs(y)/y)/b),n3)
      ,1/n1) * sqrt(x*x+y*y) - 1 }
     contained_by { box { <-2,-2,-2>, <2,2,2> } }
     scale <1,1,0.001>
     pigment { Yellow }
box {<0.01,0.01,1>,<-0.01,-0.01,-1> rotate<0, 0,0> pigment {Red}  }
box {<0.01,0.01,1>,<-0.01,-0.01,-1> rotate<0,90,0> pigment {Green}}
box {<0.01,0.01,1>,<-0.01,-0.01,-1> rotate<90,0,0> pigment {Blue} }
Regards, Hans
Dave Vogt wrote:
> Hi there,
> done in pov.
> Greets,
> Dave V.
Date: 22 Mar 2004 14:09:17
Message: <405f39dd@news.povray.org>
"Dave Vogt" <spa### [at] frozenbraincom> wrote in message
news:405efa32@news.povray.org...
Hi there,
done in pov.
Greets,
Dave V.
This looks like a fun tool.
export of attached shape to pov mesh turned out to be 3228 kB
Download 'Image2.jpg' (84 KB)
Preview of image 'Image2.jpg'
Date: 22 Mar 2004 14:55:22
Message: <405f44aa@news.povray.org>
Hi there,
  Hi Dave
...Well, they
  How are you opening this tool?
done in pov.
  Ah, you'll find them again, or at least get close.
   ~Steve~
Greets,
Dave V.
Dave "tPassive" Vogt| ruby -e "n=ts.to_i;a=..n).to_a;a.each{
Date: 22 Mar 2004 16:23:43
Message: <405f595e@news.povray.org>
Unzip, run the .exe file ;)
Be sure to get the 3d Shape explorer, not the illustrator plugin.
> done in pov.
the tool supports exporting to povray.
We will see..
see you
Dave
Dave "tPassive" Vogt| ruby -e "n=gets.to_i;a=(2..n).to_a;a.each{
Date: 22 Mar 2004 19:01:45
Message: <405f7e69@news.povray.org>
> Hi there,
> done in pov.
Oy, yet another object I wouldn't want to be hit in the head with.
Very nice!
- Respectfully,
Dan
http://<broken link>
Date: 22 Mar 2004 19:23:04
Message: <405f8368$1@news.povray.org>
Thanks for the tip. Do you have to register to get the export to POV
feature? Otherwise, how to?
thanks,
d.
Hi there,
done in pov.
Greets,
Dave V.
Date: 23 Mar 2004 01:01:20
Message: <405fd2b0@news.povray.org>
> thanks,
Right click on the displayed shape anf there you go.
mat### [at] matweide
http://www.matwei.de
Date: 23 Mar 2004 01:03:45
Message: <pdb_NOSPAM-0074A3.17034423032004@news.povray.org>
Yes, although the POVRay scripts work as well but it takes longer
to experiment to find the shape you want.
   http://astronomy.swin.edu.au/~pbourke/surfaces/supershape3d
Paul Bourke
pdb_NOSPAMswin.edu.au
Date: 23 Mar 2004 01:11:25
Message: <pdb_NOSPAM-6E1744.17112423032004@news.povray.org>
The version you see there is the MSWindows one, if you want Mac OS-X
or Linux version see my www site.
   http://astronomy.swin.edu.au/~pbourke/surfaces/supershape3d/
Paul Bourke
