POV-Ray : Newsgroups : povray.binaries.images : Head with skin texture Server Time
15 Jul 2026 12:25:02 EDT (-0400)
  Head with skin texture (Message 2 to 11 of 11)
<<< Previous 1 Messages Goto Initial 10 Messages
Subject: Re: Head with skin texture
Date: 9 Mar 2004 10:06:02
Message: <404ddd5a@news.povray.org>
Gettin better everytime I see it!
Date: 9 Mar 2004 10:22:59
Message: <Xns94A7A6A6C5A83raf256com@203.29.75.35>
ssh### [at] rexnetnet news:404dcade@news.povray.org
> "C:\Documents and Settings\Administrator\My
> Documents\3D\UVhead1a.jpg"
Oh my god - how lame ;o)
But otherwise - image is greate! :)
http://www.raf256.com/3d/
Computer Graphics
Date: 9 Mar 2004 10:23:19
Message: <404de167@news.povray.org>
Thanks for Posting the texture!
Date: 9 Mar 2004 13:12:12
Message: <404e08fc@news.povray.org>
Steve Shelby wrote:
> I spent the last week working on skin texture for my head model. I used UV
> mapping and a layered texture, put together in Moray's material editor. Any
> suggestions for improvement would be appreciated.
> Steve Shelby
>    texture
>       pigment
>          image_map
>             jpeg   "C:\Documents and Settings\Administrator\My
>       finish
>          ambient 0.6
>          diffuse 0.4
>          phong 0.3
>          phong_size 2.6
>          specular 0.1
>    texture
>       pigment
>          color rgbf <1.0, 0.82, 0.6, 0.25>
>       normal
>          crackle form <-1.0, 1.0, 0.0>
>          turbulence 2.0
>          phase 0.01
>          sine_wave
>          scale  0.004
>       finish
>          ambient 0.01
>          phong 0.1
>          phong_size 60.0
>          specular 0.1
Okay I'm shooting from the hip: The more expert will correct me if I am
wrong I hope.
First, I think the finish you are getting is only the last one
specified. ( So right now you are getting nothing from the layering
except some sort of self-documenting code-construction niceness. )
Using a procedural texture to generate the image map and then applying
that with uvmapping is a good way to go.  I have seen it used before as
an automated way to establish a base pigment.  ( And you have used it
well to get a chroma effect, ie. playing warm vs cool such as red vs
green to produce a vibrant skin like tone. Excellent! )  Now you need to
add a lot of vagary with hand drawn spots, veins, lip color, etc.
Again, in most graphics editors you can maintain these additions on
separate layers,
and only let them merge in a saved off copy.  You may find as you make
your pigment more complex, that you may find a thinner base texture
works better. Not sure.  I am experimenting with all this myself.
To take the normal effect further you can add uvmapped bump_maps but
these are 'layered' via the 'average' pattern.
Similarly you can attempt to layer in bit_mapped variations on one of
the finish components: diffuse, specular, or reflection.  To do that, I
believe, you would compose textures that are identical except for the
component in question, and then mix them with the image_pattern.  So far
I am not sure how to break out all three separately, you could only
average them I think.
Date: 9 Mar 2004 19:51:31
Message: <404e6693@news.povray.org>
"Steve Shelby" <ssh### [at] rexnetnet> wrote in message
news:404dcade@news.povray.org...
Any
> Steve Shelby
I think someone is going to get a job offer from Curious Labs :-)
Date: 11 Mar 2004 02:34:05
Message: <4050166d$1@news.povray.org>
Finally found time to chase this down.
This tutorial I found to be the most dramatic
example of using handpainted colour on a pigment map.
http://www.3dm-mc.com/tutorials/maya/texturing/
Date: 11 Mar 2004 08:34:47
Message: <40506af7$1@news.povray.org>
news:404e08fc@news.povray.org...
Not true. Changes made in finish attributes on the under layer definitely
show through. I just tried it again to be sure.
> separate layers,
I did that .
I tried puting a normal noise pattern on the under layer, but when I used
transformation to scale it it scaled the entire UV map. Now I'm thinking I
put the transformation in the wrong place. I'll have to try it again.
Thank you for your comments and suggestions.
Steve Shelby
Date: 11 Mar 2004 08:43:55
Message: <40506d1b$1@news.povray.org>
I downloaded Moray and gave it a spin.  Definitely some nice features
there.  I couldn't believe you had to do a screen shot to gget a copy of
the uv template.  But I found no other solution either.  Shame, because
the uvmapping feature is very nice.  I will tune into the moray ng's but
I still find it hard to believe you must do a screen shot.  Presumably
this has to do with where the design is headed?
Date: 11 Mar 2004 11:48:45
Message: <4050986d@news.povray.org>
There is a plugin for Moray called UV Map Export, see
http://www.stmuc.com/moray/meplugin.html , which is supposed to let you
export a UV map as a .bmp file. I tried puting it into the program, but it
must be buggy, because it made Moray crash the moment I tried to open the
mesh file.
Steve Shelby
news:40506d1b$1@news.povray.org...
Date: 11 Mar 2004 19:21:48
Message: <4051029c$1@news.povray.org>
I...just...can't.....see....spending......money........for software.....
(Well, okay, I bought Poser, but that was more for the models).
- Respectfully,
Dan
http://<broken link>
