POV-Ray : Newsgroups : povray.binaries.images : wierd radiosity error Server Time
19 Apr 2026 16:25:30 EDT (-0400)
  wierd radiosity error (Message 1 to 10 of 11)
Subject: wierd radiosity error
Date: 4 Mar 2004 01:42:54
Message: <4046cfee@news.povray.org>
I've not seen this one before. I have this simple scene with some coloured
blocks lying on a white floor, with a light source in one direction and
radiosity set to Radiosity_Final from rad_def.inc. As you can see the blocks
seem to cause an echo in the inverse of their colour, in the direction of the
light (as if somehow they'd reflected negative light!?)
Anybody seen this before? Have I done something crazy?
Source code available if anyone wants it.
Tek
www.evilsuperbrain.com
Download 'tetri.jpg' (63 KB)
Preview of image 'tetri.jpg'
Subject: Re: wierd radiosity error
Date: 4 Mar 2004 03:00:15
Message: <Xns94A25B6E1D2D7raf256com@203.29.75.35>
tek### [at] evilsuperbraincom news:4046cfee@news.povray.org
> coloured blocks lying on a white floor, with a light source in one
> direction and radiosity set to Radiosity_Final from rad_def.inc. As
> you can see the blocks seem to cause an echo in the inverse of their
> colour, in the direction of the light (as if somehow they'd reflected
> negative light!?)
Could You post full code (maybe in .b.scene
http://www.raf256.com/3d/
Computer Graphics
Date: 4 Mar 2004 03:31:42
Message: <4046e96e$1@news.povray.org>
Done.
Tek
"Rafal 'Raf256' Maj" <spa### [at] raf256com> wrote in message
news:Xns94A25B6E1D2D7raf256com@203.29.75.35...
> > negative light!?)
> Rafal Maj 'Raf256', home page - http://www.raf256.com/me/
> Computer Graphics
Date: 4 Mar 2004 04:27:09
Message: <Xns94A26A29A2EC9raf256com@203.29.75.35>
tek### [at] evilsuperbraincom news:4046e96e$1@news.povray.org
> Done.
After a quick look, I would start with decreasing diffuse to 0.9 (1.0 diffuse does not
occure in nature, well at least in normal materials).
Maybe You would also try for example following radiosity settings:
#local QQ_RAD = 4; // <===== set this variable 0,1,2,3,4,5,6 or 7
#declare CFG_AMB = 0.3; // <==== set this variable for ambient when NOT using
radiosity
global_settings {
  max_trace_level 20
  assumed_gamma 1.4
  //assumed_gamma 2
  #if (QQ_RAD)
    #declare CFG_AMB = 0;
    radiosity {
      brightness 1  gray_threshold 0  max_sample 10 // <-- !
      #if (QQ_RAD=1)
        normal on  pretrace_start 1/48  pretrace_end 1/256
        count 30  error_bound 0.90  low_error_factor 0.75
        adc_bailout 1/60  recursion_limit 3 minimum_reuse 1/96  nearest_count 5
      #if (QQ_RAD=2)
        count 50  error_bound 0.80  low_error_factor 0.70
        adc_bailout 1/60  recursion_limit 4 minimum_reuse 1/96  nearest_count 6
      #if (QQ_RAD=3)
        count 80  error_bound 0.60  low_error_factor 0.80
      #if (QQ_RAD=4)
        count 100  error_bound 0.50  low_error_factor 0.80
        adc_bailout 1/64  recursion_limit 4 minimum_reuse 1/256  nearest_count 7
      #if (QQ_RAD=5)
        normal on  pretrace_start 1/64  pretrace_end 1/256
        count 200  error_bound 0.30  low_error_factor 0.80
        adc_bailout 1/64  recursion_limit 5 minimum_reuse 1/256  nearest_count 8
      #if (QQ_RAD=6)
        count 500  error_bound 0.23  low_error_factor 0.85
        adc_bailout 1/75  recursion_limit 6 minimum_reuse 1/256  nearest_count 8
      #if (QQ_RAD=7)
        count 1000  error_bound 0.17  low_error_factor 0.80
        adc_bailout 1/80  recursion_limit 7 minimum_reuse 1/256  nearest_count 10
default {
  finish { ambient CFG_AMB }
  pigment { rgb 1 }
Computer Graphics
Date: 4 Mar 2004 04:33:39
Message: <4046f7f3$1@news.povray.org>
That's very interesting, and you make a good point about diffuse, but it doesn't
explain the artefacts!
I'm not interested in getting round the problem, that's easy! I want to know why
it happens.
Tek
news:Xns94A26A29A2EC9raf256com@203.29.75.35...
> > Done.
does not occure in nature, well at least in normal materials).
radiosity
> global_settings {
>   max_trace_level 20
>   assumed_gamma 1.4
>   //assumed_gamma 2
>   #if (QQ_RAD)
>     radiosity {
>       #if (QQ_RAD=1)
5
>       #end
>       #if (QQ_RAD=2)
6
>       #end
>       #if (QQ_RAD=3)
6
>       #end
>       #if (QQ_RAD=4)
7
>       #end
>       #if (QQ_RAD=5)
8
>       #end
>       #if (QQ_RAD=6)
8
>       #end
>       #if (QQ_RAD=7)
10
>       #end
>   #end
> default {
>   pigment { rgb 1 }
> Computer Graphics
Date: 4 Mar 2004 13:26:03
Message: <404774bb@news.povray.org>
Crazy man, craaaaazy.  *thumbs up*
Date: 4 Mar 2004 23:40:48
Message: <404804d0$1@news.povray.org>
news:4046f7f3$1@news.povray.org...
doesn't
know why
> it happens.
I'm interested in some learnin' on the whole Radiosity thing too. This is
the extent of my Radiosity knowledge:
* I go to the Special Effects menu.
* I insert the Radiosity effect.
* I boggle at most of the parameters.
That... that just isn't right. :-)
Date: 5 Mar 2004 03:57:25
Message: <404840f5$1@news.povray.org>
Well I use the much simpler option:
#include "rad_def.inc"
global_settings{
    radiosity{ Rad_Settings(Radiosity_Fast,on,on) }
No nasty parameters there! You just decide what quality you want and off you go
Tek
"Dan P" <dan### [at] yahoocom> wrote in message
news:404804d0$1@news.povray.org...
> "Tek" <tek### [at] evilsuperbraincom> wrote in message
> doesn't
> know why
> > it happens.
Date: 5 Mar 2004 17:23:10
Message: <4048fdce$1@news.povray.org>
news:404840f5$1@news.povray.org...
is
> global_settings{
you go
(I don't have POV here) -- is that a standard include? If so, awesome!
Date: 5 Mar 2004 23:42:13
Message: <404956a5$1@news.povray.org>
news:4048fdce$1@news.povray.org...
Yup, it's one of the standard ones. It is truly awesome!
Back in the days of megapov I struggled to get radiosity set the way I wanted
it, and now these presets are higher quality and faster than the settings I used
to use!
Tek
