POV-Ray : Newsgroups : povray.binaries.images : wierd radiosity error Server Time
29 Mar 2026 06:50:23 EDT (-0400)
  wierd radiosity error (Message 2 to 11 of 11)
<<< Previous 1 Messages Goto Initial 10 Messages
Subject: Re: wierd radiosity error
Date: 4 Mar 2004 03:00:15
Message: <Xns94A25B6E1D2D7raf256com@203.29.75.35>
tek### [at] evilsuperbraincom news:4046cfee@news.povray.org
> I've not seen this one before. I have this simple scene with some
> coloured blocks lying on a white floor, with a light source in one
> direction and radiosity set to Radiosity_Final from rad_def.inc. As
> you can see the blocks seem to cause an echo in the inverse of their
> colour, in the direction of the light (as if somehow they'd reflected
> negative light!?)
Could You post full code (maybe in .b.scene
http://www.raf256.com/3d/
Computer Graphics
Date: 4 Mar 2004 03:31:42
Message: <4046e96e$1@news.povray.org>
Done.
Tek
www.evilsuperbrain.com
"Rafal 'Raf256' Maj" <spa### [at] raf256com> wrote in message
news:Xns94A25B6E1D2D7raf256com@203.29.75.35...
> > negative light!?)
> Rafal Maj 'Raf256', home page - http://www.raf256.com/me/
> Computer Graphics
Date: 4 Mar 2004 04:27:09
Message: <Xns94A26A29A2EC9raf256com@203.29.75.35>
tek### [at] evilsuperbraincom news:4046e96e$1@news.povray.org
> Done.
After a quick look, I would start with decreasing diffuse to 0.9 (1.0 diffuse does not
occure in nature, well at least in normal materials).
Maybe You would also try for example following radiosity settings:
#local QQ_RAD = 4; // <===== set this variable 0,1,2,3,4,5,6 or 7
#declare CFG_AMB = 0.3; // <==== set this variable for ambient when NOT using
radiosity
global_settings {
  max_trace_level 20
  assumed_gamma 1.4
  //assumed_gamma 2
  #if (QQ_RAD)
    #declare CFG_AMB = 0;
    radiosity {
      brightness 1  gray_threshold 0  max_sample 10 // <-- !
      #if (QQ_RAD=1)
        normal on  pretrace_start 1/48  pretrace_end 1/256
        count 30  error_bound 0.90  low_error_factor 0.75
        adc_bailout 1/60  recursion_limit 3 minimum_reuse 1/96  nearest_count 5
      #if (QQ_RAD=2)
        count 50  error_bound 0.80  low_error_factor 0.70
        adc_bailout 1/60  recursion_limit 4 minimum_reuse 1/96  nearest_count 6
      #if (QQ_RAD=3)
        count 80  error_bound 0.60  low_error_factor 0.80
      #if (QQ_RAD=4)
        count 100  error_bound 0.50  low_error_factor 0.80
        adc_bailout 1/64  recursion_limit 4 minimum_reuse 1/256  nearest_count 7
      #if (QQ_RAD=5)
        normal on  pretrace_start 1/64  pretrace_end 1/256
        count 200  error_bound 0.30  low_error_factor 0.80
        adc_bailout 1/64  recursion_limit 5 minimum_reuse 1/256  nearest_count 8
      #if (QQ_RAD=6)
        count 500  error_bound 0.23  low_error_factor 0.85
        adc_bailout 1/75  recursion_limit 6 minimum_reuse 1/256  nearest_count 8
      #if (QQ_RAD=7)
        count 1000  error_bound 0.17  low_error_factor 0.80
        adc_bailout 1/80  recursion_limit 7 minimum_reuse 1/256  nearest_count 10
default {
  finish { ambient CFG_AMB }
  pigment { rgb 1 }
Computer Graphics
Date: 4 Mar 2004 04:33:39
Message: <4046f7f3$1@news.povray.org>
That's very interesting, and you make a good point about diffuse, but it doesn't
explain the artefacts!
I'm not interested in getting round the problem, that's easy! I want to know why
it happens.
Tek
news:Xns94A26A29A2EC9raf256com@203.29.75.35...
> > Done.
does not occure in nature, well at least in normal materials).
radiosity
> global_settings {
>   max_trace_level 20
>   assumed_gamma 1.4
>   //assumed_gamma 2
>   #if (QQ_RAD)
>     radiosity {
>       #if (QQ_RAD=1)
5
>       #end
>       #if (QQ_RAD=2)
6
>       #end
>       #if (QQ_RAD=3)
6
>       #end
>       #if (QQ_RAD=4)
7
>       #end
>       #if (QQ_RAD=5)
8
>       #end
>       #if (QQ_RAD=6)
8
>       #end
>       #if (QQ_RAD=7)
10
>       #end
>   #end
> default {
>   pigment { rgb 1 }
> Computer Graphics
Date: 4 Mar 2004 13:26:03
Message: <404774bb@news.povray.org>
Tek wrote:
> Anybody seen this before? Have I done something crazy?
Crazy man, craaaaazy.  *thumbs up*
Date: 4 Mar 2004 23:40:48
Message: <404804d0$1@news.povray.org>
news:4046f7f3$1@news.povray.org...
doesn't
know why
> it happens.
I'm interested in some learnin' on the whole Radiosity thing too. This is
the extent of my Radiosity knowledge:
* I go to the Special Effects menu.
* I insert the Radiosity effect.
* I boggle at most of the parameters.
That... that just isn't right. :-)
Date: 5 Mar 2004 03:57:25
Message: <404840f5$1@news.povray.org>
Well I use the much simpler option:
#include "rad_def.inc"
global_settings{
    radiosity{ Rad_Settings(Radiosity_Fast,on,on) }
No nasty parameters there! You just decide what quality you want and off you go
Tek
"Dan P" <dan### [at] yahoocom> wrote in message
news:404804d0$1@news.povray.org...
> "Tek" <tek### [at] evilsuperbraincom> wrote in message
> doesn't
> know why
> > it happens.
Date: 5 Mar 2004 17:23:10
Message: <4048fdce$1@news.povray.org>
news:404840f5$1@news.povray.org...
is
> global_settings{
you go
(I don't have POV here) -- is that a standard include? If so, awesome!
Date: 5 Mar 2004 23:42:13
Message: <404956a5$1@news.povray.org>
news:4048fdce$1@news.povray.org...
Yup, it's one of the standard ones. It is truly awesome!
Back in the days of megapov I struggled to get radiosity set the way I wanted
it, and now these presets are higher quality and faster than the settings I used
to use!
Tek
Date: 6 Mar 2004 18:47:19
Message: <404a6307$1@news.povray.org>
news:404956a5$1@news.povray.org...
wanted
I used
> to use!
Exssssssssselent (caging fingers like Monty Burns).
