POV-Ray : Newsgroups : povray.binaries.images : World on a Donut Server Time
1 Jan 2026 04:20:50 EST (-0500)
  World on a Donut (Message 1 to 10 of 16)
Subject: World on a Donut
Date: 2 Mar 2004 00:19:15
Message: <4044194e@news.povray.org>
[Note: Superseding the original article, actually attaching the image this
time... Hope this works...]
This was a '1 hour challenge', in which I try to get a particular effect
that I've never done in 60-90 minutes, and see what happens. Usually a few
vague blobs. This one I REALLY like though. This was inspired by an image
by Tek that showed a planet on a non-sphericla shape. I just had to give it
a try. I used a torus for the shape (VERY geologically accurate...)
I'm stoked about how it came out. With more time it can definatly be
improved, and there are a few glaring omissions (Starfield..., real
atmosphere.), but it looks pretty real to me, and for ~70 minutes of
coding...
Basically the scene consists of two concentric torii lit by a parallel
light. One torus is the "planet", the second has a slightly larger minor
radius, and is used to layer the clouds on. I'm pretty happy with the
clouds, REALLY happy with the oceans, and pretty happy about the
continents. If I assume this is planet-like, the geology is pretty lousy,
as it's the same at all latitudes. This, however is a TORUS, no way this
thing could even hold water on the inner surface, and probably not the
outer surface either...
I'm particually proud of the just-noticable 'wrinkling' of the oceans, that
is also evident in space photos of earth.
Source and render attached... I may render a few close to the surface
tomorrow...
Code:
#include "stars.inc"
default{finish{ambient 0}}
sky_sphere{
camera{location <.5,.5,2> look_at <0,0,1>}
#declare sea_tex1 = texture{pigment{rgb <0,0,.3>
} normal{agate .05 scale .01} finish{reflection .1 specular .5}}
#declare sea_tex2 = texture{pigment{rgb <0,.4,.6>}
#declare land_tex0 = texture{
#declare land_tex1 = texture{
#declare land_tex2 = texture{
#declare land_tex3 = texture{
light_source{<1,.3,3>,1 parallel point_at <0,0,0>}
torus{1,.3
torus{1,.301
<1,1,1,1>][0.42 rgbf <1,1,1,1>][0.5 rgbf <.8,.8,.8,.5>][0.80 rgbf
<1,1,1,.3>][1.0 rgbf <1,1,1,0>]}}
Download 'torusworld1.jpg' (100 KB)
Preview of image 'torusworld1.jpg'
Subject: Re: World on a Donut
Date: 2 Mar 2004 01:13:45
Message: <Xns94A049753C370raf256com@203.29.75.35>
tyl### [at] ml1net news:4044194e@news.povray.org
> coding...
Yeap, nice effect :)
> tomorrow...
Just btw, code after copy-paste to pov generates:
Parse Error: Illegal character in input file, value is a0.
It seems that every indent in Yours code start with an 0xa0 charter,
strange.
http://www.raf256.com/3d/
Computer Graphics
Date: 2 Mar 2004 02:16:50
Message: <404434e2$1@news.povray.org>
"Tyler Eaves" <tyl### [at] ml1net> wrote in message news:4044194e@news.povray.org...
I do that sometimes, it's a very good way to refine your pov skills. I also have
the rule that I have to start with a completely blank scene file and may only
use the standard includes :)
> Usually a few
That's very impressive for one hour! It took me a lot longer than that to get my
planet texture looking that nice.
Just out of curiosity, which image inspired it? Because it's very similar to
this one:
http://www.evilsuperbrain.com/gallery/showimage.php?name=finished/links_poster
Tek
Date: 2 Mar 2004 02:18:04
Message: <4044352c$1@news.povray.org>
> strange.
You aren't using Windows, are you?  I was able to steal his code just fine.
Date: 2 Mar 2004 02:25:28
Message: <Xns94A0559DF24F3raf256com@203.29.75.35>
gil### [at] purdueedu news:4044352c$1@news.povray.org
> fine.
Yes, I'm still using this shitty system, but hopefully not for long :)
Computer Graphics
Date: 2 Mar 2004 08:38:58
Message: <pan.2004.03.02.13.40.08.685151@NOSPAMml1.net>
> this one:
Yup, that's the one ;)
Date: 2 Mar 2004 09:01:40
Message: <404493c4$1@news.povray.org>
Nice!
Have you ever tried "World in a Tube".  In a book called "EON", in contained
a huge endless Tube with the world wrapped around the Inside along in
length, and a shimmering (banded) light source running along the centre of
the tube.
It would be an intresting excercise.
Date: 2 Mar 2004 10:15:39
Message: <4044a51b@news.povray.org>
> Code:        [..]
Beautiful !!
I've played a bit with your code, especially the clouds, because I think
they are to dark. Why do you use filter instead of transmit. I've changed it
to transmit and you get better lightning beneath the outer torus.
To make it more white I've changed the intensity of  both the light_ source
aswell as the white of the clouds.
Added some stars too.
I've attached the adapted file.
Greetings,
Jaap Frank
Download 'TorusWorld.pov.txt' (5 KB) Download 'TorusWorld.jpg' (209 KB)
Preview of image 'TorusWorld.jpg'
Date: 2 Mar 2004 11:46:42
Message: <4044ba72@news.povray.org>
Felbrigg wrote:
> Nice!
> the tube.
wasn't there some book called "rendezvous with rama" or something with a
space-ship just like you described? i don't recall the author's name...
	Marc
Date: 2 Mar 2004 12:00:55
Message: <pan.2004.03.02.17.02.05.632942@NOSPAMml1.net>
>> Code:        [..]
> Beautiful !!
> Greetings,
> Jaap Frank
Wow, the clouds do look a lot nicer. I didn't have much time to tweak 'em,
as I spent most of the hour on the land.
