POV-Ray : Newsgroups : povray.binaries.images : Lame Short Code Contest attempt Server Time
15 Jul 2026 15:24:09 EDT (-0400)
  Lame Short Code Contest attempt (Message 8 to 17 of 27)
<<< Previous 7 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Lame Short Code Contest attempt
Date: 22 Feb 2004 22:58:03
Message: <40397a4b@news.povray.org>
news:40389ae0@news.povray.org...
>   After seeing the city entry I got so depressed I don't think I will be
> making any attempt at competing... :)
>   Anyways, here's a lame attempt I was playing with. I will not send this
> one because it's so simple, so I'll just post it here and give my
> congratulations to the first who figures out how it is done (in 256
bytes).
> Extra bonus to anyone who posts a code creating a similar image (as
> similar as possible, of course). :)
I think this could be a great entry. I'm guessing you did it something like
this:
#include "functions.inc"
plane
 z, 1
 pigment
  mandel 1000
  interior 1, 1
  translate <-0.4021, 0.2, 0>
  scale 100
 finish
  ambient 1
Date: 22 Feb 2004 23:04:49
Message: <40397be1$1@news.povray.org>
"Dan P" <dan### [at] yahoocom> wrote in message
news:40397a4b@news.povray.org...
this
> bytes).
like
> this:
Whoops, I didn't need the functions.inc!
Here is one at 96 chars:
plane{z,1 pigment{mandel 1000 interior 1,1 translate<-0.4021,0.2,0>scale
100}finish{ambient 1}}
Date: 22 Feb 2004 23:23:15
Message: <40398033$1@news.povray.org>
news:40397be1$1@news.povray.org...
Here's another fun way to use mandel:
#declare f=function{pigment{mandel 1000 interior 1,1 translate -0.17
color_map{[0 rgb 0][1 rgb 1]}scale 2}}light_source{0.2*y rgb
1}height_field{function 999,999{f(x,y,z).gray*0.1}pigment{rgb
1}translate -0.5}camera{rotate 45*x translate -0.7*z}
246 bytes :-)
Date: 23 Feb 2004 04:48:03
Message: <ogtog1-qs4.ln1@triton.imagico.de>
> 246 bytes :-)
You don't honestly want to sell this as a shortest version, do you?  I
mean there are dozens of chars to save here.
Last updated 11 Jan. 2004 _____./\/^>_*_<^\/\.______
Date: 23 Feb 2004 09:21:12
Message: <403a0c58$1@news.povray.org>
news:ogt### [at] tritonimagicode...
> > 246 bytes :-)
> Christoph
I think dere oughta be a rule -- "bring it" :-)
I want to learn how to shave more chars... let's see the shorter version!
Date: 23 Feb 2004 10:02:41
Message: <403A15D8.8020907@hotmail.com>
Dan P wrote:
> "Christoph Hormann" <chr### [at] gmxde> wrote in message
>>>246 bytes :-)
>>Christoph
my hints:
- you don't need the zeros before the dot '-0.7' == '-.7'
- you don't need a space between a number and a keyword or variable
  '1000 interior' == '1000interior'
- you can thus also replace '45*x translate' by 'x*45translate'
- you do not need a space before a '-'
   'translate -0.7' == 'translate-.7'
- 1000 or 999 do not make much difference (except one char)
that gives:
#declare f=function{pigment{mandel 999interior 1,1translate-.17
color_map{[0rgb 0][1rgb 1]}scale 2}}light_source{y*.2rgb
1}height_field{function 999,999{f(x,y,z).gray*.1}pigment{rgb
1}translate-.5}camera{rotate x*45translate-.7*z}
which saves 14 bytes in total, not realy the dozens Christoph talks
about, so there is probably more.
    Andrel
Date: 23 Feb 2004 10:19:25
Message: <403a19fd$1@news.povray.org>
"andrel" <a_l### [at] hotmailcom> wrote in message
news:403### [at] hotmailcom...
> my hints:
> that gives:
Sweet! I wish I knew about the numbers thing before I put my entry in. I
think I might also be able to lose [0rgb 0] as well to get:
1,1translate-.17color_map{[1rgb 1]}scale
2}}light_source{y*.2rgb1}height_field{function
999,999{f(x,y,z).gray*.1}pigment{rgb1}translate-.5}camera{rotate
x*45translate-.7*z}
I don't have pov at work, though; does the above compile?
Date: 23 Feb 2004 10:36:09
Message: <15jpg1-qua.ln1@triton.imagico.de>
There is - but hey, this is a *contest*... ;-)
Date: 23 Feb 2004 10:41:24
Message: <403A1EEB.8070207@hotmail.com>
> x*45translate-.7*z}
After you replace 'rgb1' by 'rgb 1' it does.
It is not the same image though ;)
You can gain another char by using '.red' for '.gray'
(I do not know why. I never had time to investigate
much about function :( I mostly do meshes and patches.)
Date: 23 Feb 2004 10:46:44
Message: <p08k3092tnmacsnqc1lnfr997750g0jlbi@4ax.com>
On Mon, 23 Feb 2004 16:34:25 +0100, Christoph Hormann <chr### [at] gmxde> >
... and source of my irritation. Now if a day could heve the same number of
hours as short code chars... I hope I will find some hours for participate.
ABX
