POV-Ray : Newsgroups : povray.binaries.images : Lame Short Code Contest attempt Server Time
15 Jul 2026 15:25:44 EDT (-0400)
  Lame Short Code Contest attempt (Message 21 to 27 of 27)
Subject: Re: Lame Short Code Contest attempt
Date: 24 Feb 2004 01:12:08
Message: <403aeb38$1@news.povray.org>
"Christopher James Huff" <cja### [at] earthlinknet> wrote in message
news:cjameshuff-D54816.11362823022004@news.povray.org...
> In article <403### [at] hotmailcom>,
>  andrel <a_l### [at] hotmailcom> wrote:
> > #declare f=function{pigment{mandel 999interior 1,1translate-.17
> > color_map{[0rgb 0][1rgb 1]}scale 2}}light_source{y*.2rgb
> > 1}height_field{function 999,999{f(x,y,z).gray*.1}pigment{rgb
> > 1}translate-.5}camera{rotate x*45translate-.7*z}
> Replace ".gray" with ".hf" to save two characters.
You can just use .x instead, since the rgb components are the same.
Somebody's not been reading my source closely enough ;)
Tek
www.evilsuperbrain.com
Date: 24 Feb 2004 01:28:31
Message: <403aef0f@news.povray.org>
// +SP8 +EP8 +A0.1 +AM2 +R2 -FN
#declare f=function{pigment{mandel 1e3interior 1,1translate-.2
color_map{[0rgb 0][1rgb 1]}scale 2}}light_source{<0,.7.4>rgb
1}height_field{function 999,999{f(x,y,z).hf/9}pigment{rgb
1}translate.7*z-.5rotate-x*45}
// 19 additional characters saved: 63+61+58+31=210;
// (not counting newlines -- as one long line: 212 characters
// Sufficiently similar?
//    Sputnik
Date: 24 Feb 2004 10:09:48
Message: <403b693c@news.povray.org>
news:403aef0f@news.povray.org...
> //    Sputnik
Wow, I'm fighting the temptation to redo my short-code entry and cut it in
half :-)
Date: 25 Feb 2004 23:02:27
Message: <403d6fd3@news.povray.org>
// >>AAARGH!<<
// I had counted the characters by looking at the column
// indicator in the POV-Ray editor's status line with the
// edit cursor at the end of the line, but this number
// is [number of characters in line] + 1 !
// Here is my new version, now 62+57+54+30 = 203 characters
// long (204 if single line) -- an improvement of 10 over my
// last post: 4 due to counting correctly, 6 really saved.
//   Sputnik
//       1         2         3         4         5   5  5  6 6
//345678901234567890123456789012345678901234567890123456789012
color_map{[0rgb 0][1rgb.1]}scale 2}}light_source{<0,.7.4>
1}height_field{function 999,999{f(x,y,z).x}pigment{rgb
Date: 2 Mar 2004 05:49:29
Message: <40446903.2040508@informatik.uni-freiburg.de>
>   Anyways, here's a lame attempt I was playing with. I will not send this
> one because it's so simple, so I'll just post it here and give my
> congratulations to the first who figures out how it is done (in 256 bytes).
> Extra bonus to anyone who posts a code creating a similar image (as
> similar as possible, of course). :)
Seeing that the challenge is still open, here is my attempt. Unfortunatlely
I am not adept enough with internal adresses to find out your coordintes by
just looking at your picture.
box{.4z-.7pigment{rgbt 1}interior{media{emission 9density{mandel
150color_map{[.1rgb z][.2rgb 0][.3rgb x][.4rgb 1-z][1rgb
1]}}translate<1.258.359.0>scale 200}}hollow}
merge{#local i=-11;#while(i<11)#local
i=i+.1;sphere{<i*(i*i*(.05-i*i*(4e-7*i*i+3e-4))-3)10*sin(i)30>.5}#end
pigment{rgbt 1}interior{media{emission x}}hollow}//  Mark Weyer
Date: 4 Mar 2004 12:37:01
Message: <40476B8F.90803@informatik.uni-freiburg.de>
And here is the picture
Download 'test.jpg' (27 KB)
Preview of image 'test.jpg'
Date: 6 Apr 2004 13:08:48
Message: <ckk570las0fdiiud5imq3gji8b5984eobg@4ax.com>
Someone supposed using mandle as a media density pattern. My guess is
this could also be done by averaging the same mandel pattern at
increasing zoom levels. I've used this technique for motion blur and
radial blur (both zoom and spin type).
Peter Popov ICQ : 15002700
