POV-Ray : Newsgroups : povray.binaries.images : City SSC WIP 2 Server Time
20 Jun 2026 23:17:25 EDT (-0400)
  City SSC WIP 2 (Message 1 to 10 of 19)
Subject: City SSC WIP 2
Date: 15 Feb 2004 22:06:41
Message: <403033c1@news.povray.org>
After thee feedback from my last posting, I've decided to enter the city image
in the short code contest. I've managed to find enough room in the 256 bytes of
source to add some fog and a hill in the distance, and to completely change the
colours, I'm really pleased with the result :)
This is probably the final version. What do you think of it?
Oh, and just because I can, here's the full source:
#macro C()function{pigment{crackle#end#local A=C()solid}}#local
B=C()}}isosurface{function{max(2+y*9-A(x*9,0,z*9).x*4,.2-B(x*9,0
,z*9).x)/99}finish{reflection{0,1}}}fog{rgb 1+y/5+z/3distance.7
fog_type 2fog_alt.1}sky_sphere{pigment{agate}}sphere{9*(.6-y),5}
Tek
www.evilsuperbrain.com
Download 'city2.jpg' (25 KB)
Preview of image 'city2.jpg'
Subject: Re: City SSC WIP 2
Date: 15 Feb 2004 23:27:44
Message: <403046c0$1@news.povray.org>
I have a new wallpaper now. Thanks!
Date: 16 Feb 2004 00:15:28
Message: <403051f0$1@news.povray.org>
news:403033c1@news.povray.org...
bytes of
change the
What do I think, Tek? I think you kicked my entry's ass. :-)
Great job!
Date: 16 Feb 2004 03:22:52
Message: <40307ddc$1@news.povray.org>
"Dan P" <dan### [at] yahoocom> wrote in message
news:403051f0$1@news.povray.org...
> Great job!
:D
Well in my defence I mostly fluked it!
Tek
Date: 16 Feb 2004 08:10:53
Message: <4030c15d@news.povray.org>
Fantastic, specially considering how short the code is.
I don't want to sound picky, but there are some "jaggies" here and there...
is that because of lack of isosurface anti-aliasing?
Regards...
> Tek
Date: 16 Feb 2004 10:12:20
Message: <4030ddd4$1@news.povray.org>
news:40307ddc$1@news.povray.org...
> > Great job!
> :D
Such humility :-) I looked at your isosurface code and picked up my jaw some
minutes later. If I were a bettin' man, I'd bet you taking home the entire
prize for both artistic and technical. Nice job! :-)
Date: 16 Feb 2004 23:08:30
Message: <403193be$1@news.povray.org>
news:4030ddd4$1@news.povray.org...
Well the technique for that isosurface was something that took me along time to
figure out, quite some time ago. All I've done here is adapt it to a tiny amount
of code :)
Tek
Date: 16 Feb 2004 23:16:21
Message: <40319595$1@news.povray.org>
"Roberto A." <wol### [at] hot-mailcom> wrote in message
news:4030c15d@news.povray.org...
Yeah, it's kind of an aliasing issue...
Basically there's 3 settings that control the appearance of an isosurface
definition: contained_by{}, max_gradient, and accuracy.
Obviously in my 256 bytes of source I don't have room for any of these, so I use
pov's defaults then work round the problems:
- the default contained_by shape is the unit sphere, so I scale my function down
to fit that (that's why the function has x*9,y*9,z*9)
- the default max_gradient is 1, so I adjust the range of values my function
will produce to fit that (by dividing the whole function by 99)
- the default accuracy is 0.001, i.e. 1/1000th the size of the default container
shape. There is nothing I can do to fake this, hence you get those artefacts.
I still have 1 byte spare, so if you can think of a way to adjust the "accuracy"
setting using just 1 byte I'd be most appreciative ;)
Tek
Date: 17 Feb 2004 10:33:47
Message: <4032345b$1@news.povray.org>
Please use the proper newsgroup for posting source ( ;-) )  Some of us
have bandwidth concerns. . . .
Dave Matthews
BTW Thanks for posting it.  As I decipher, maybe I'll figure out some
tricks for reducing my own code.
Hmm.  How do you know that, for example, some end "}" are unnecessary?
(I assume that, as usual, I'm missing something in the manual.)
Date: 17 Feb 2004 19:09:48
Message: <cjameshuff-881346.19102217022004@news.povray.org>
In article <4032345b$1@news.povray.org>,
All { braces must have a matching } brace. This scene just puts the
opening braces in the macro, and the closing braces after the calls to
that macro. Cleanly indented, the code's a lot easier to understand:
#macro C()
    function {
        pigment {crackle
#local A = C() solid}}
#local B = C() }}
This is equivalent to:
#local A = function {pigment {crackle solid}}
#local B = function {pigment {crackle}}
http://tag.povray.org/
