POV-Ray : Newsgroups : povray.binaries.images : Spilled Liquid Server Time
12 May 2026 12:16:37 EDT (-0400)
  Spilled Liquid (Message 1 to 3 of 3)
Subject: Spilled Liquid
Date: 4 Feb 2004 11:25:12
Message: <40211ce8@news.povray.org>
I saw a post where the poster was wandering how to do a spilled liquid after
failing with blobs.. So I've knocked up this test scene using a couple of
splines for the liquid which might help them.
I'd like to invite suggestions for improving the lighting and look of the
water, or better still change it from water to semi tranparent coffee.  I'd
like to get this simple scene improooooved ( that is to say realistic ).
Thanks
Heres the code if you want to have a stab at it...
#include "textures.inc"
#include "shapes.inc"
#declare SnakeWood =
texture {  /* Bottom wood-grain layer */
        wood
        turbulence 0.05
        color_map {
            [0.00 rgb <0.58, 0.45, 0.23>]
            [0.34 rgb <0.65, 0.45, 0.25>]
            [0.40 rgb <0.33, 0.23, 0.13>]
            [0.47 rgb <0.60, 0.40, 0.20>]
            [1.00 rgb <0.25, 0.15, 0.05>]
    finish {
        crand 0.02
        //ambient 0.32
        diffuse 0.63
        phong 0.2
        phong_size 10
    normal { bumps 0.05 }
texture {     /* top layer, adds small dark spots */
        bozo
        color_map {
            [0.0 rgbt <1.00, 1.00, 1.00, 1.00>]
            [0.8 rgbt <1.00, 0.90, 0.80, 0.80>]
            [1.0 rgbt <0.30, 0.20, 0.10, 0.40>]
    scale 0.25
light_source {<-20, 20, 0> color White area_light  <5, 0, 0>, <0, 0, 5>, 11,
11 adaptive 1 jitter photons { refraction on reflection on } }
camera  {
        location <0,10,-25> look_at <0,0,0>
background { Black }//color <0.25,0.35,0.80> }
box     {
        <-1,-1,-1>,
        <1,1,1>
                pigment { Red }
        scale <2,2,2>
        rotate <0,-15,0>
        translate <2,1,10>
box     {
        <-1,-1,-1>,
        <1,1,1>
                pigment { Red }
        scale <2,2,2>
        rotate <0,-16,0>
        translate <2,1,-9>
cylinder{
        <-1,-1,-1>,
        <1,1,1>,
        1
                pigment { White*2 }
        scale <1,5,1>
        translate <-7,3,0>
plane   { <0, 1, 0>, -0.001
        texture { SnakeWood }//pigment { checker pigment{Red},
pigment{White} } scale <10,10,10> rotate <0,43,0>}
#declare Point1 = <-10,1,10>;
#declare Point2 = <-10,1,0>;
#declare Point3 = <-10,1,-10>;
#declare Point4 = <0,1,-10>;
#declare Point5 = <10,1,-10>;
#declare Point6 = <15,1,2>;     //<10,1,0>;
#declare Point7 = <10,1,2>;    //<10,1,10>;
#declare Point8 = <0,1,10>;
#declare Point9 = <-14,1,12>; //<-10,1,10>;
#declare Point10 = <-10,1,0>;
#declare Point11 = <-10,1,-10>;
merge {
// outside of the puddle
sphere_sweep {
        cubic_spline
        11,
        Point1,1
        Point2,1
        Point3,1
        Point4,1
        Point5,1
        Point6,1
        Point7,1
        Point8,1
        Point9,1
        Point10,1
        Point11,1
// inside of the puddle
prism {
    cubic_spline
    0, // sweep the following shape from here ...
    2, // ... up through here
    11, // the number of points making up the shape ...
        <Point1.x,Point1.z>,
        <Point2.x,Point2.z>,
        <Point3.x,Point3.z>,
        <Point4.x,Point4.z>,
        <Point5.x,Point5.z>,
        <Point6.x,Point6.z>,
        <Point7.x,Point7.z>,
        <Point8.x,Point8.z>,
        <Point9.x,Point9.z>,
        <Point10.x,Point10.z>,
        <Point11.x,Point11.z>
        hollow
                        Clear // rgbt <0.858824,0.576471,0.439216>
                finish  {
                        reflection { 0.1,0.8 }
        interior        {
                        ior Water_Ior
        translate <0,-1.5,0>
Download 'Puddle.jpg' (33 KB)
Preview of image 'Puddle.jpg'
Subject: Re: Spilled Liquid
Date: 4 Feb 2004 16:44:43
Message: <402167cb$1@news.povray.org>
Some suggestions:
- Usually, materials and especially wood tend to be darker where wet.
- you could improve your wood texture, with better pigment and some normals.
- it would be easier to see where there's water with a clearer
background to be reflected in it.
Efficient how you did the water patch,
JC
> Thanks
>     pigment {
>         wood
>         turbulence 0.05
>         color_map {
>     finish {
>         crand 0.02
>         //ambient 0.32
>         diffuse 0.63
>         phong 0.2
>         phong_size 10
>     pigment {
>         bozo
>         color_map {
>     scale 0.25
> camera  {
> box     {
>         <-1,-1,-1>,
>         <1,1,1>
>         texture {
>                 pigment { Red }
>         scale <2,2,2>
>         rotate <0,-15,0>
>         translate <2,1,10>
> box     {
>         <-1,-1,-1>,
>         <1,1,1>
>         texture {
>                 pigment { Red }
>         scale <2,2,2>
>         rotate <0,-16,0>
>         translate <2,1,-9>
> cylinder{
>         <-1,-1,-1>,
>         <1,1,1>,
>         1
>         texture {
>                 pigment { White*2 }
>         scale <1,5,1>
>         translate <-7,3,0>
> merge {
> sphere_sweep {
>         cubic_spline
>         11,
>         Point1,1
>         Point2,1
>         Point3,1
>         Point4,1
>         Point5,1
>         Point6,1
>         Point7,1
>         Point8,1
>         Point9,1
>         Point10,1
>         Point11,1
> prism {
>     cubic_spline
>         hollow
>         texture {
>                 pigment {
>                 finish  {
>         interior        {
>                         ior Water_Ior
Date: 5 Feb 2004 00:01:09
Message: <matthewpace-4B509E.21010804022004@news.povray.org>
Id suggest some media, perhaps a photon map just for cool effect,
darkening the liquid, even if it is water, and increase the ior.
That about sums it up, looks good so far!
