POV-Ray : Newsgroups : povray.binaries.images : (32kb) WIP with artifact question - box.png (1/1) Server Time
14 Nov 2024 16:25:57 EST (-0500)
  (32kb) WIP with artifact question - box.png (1/1) (Message 1 to 10 of 10)
Subject: (32kb) WIP with artifact question - box.png (1/1)
Date: 2 Feb 2004 02:24:02
Message: <matthewpace-C0B659.23235701022004@news.povray.org>
I have decided to do a series of glowing boxes, I dont know if I stole
this from anyone, if so, please let me know, and I apologize.  Here is a
partial rendering of the first one, with radiosity off (looks better
with it on, duh) and some artifacts that I believe are from AA.  If you
can tell me how to fix that, I would be quite thankful.  Its currently
AA adaptive .4 threshold, level 5 recursion, and .1 jitter.  I have a
lot going one because it was highly aliased, espescially at large
resolutions.  You can notice it at the edge facing the camera, the line
between dark and light is not straigt.
Thanks in advace.
Matthew Pace
Download 'box.png' (32 KB)
Preview of image 'box.png'
Subject: Re: (32kb) WIP with artifact question - box.png (1/1)
Date: 2 Feb 2004 02:41:24
Message: <401dff24@news.povray.org>
I think the area of the box that you mentioned is *not* being AA'ed, since
it consists of two shades of grey which are very close to each other (less
than .4). Try reducing your AA threshold (try .2 for starters) and see if
the problem goes away. (It should at least be reduced once you get the
threshold low enough.)
By the way, you probably don't need a recursion level as high as 5. I think
2 or 3 would do the trick.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 2 Feb 2004 11:58:30
Message: <401e81b6@news.povray.org>
"Matthew Pace" <mat### [at] earthlinknet> wrote in message
news:matthewpace-C0B659.23235701022004@news.povray.org...
If you are going to work on such a simple idea, then you really need to
concentrate on not being so sloppy about it. This picture would be
helped by more attention to the proportions of the cube segments.
 -Shay
Date: 2 Feb 2004 12:05:28
Message: <Xns9483B83E1477Eraf256com@203.29.75.35>
mat### [at] earthlinknet news:matthewpace-
> Its currently
It's better to lower threshold i.e. try treshold 0.03 (recursion 3, method
1 or 2, jitter mabe off, or .1-.5)
Date: 2 Feb 2004 12:30:45
Message: <Xns94837F14EB16Atomatimporg@203.29.75.35>
"Shay" <sah### [at] simcopartscom> wrote in news:401e81b6@news.povray.org:
Different strokes for different folks.  That was one of the interesting
things about it for me.  Otherwise it is just another rubik's cube.
Tom
_________________________________
The Internet Movie Project
http://www.imp.org/
Date: 2 Feb 2004 18:48:16
Message: <matthewpace-79C3D0.15481402022004@news.povray.org>
In article <401e81b6@news.povray.org>, "Shay" <sah### [at] simcopartscom>
>  -Shay
I didnt want them to be equally sized, otherwise I would have done some
basic addition and subtraction to measure them out.  This was not
sloppiness, and I am sorry you do not like the way I made it.  If you
look closely, you can see that I did not even cut through the cube, but
rather indented it with CSG and some cylinders.
Date: 4 Feb 2004 12:34:07
Message: <40212d0f@news.povray.org>
news:matthewpace-79C3D0.15481402022004@news.povray.org...
| This was not sloppiness, and I am sorry you do not like the way
| I made it.
Looks like I was mistaken. I apologize, but certainly you can understand
my assumption.
Someone said once about abstract painters something to the effect of
their being more realist than "realist" painters, as the abstract
painters are presenting the reality of paint rather than attempting to
create an illusion. Carried over to cg, this paradigm legitimizes the
purposeful use of hard shadows, perfect corners, and the substitution of
ambience for glow.
I find this idea interesting and am therefore discouraged to see that so
many technically simple cg pictures carry tell-tale marks of sloppiness
like unscaled textures and arbitrarily placed or proportioned objects.
Of course there are times like this one when a person's intentional
design for his picture appears arbitrary when it is not. There are even
times when a person consciously decides that an element of his picture
truly is arbitrary and therefore gives no concern to that element.
Enjoy making the rest of your series.
 -Shay
Date: 4 Feb 2004 15:43:31
Message: <40215973@news.povray.org>
You seem to have a poor understanding of the AA parameters, maybe I can
help...
The threshold defines how much difference there has to be between two
pixels before POV-Ray will attempt to antialias them, treating each
pixel as having RGBvalues between 0 and 1; this value can range from 0
(AA everything except areas of no changes whatsoever) to 3 (only AA
divisions between pure white and pure black - in effect, nothing). A
good value to use for this while testing (if for some reason you're
testing with AA on) is .2 or .3, which is enough to get the effect of AA
but not enough to guarantee smoothness. For final renders, consider
using .1 or less.
The recursion defines how closely POV-Ray looks for edges; the higher
the recursion, the more supersamples it takes in order to define edges
and/or small details. In actual practice, a value of 2 is plenty for
test work, and anything above 4 is likely to be a waste; if you're not
getting enough detail at 4, you're probably better off rendering at a
higher resolution.
Jitter jitters the supersamples, essentially adding a small amount of
noise to antialiased areas, and should probably be avoided as a general
rule (IMO). In your case, I would say that jitter is responsible for the
"artifacts" you describe. Try setting it to 0.
You might also consider moving the camera or objects slightly so that
the division between the front faces falls along natural pixel
boundaries, if having the antialiased edge there REALLY bothers you.
-Xplo
Date: 4 Feb 2004 23:59:25
Message: <matthewpace-037BA6.20592304022004@news.povray.org>
>whole bunch of info
> -Xplo
Thanks a lot!
Date: 17 Feb 2004 15:10:24
Message: <matthewpace-ED86C9.12102317022004@news.povray.org>
In article <40212d0f@news.povray.org>, "Shay" <sah### [at] simcopartscom>
> | I made it.
> my assumption.
> ambience for glow.
>  -Shay
Interesting, do not worry about it, no one can see what an artist is
thinking when they make something, and of course I understand
