news: 4013e944$1@news.povray.org...
> how the hell do you start doing something like this ?
Dunno! always the same mistake I guess: I began with a single EL34 and I am
spending hours trying to make the McIntosh work.
> ok what's missing, nearest valve ? sockect appears empty of something.
As says Ingo :-)
Marc
Xns947BCABDE16DAseed7@news.povray.org...
> There could/should be a spring in there to push the valve down in its
> socket.
Hum it is suposed to be a spring in this one
Marc
Marc Jacquier <jac### [at] wanadoo fr> wrote in message
news:4013dc8f$1@news.povray.org...
> Hi :)
> Neither a toffee nor a computer but a mythical (and expensive) tube
> amplifier.
> when you can't afford it, raytrace it!
<DROOOL!!!>
In this case I'd probably say "legendary" instead of "mythical"... I could
never afford one, but I've managed to squeeze an extra 35 years out of an
ancient Harmon-Kardon that someone thought was dead back in 1969.
Now all you need is to make it scratch-n-sniff ;-)
RG - solid state will never smell like warm tubes
Xns947BC76AAF161seed7@news.povray.org...
> in news:4013dc8f$1@news.povray.org Marc Jacquier wrote:
> Great amp!
> One tiny little thing, the power tubes somehowe look a bit odd to me. If
> it's the KT88 I'd expect the body to be a bit "fatter". If it's a modern
> 6550 it could be a bit rounder at the top. If it's a NOS 6550 it could be
> a bit fatter at the bottom. Although I have to admit that I haven't played
> with these tubes for some years now. Currently using an amp with 6C33's.
Well I have to admit I never saw one of these tubes, I have only some pics
of the 275 but I'll take attention to your advice for future renders thanks
> I'd like to see it switched on, glowing in the dark :)
Well this means 2 arealights by valve that is 22 arealights... maybe for
2008 ;-)
Marc
4014199e$1@news.povray.org...
> Wow, it is impressive.
> I think the wood is a bit unrealistic. Improving the
> table's texture would make the image much more realistic.
you're right, I focused on the gear more than the furniture, I promise I'll
improve it
Marc (ashamed)
news: pan### [at] hotmail com...
> On Sun, 25 Jan 2004 13:36:12 -0500, ingo wrote:
> Now guess who's valve amp this is:
> http://home.no/t-o-k/photo/Valve_Amplifier.jpg
I get a DNS error :(
Marc
401425e4$1@news.povray.org...
> <DROOOL!!!>
could
not the easiest part of the job :)
Marc
Strange.
Try this:
http://194.63.250.45/t-o-k/photo/Valve_Amplifier.jpg
Tor Olav
de news: 40142f54@news.povray.org...
> Strange.
> Try this:
Same thing
I'll try later
Marc
>>Strange.
>>Try this:
> Same thing
> I'll try later
Hmmm... Maybe the server does not accept direct
access of the images.
The image can be found to the right in the second
row at this page:
http://home.no/t-o-k/photo/misc.html
Tor Olav
