POV-Ray : Newsgroups : povray.binaries.images : primate test 1 Server Time
15 Jul 2026 17:36:22 EDT (-0400)
  primate test 1 (Message 31 to 40 of 40)
Subject: Re: primate test 1
Date: 14 Jan 2004 19:14:49
Message: <4005DB78.F0A652F5@hotmail.com>
Jim Charter wrote:
> John VanSickle wrote:
> > Well, maybe not a silverback gorilla, but one could easily
> > hypothesize an isolate group of hominids that survived.
> BTW I know you are working on a mesh modeller.  I am generating the
> hair direction in POV by tracing splines along the surface of the
> figure.  In this picture I used the trace function.  In my next try I
> want to use the fact that Wings allows you to assign materials to
> individual polys.
>   So when I export to .obj, I can use this to parse out a hand drawn
> sequence of vertices and their normals.  It would be easier to be able
> to merely export selected vertices and their normals to a text file,
> then POV it from there.
The fellow who develops Wings3D has been in contact with me about my
surface subidvision code, so there is some cross-pollinization going
on.  Once I can get uv-mapping working right, my own modeller will
probably appear in public.  I used it for one of the models in one of
my IRTC entries for the current round (I did a Rusty and a spin-off).
John
Date: 14 Jan 2004 19:17:13
Message: <4005DC07.A120D49F@hotmail.com>
Jim Charter wrote:
> Now that I have a book to look at, the hair seems to vary a lot, even
> between individuals in a species.  The source photo I was using did
> seem to show pretty scraggy hair, which I took to mean "old" also.
> Other chimps have more tuffed hair, in others its softer, more aligned
> in waves.  None look quite as wiry as in my picture though.
But it looks good.  If this were a species of intelligent life, I
could easily believe one of their old men (or women) having hair like
this.
John
Date: 14 Jan 2004 19:30:36
Message: <4005df2c$1@news.povray.org>
I'll be looking foreward to trying it.
-Jim
Date: 14 Jan 2004 22:04:24
Message: <40060338$1@news.povray.org>
Jeremy M. Praay wrote:
> Amazing work, Jim!  This is breath-taking, in my opinion.
Thanks Jeremy
> I would like to hear more elaboration on how you did the hair, and how CPU
> and memory intensive it was, etc., if you wouldn't mind.
Yeah I know you have been attacking the hair problem too. That's partly
why I posted this example.  Give me a day or two and I'll put something
together.  I am actually working with a new way to do the hair which
looks quite promising but is buggy at the moment.  Then maybe I can show
you both methods.  I was using mesh, but not instancing, and that render
took around 40 min I think with Jaime's lighting which includes radiosity.
I never could have done it before I fixed the case fan which seems to
have solved my overheating problems.  I am beginning to think that while
my processor was heating up, so was everything else and it may be the
video card that was actually flaking out.  That might explain why it
seems to be heat related, even though I was only taking the palomino up
to 60 degrees before crashing.
I have half a gig of memory installed and no where near all of it gets
used.  But that guy going to need a lot more hair before he's finished.
Date: 15 Jan 2004 13:36:41
Message: <4006ddb9$1@news.povray.org>
Gilles Tran wrote:
> IIRC, Jim has a formal art training and is an accomplished traditional
> painter (see his website), which is a great advantage in 3D from what I've
> seen from other traditional media artists who turned to 3D.
It is also true that I was first introduced to mesh modelling in an
instructor-lead, Maya class.  So that when I came to Wings, I had the
concept.  I knew what I wanted to do.  I just had to learn how.
-Jim
Date: 15 Jan 2004 18:39:30
Message: <400724b2$3@news.povray.org>
wow!
Kitty5 NewMedia http://Kitty5.com
TEL : +44 (01270) 501101 - ICQ : 15776037
PGP Public Key : http://pgp.kitty5.com
Date: 15 Jan 2004 21:42:38
Message: <40074f9e@news.povray.org>
Hillary!
Jim
news:400485b8@news.povray.org...
> There is more wrong with this than right, but I wanted to show the
> direction I have being working in.  This actually started as an entry
> for "future" but has turned into a more measured project to teach myself
> organic modelling, texturing, hair generation etc.  It's going to take a
> while to get something really showable.
> No sss in place yet.
> Modelled in Wings
> Lighting by Jaime
> Bumpmaps and image maps generated in PS
> Uvmapped in uvmapper
Date: 16 Jan 2004 00:09:45
Message: <40077219@news.povray.org>
Okay.
1. I used the trace macro to find a lines of points on the surface of
the figure to describe the direction of the hair.  Splines are generated
  from these points.  One spline alone the surface for the hair roots.
One spline from points along the normals to place the end points of the
hairs
2. The splines are sampled to get start, end, and midpoints, for each
hair.  These points are use to create a spline.  Each hair is then built
by placing mesh along the spline
3. The hair spline can be modulated by sampling a smooth pattern such as
bozo and using the values to rotate the midpoints slightly around the normal
4. The placement of each hair is also jittered
But the original method of tracing points to establish the hair
direction was time consuming and cumbersome.  So going forward I plan to
use the following method to establish the direction splines
5. In Wings, nine different materials can be assigned to nine selected
points
6. With all nine points selected, they can be exported as a .obj mesh
file.  In the mesh file, each polygon or 'face' is tagged with a
separate material. e.g.
g cube1_1a
usemtl 1a
f 19//19 31//31 10//10 1//1
g cube1_1b
usemtl 1b
f 11//11 34//34 24//24 3//3
g cube1_1c
usemtl 1c
f 12//12 33//33 21//21 2//2
g cube1_2a
usemtl 2a
f 6//6 18//18 30//30 17//17
g cube1_2b
usemtl 2b
f 8//8 22//22 29//29 23//23
g cube1_2c
usemtl 2c
f 16//16 36//36 15//15 4//4
g cube1_3a
usemtl 3a
f 20//20 35//35 27//27 7//7
g cube1_3b
usemtl 3b
f 9//9 26//26 32//32 25//25
g cube1_3c
usemtl 3c
f 13//13 28//28 14//14 5//5
7. The obj mesh file can be parsed in a separate program and one of the
four vertices and normals fo each face can be retrieved
8. These points can be used to generate the direction splines.
Download '1.jpg' (35 KB) Download '2.jpg' (43 KB) Download '5.jpg' (72 KB) Download '8.jpg' (29 KB)
Preview of image '1.jpg'
Preview of image '2.jpg'
Preview of image '5.jpg'
Preview of image '8.jpg'
Date: 19 Jan 2004 12:38:48
Message: <400c1628@news.povray.org>
Jesus, Jim, you sure know how to play it cool. A few weeks ago, you
posted a link in p.o-t to the work of a modeler whom you admired. Now
you post this, which is twice as good as any of his stuff.
I have wondered if something like this:
http://news.povray.org/povray.binaries.images/23494/
might produce better looking, less memory eating hair at the expense of
greater rendering time.
 -Shay
Date: 19 Jan 2004 13:25:55
Message: <400c2133$1@news.povray.org>
Er..., not yet, but when I get it to where I want it to be,... maybe,
definitely maybe ;)  Thanks for the boost.  Since I know you say exactly
what you think, I means a lot to me.
I do plan to try that.  I do expect the render time to hurt.  I will see
how far I can take the mesh first.
-Jim
