Subject: Re: Antialiasing problems (3 images, 11k,15k,12k)
Date: 12 Jan 2004 22:39:41
Message: <4003687d$1@news.povray.org>
> > : Not that the starfield will
> > : remain exactly like this, but sure they don't have to vanish. To keep the
> > : stars small, make sure they are very strong / intense, and then try this
AA:
> > : +AM2 +A0.0 +R2 -J
> > This didn't help, still kills the starfield. But thanks!
> If it does, it implies your stars are simply too small.
not necessarily too small, but certainly to dark. Brighten your stars, and I
believe you will get more realistic results than if you make them bigger.
maybe...
dunno
coulnd't hurt trying :)
cu!
<.5,1,.5>,x)L(0,x-y,<.5,1,.5>,x) // ZK http://www.povplace.be.tf
Date: 12 Jan 2004 22:57:36
Message: <40036cb0@news.povray.org>
It depends on what you're trying to emulate. If you want anti-aliasing simply to
make it look like you started with a higher res image and reduced it, then the
way pov does it is fine. But if you want it to simulate photography then it
should combine all it's samples before clipping them. You could avoid
over-bright objects getting jagged edges by using more samples (the
anti-aliasing threshold would mean these extra samples only got used on those
high-contrast areas).
Tek
www.evilsuperbrain.com
"Slime" <fak### [at] email address> wrote in message news:40034b23$1@news.povray.org...
> > Unfortunately, POV clips the colors before it combines them, rather than
> > afterward...to antialiasing, rgb 20 is the same as rgb 1.
> You mean fortunately. POV-Ray does this in the mathematically correct way.
> Antialiasing is a method of making an image with finite resolution appear as
> though it has infinite resolution. If POV-Ray did not do it this way, then
> extremly bright objects which are *large* (such as a sphere with color rgb
> 20) would look very aliased.
> Clipping after anti-aliasing would cause anti-aliasing to be useful only in
> situations where colors were not oversaturated. Just because the alternative
> would produce a specific effect in a specific situation doesn't mean that
> it's desirable.
> - Slime
Date: 12 Jan 2004 23:27:59
Message: <400373cf@news.povray.org>
> You could avoid
those
If 1/9 of a pixel has the color rgb 10000, and the rest of the pixel has
other colors between 0 and 1, and clipping happens after anti-aliasing, then
the pixel is going to be 1/9 * 10000 + 8/9 * (something between 0 and 1),
which works out to be well over 1, causing the entire pixel to be
oversaturated. More samples just causes this calculation to be more
accurate, but still well over 1. If this happens at every pixel along the
edge of an object, it will look pixellated.
- Slime
[ http://www.slimeland.com/ ]
In article <40034b23$1@news.povray.org>, "Slime" <fak### [at] email address>
No, do I mean unfortunately. Clipping before antialiasing is the wrong
way to fix this problem. Small, intense sources get completely wiped
out. Antialiasing supersamples the scene, not some virtual model of an
image file in a format that's limited to a tiny dynamic range.
Christopher James Huff <cja### [at] earthlink net>
POV-Ray TAG: <chr### [at] tag povray org>
http://tag.povray.org/
> out.
Because they're too small to be accurately represented in the final image
resolution. Just because they're intense doesn't mean they should become a
full pixel in size. This could end up producing different results depending
on what the final resolution is.
Antialiasing supersamples the scene, but it must take into account that the
final output will have limitations such as a finite dynamic range. The
mysterious "format" you refer to is the same as the actual format of the
final image, which is important. By clipping before averaging, anti-aliasing
produces the effect of rendering at an infinite resolution and then resizing
smaller, which is exactly what it's supposed to do.
I admit that I do see some logic in your argument - clipping before
averaging does feel artificial to some extent. However, the fact that
clipping after averaging would produce jagged edges on bright objects causes
me to believe that it would be much more useless than clipping before
averaging.
In any case, I'd appreciate if someone who's done a significant amount of
research on the topic could step in and tell us *why* POV-Ray does it the
way it does, and maybe what other popular 3D apps do, and why it is or is
not correct.
- Slime
Oh yes, I see what you mean.
Still my digital camera tends to pick up jagged edges on bright things... :)
Tek
"Slime" <fak### [at] email address> wrote in message news:400373cf@news.povray.org...
> > You could avoid
> those
> - Slime
> full pixel in size.
Sure it does. If a sun-sized star is a million times farther from
Earth than the sun, but a hundred million times brighter, it would
be visible during the day, even though it is otherwise too small to
be seen.
But what about if you take a photo of the night sky? The stars are much smaller
than 1 pixel, however they show up because of their intensity.
The colour of a pixel should be the average colour across the area of that
pixel, so if you have a star that's 1/2000th the area of the pixel and has
intensity 1000, then the pixel should have a colour of rgb 0.5. This happens in
a camera because it takes theoretically infinite samples (i.e. all the photons
hitting that pixel contribute to the brightness).
I believe that's the effect Bob was trying to simulate.
Tek
"Slime" <fak### [at] email address> wrote in message news:400409cc$1@news.povray.org...
> > out.
> averaging.
> not correct.
> - Slime
I tend to agree with you but the whole thing is not that easy. What
antialiasing does is to try to approximate the integration over the
pixel area by taking several samples.
But the problem is if it is correct to do the averaging of the samples
(which is the approximation of the integral with a sum) with or without
the non-linearities of the tone-mapping used (in case of standard POV
this is gamma correction and clipping).
You can't really answer this from looking how it works in real life -
when you take a photograph of a star the ideal camera outside the earth
atmosphere in ideal empty space will only show an infinitely small
point. Of course nothing is ideal so the result will be a spot of
finite size (with the intensity diminishing from the center to the rim).
but how exactly the non-linearities of the film exposure work here is
hard to tell (meaning it would be difficult to predict how bright two
stars very close to each other will look from the appearance of them a
distance apart).
Coming back to the actual antialiasing problem - in cases like this it
would be quite nice to antialias before clipping, in relation with the
high dynamic range output in next megapov this will be possible as well.
But there are also situations where this causes problems, see for
example the wall edge on the right in:
http://www-public.tu-bs.de:8080/%7Ey0013390/pov/pool/chpool.jpg
where despite antialiasing the stairstep effects are quite strong which
is to some extent caused by the tone mappping being applied after
antialiasing.
An idea i had thought of to solve this problem (without the necessity to
accept clipped output) was to make the tone mapping function (or an
approximation of it) available to POV (for example as a user defined
function) and to apply this function before the averaging of samples.
To get back to the linear result afterwards you would need the inverse
of this function of course (it needs to be invertible so you should not
use hard clipping).
I don't know how useful such a feature would be but it would allow to
adjust continuously between the two extemes.
Last updated 11 Jan. 2004 _____./\/^>_*_<^\/\.______
Date: 13 Jan 2004 13:43:28
Message: <40043c50@news.povray.org>
> point.
Well I was thinking of a digital camera, which works by having a grid of colour
sensors that effectively just add together the brightness due to all photons
falling upon that pixel. Surely with that a very small point would always be 1
pixel in size and have a brightness proportional to it's brightness multiplied
by how much of the area of the pixel it covers.
I'm not sure how all that corresponds to gamma ramps and such, but digital
cameras tend to get sharp images without aliasing, so surely that can be used as
a model for an anti-aliasing technique?
Tek
"Christoph Hormann" <chr### [at] gmx de> wrote in message
news:mgp### [at] triton imagico de...
> distance apart).
> antialiasing.
> use hard clipping).
> Christoph
> POV-Ray tutorials, include files, Sim-POV,
> HCR-Edit and more: http://www.tu-bs.de/~y0013390/
