Subject: Re: Repost: My Stereo (jpg-211k)
Date: 24 Dec 2003 07:52:24
Message: <3fe98c08@news.povray.org>
"Carl Hoff" <hof### [at] wt net> wrote in message news:3fe8df9e@news.povray.org...
> I've had planes appear in my CGS's before. For example if one of the
pieces
> you differenced out of your box had a co-incident surface with the side of
> the box it could leave just that plane sticking out by itself. Look at
the
> circled areas in the attached picture. Why are there wooden teeth
sticking
> down into the top of the TV? Is this something sitting on top of the TV?
> Maybe I'm just not looking at it correctly but it looks odd to me.
Could the proximity of old Rod Sierling explains those phenomenons. After
all he controls the horizontals and verticals of our TV screens, I bet he
could do it with a monitors too ^________^
Jean-luc: "I've never used CSG in my life!" -__-
Jeremy
"Eric Freeman" <whi### [at] yahoo com> wrote in message
news:3fe8c631@news.povray.org...
> "Hughes, B." <omn### [at] charter net> wrote in message
> news:3fe8463d$1@news.povray.org...
> > news:3fe834b8@news.povray.org...
> > > If I make it too transparent, the lampshade doesn't look
> > > right. If I make it less transparent, not enough lite gets
> > > thru.
> > Could fake it using a lens flare effect, placed between the
> > camera and lampshade.
> Hmmmmmm.....
Gilles made a pretty good lamp which you can see here, and download the
source as well.
http://www.oyonale.com/ressources/english/sources10.htm
I'm not saying you should replace the lamp, but it may give you some ideas
from the source. But with the lamp turned on, it takes a looooong time to
render, so keep that in mind.
The 'teeth' (for lack of a better word) are still there and it doesn't
look like the lighting to me. Could you render just the TV by itself
against a white background? I tend to think its a co-incident surface
artifact.
Carl
news:3fe8f33f@news.povray.org...
> > of the pieces you differenced out of your box had a co-incident
> > surface with the side of the box it could leave just that plane
> > sticking out by itself. Look at the circled areas in the attached
> > picture. Why are there wooden teeth sticking down into the top
> I think it's just the lighting. Here's a close up with brighter lights.
> The top of the TV is the top of the grey frame around the picture. There
is
> a gap between the top of the TV and the top of the cabinet. There is a
wood
> back on the cabinet that can be seen over the top of the TV.
> Eric
Program ended abnormally on 23/12/2003 21:00, Due to a catastrophic Eric
Freeman error:
> The top of the TV is the top of the grey frame around the picture. There is
> a gap between the top of the TV and the top of the cabinet. There is a wood
> Eric
Is the top of your TV shiny? I agree with Carl, there seems to be something
wrong... To me the outline of the TV looks like this:
/* flabreque */L)polygon{5,F,F+z,L+z,L,F pigment{rgb 9}}#end union
/* @ */{P(0,a)P(a,b)P(b,c)P(2*a,2*b)P(2*b,b+c)P(b+c,<2,3>)
/* videotron.ca */}camera{orthographic location<6,1.25,-6>look_at a }
Download 'closeup.jpg' (24 KB)
Preview of image 'closeup.jpg'
Thanks... atleast I now know its NOT just me seeing things.
Carl
"Francois Labreque" <fla### [at] videotron ca> wrote in message
news:3fe9d590@news.povray.org...
something
"Carl Hoff" <hof### [at] wt net> wrote in message news:3fe9e884@news.povray.org...
> > something wrong... To me the outline of the TV looks like this:
I found the problem... a misplaced bounded_by/clipped_by statement. I would
have never spotted it... thanx dudz. One day I'll finish this pic (the back
of tv isn't contoured like the real thing... it's just a box).
Eric
Download 'tv_alone.jpg' (72 KB)
Preview of image 'tv_alone.jpg'
> If I make it too transparent, the lampshade doesn't look right. If I make
> it less transparent, not enough lite gets thru.
Did you try double_illuminate ?
Marc
