POV-Ray : Newsgroups : povray.binaries.images : The ball, the mirror, and the checkered plane [~ 64 KiB] Server Time
16 Apr 2026 12:58:48 EDT (-0400)
  The ball, the mirror, and the checkered plane [~ 64 KiB] (Message 1 to 3 of 3)
Subject: The ball, the mirror, and the checkered plane [~ 64 KiB]
Date: 30 Nov 2003 14:08:57
Message: <3fca403d@news.povray.org>
Things like this have probably been done a thousand times... here's another
one.
The "ball" is an isosurface, using data from terrainbase
(<http://www.ngdc.noaa.gov/mgg/global/seltopo.html>) and an image map (and
clouds) from Blue Marble
(<http://earthobservatory.nasa.gov/Newsroom/BlueMarble/>).
I'd still like to improve the lighting (with radiosity), the toothbrush's
"hairs" and some textures, and maybe add a glass or something to be seen in
the mirror.
light_source{9+9*x,1}camera{orthographic look_at(1-y)/4angle 30location
9/4-z*4}light_source{-9*z,1}union{box{.9-z.1+x clipped_by{plane{2+y-4*x
0}}}box{z-y-.1.1+z}box{-.1.1+x}box{.1z-.1}pigment{rgb<.8.2,1>}}//Jellby
Download 'earth.jpg' (64 KB)
Preview of image 'earth.jpg'
Subject: Re: The ball, the mirror, and the checkered plane [~ 64 KiB]
Date: 30 Nov 2003 18:20:01
Message: <web.3fca7a41bc8d0a9b543aa38d0@news.povray.org>
I really like it so I'll take the trouble to tell you what improvements I'd
like to see:
 - I could be wrong, but it looks like the continents are too big on that
Earth, as if the mapping of the data to the sphere is at the wrong scale.
It looks from the picture that Siberia must extend all the way around the
globe through where the Americas should be.
 - Tighten that atmospheric shell.  At this scale the height of the cloud
cover would be microscopic, but it's not a bad idea to make it just
noticeable in order to keep that sense of depth.
I like the style of it and I think you have a really good start.  I'm no
expert so feel free to ignore everything I've said.
>one.
>the mirror.
Date: 6 Dec 2003 14:28:16
Message: <3fd22dcd@news.povray.org>
> I'd like to see:
As far as I can tell, the mapping is right. It's just a spherical mapping of
(a higher resolution version of)
<http://visibleearth.nasa.gov/data/ev116/ev11612_land_ocean_ice_350.jpg>,
which, it seems, has constant angular resolution in both vertical and
horizontal directions. Take into account that, the most northern (and
southern) zones look much larger in the plane map, since they are
stretched. I rendered different views of this Earth and all seems to be
fine.
Yes, the radial (surface) detail is much exaggerated, in a correct scale,
the Earth would be more featureless than an orange... I halved the height
of the clouds over the sea's surface.
This is the current state. Radiosity and photons are on, and it took too
long to render in my box, so it's only 300x400 :( Sadly, much of the detail
is lost (it's maybe too dark, too, what could I do?), like the underwater
relief, but I like the metallic shine and how the desertic areas in Africa
and Asia are cloudless. In a few days I hope to have a new computer at
work, when I have it configured and running I will render a bigger image
there and maybe try to fiddle a bit more with textures...
Any additional suggestions?
P.S. Would this Earth be interesting for the "Balls Collection" project?
Download 'earth2.jpg' (21 KB)
Preview of image 'earth2.jpg'
