Program ended abnormally on 05/11/2003 23:10, Due to a catastrophic Greg
M. Johnson error:
Liposuction pump?
/* flabreque */L)polygon{5,F,F+z,L+z,L,F pigment{rgb 9}}#end union
/* @ */{P(0,a)P(a,b)P(b,c)P(2*a,2*b)P(2*b,b+c)P(b+c,<2,3>)
/* videotron.ca */}camera{orthographic location<6,1.25,-6>look_at a }
> Liposuction pump?
No, it's a metallic animal with a long thin neck, coming out at
full moon and grabbing with its six-finger-head at the cap of
an innocent transparent cylinder containing some delicious
synthetic green oil ...
... but the animal has no tail, no eyes, no ears and seems to be
ill: it has a speckled skin; and the moon isn't visible, so the
lighting isn't fully convincing.
Sputnik
Funny, **I** couldn't see it using IE Explorer-- could there be a version
problem? But it worked fine IIRC on my other PC using OE.
The green tank houses some sort of diabolical scientific experiment, perhaps
an operation not unlike that which Wolverine went through. The tank on the
right is supposed to be the source of the green liquid.
Interestingly, I gave an impression of green goop simply with reflection. I
wonder if the effect would hold with all lighting & views.
Thanks for the speculation-- it helps me figure out what details I need to
fix.
