POV-Ray : Newsgroups : povray.binaries.images : Balls collection (61k) - Contributions needed Server Time
16 Jul 2026 01:17:08 EDT (-0400)
  Balls collection (61k) - Contributions needed (Message 39 to 48 of 58)
Subject: Re: Fix for Rear-Wall + (11k)
Date: 17 Oct 2003 05:46:22
Message: <3f8fba6e@news.povray.org>
Thanks, I updated the code and will repost into p.b.s-f with the new
candle code. I made the golf ball and tried to use your ESR macro to
generate 492 evenly ditributed points but it's taking quite a very long
time so I had to use an external C program I found. The problem is now
that a sphere with 492 differenced objects seems to be very long to
render (I think it is explained on "Mike's Little Web Page"), and it's
even worse than that because I planned to use 13 of them... (see
attached image).
Nico
Tim Nikias v2.0 wrote:
> I've looked into your code to properly test the candle in the actual
> environment, and this is what I've found: you forgotten to move the plank by
> z*plank_thickness in the end. The thickness points towards the camera and
> thus extends from z=2.5 towards z=2.1, so I've just added plank_thickness in
> the last translation. Below is the code, you can easily spot the difference
> from your to my version:
> // Rear plank
> object {
>   IW_Plank_RoundW  (
>     17,
>     (box_nx*box_x+(box_nx+1)*plank_thickness), plank_thickness,
> box_ny*box_y+(box_ny+1)*plank_thickness,
>     2, 0, 0.05, 0.0035,
>     pigment { P_IW_10 color_map {CM_IW} scale 5} , Fin_W_02 , No_Normal, 2
>   rotate x*-90
>   translate -x*(box_nx*box_x+(box_nx+1)*plank_thickness)/2
>   translate z*(box_z+plank_thickness) //  <= Updated here
> Attached is the small snippet showing the candle from a 500x500 render with
> only the candle traced. Required about 5 minutes on my 2.4Ghz XP+ and
> shouldn't affect the rendering times of the others boxes as the lightsource
> of the candle is pretty much contained in the box.
> Regards,
> Tim
Download 'detail.jpg' (12 KB)
Preview of image 'detail.jpg'
Subject: Re: Balls collection (61k) - Contributions needed
Date: 17 Oct 2003 05:49:15
Message: <3f8fbb1b$1@news.povray.org>
Tom Galvin wrote:
> Nico <rou### [at] loriafr> wrote in news:3f8d6461@news.povray.org:
>>Anyone interested ?
>>Comments ? Ideas ?
>>Nicolas
> I love it.  Once I saw this, I had a vision of a much lager cupboard (9x9
> cubbies?) with the center ones holding
>     	P   O   V   -   R   A   Y
> And printed out as a Poster
That would be definitely very nice, even more if there are enough
contribution to be able to fill it.
Nico
Date: 17 Oct 2003 05:58:27
Message: <3f8fbd43$1@news.povray.org>
Christoph Hormann wrote:
> Nico wrote:
>> Hi All,
>> Since I'm always searching povray newsgroup to look for specific
>> methods of doing things, I decided to try to gather them all in a
>> single picture both to have a quick idea on what it looks like and
>> also to have a quick access on source. The image currently shows (in
>> order):
>>  - Blurred reflection (from Povray Questions and Tips)
>>  - Spheric mapping of object (I did this one)
>>  - Ice (or water ?) from a recent post by IkA
>>  - Furtex by Rune S. Johansen
>> Of course, this image is still a WIP and it misses a bunch of other
>> great methods/tips that have been posted like subsurface scattering,
>> fire, water, furballs, media clouds, etc.
>> At this point, I would need your help to complete the image by adding
>> some more balls showing special effects/textures/methods...
>> Anyone interested ?
>> Comments ? Ideas ?
> Looks like a good start.  Maybe you should add something like:
> http://www.tu-bs.de/%7Ey0013390/pov/planets.html
Yes, earth with moon in orbit would be great but having read the webpage
describing the method, I'm not sure I know how to do that (or did I miss
the link ?). Could you post an example ?
Nico
Date: 17 Oct 2003 06:40:52
Message: <3f8fc734$1@news.povray.org>
Care to send me that C-Programm via email?
Aside of the rendering times, I'd say go for one sphere. After all, it looks
like your image is rather designated to single spheres in little boxes...
Tim Nikias v2.0
Email: tim.nikias (@) gmx.de
> attached image).
> Nico
plank by
and
plank_thickness in
difference
> > // Rear plank
> > object {
> >   IW_Plank_RoundW  (
> >     17,
> >     2, 0, 0.05, 0.0035,
2
> >   rotate x*-90
with
lightsource
> > Regards,
> > Tim
Version: 6.0.525 / Virus Database: 322 - Release Date: 09.10.2003
Date: 17 Oct 2003 06:44:23
Message: <3f8fc807$1@news.povray.org>
Another thing: the updated version you submitted has the red spheres
switched on, everything else commented out, and the red spheres are in the
top-left corner.
Tim Nikias v2.0
looks
> Tim Nikias v2.0
> Homepage: http://www.digitaltwilight.de/no_lights
Date: 17 Oct 2003 06:53:26
Message: <3f8fca26@news.povray.org>
And yet another thing: This is how I'd do the water-sphere:
sphere {0,1
  ball_at (2,3)
    pigment {rgbt  <1.0,1.0,1.0,0.98>}
    finish{
      diffuse 0
      ambient 0
      specular 1
      roughness 0.0001
    reflection {0,1 fresnel}
    conserve_energy
       normal { agate 0.3 scale 1.3 }
    interior {ior 1.33}
No need for the "glass.inc" at all, proper Ior for the water, as well as
reflection. Specular and Phong are two models for the same thing:
Highlights, so I'd go with just one of them. Since the rgb-color is <1,1,1>
I'd go for high transmit instead of filter.
Tim Nikias v2.0
Date: 17 Oct 2003 07:00:55
Message: <3f8fcbe7$1@news.povray.org>
I tend to forget things...
How about photons? You'd have to render it in two passes probably, so that
the blurred reflection won't take too long for the photons. I'd say:
#declare Photon_Pass=true;
#if (Photon_Pass)
 photons{... save_file}
#else
 photons{...load_file}
And some switched inside the blurred reflection and possibly other objects
to create the correct lighting.
Tim Nikias v2.0
Date: 17 Oct 2003 07:20:53
Message: <3f8fd095@news.povray.org>
I fixed the waterball, the main file and keep the several golf balls
just to see what it looks like. Result by Tuesday maybe (will be busy
until then).
I was thinking about photons but didn't dare to try (rendering time).
I think we have also to find a way to collaborate on the rendering.
Since each ball (or future small scene) is contained within a box the
image can certainly be rendered by several different people, hoping
there won't be much (light) interaction between subparts.
What do you think ?
Nico
> #if (Photon_Pass)
> #else
> #end
Date: 17 Oct 2003 07:28:44
Message: <3f8fd26c$1@news.povray.org>
You're using radiosity. Unless someone prerenders the scene and saves the
radiosity data, which the others can load, there is light interaction
between subparts. For a final render I'd suggest the two-pass radiosity
method the newsgroups cooked up at some point anyway, so divided rendering
should be possible then. You can find more information on that two-pass
method on my website, within my Past-Projects-Section, entitled "Indoor
Radiosity Experiments". I've made use of that technique for my Gerberas
Image as well, so you'll find information on that in there as well.
I've also noticed that your radiosity settings are somewhat queer, e.g.
nearest_count set to 1. Why is that? I raised nearest_count to 8, cause
otherwise it gave me ugly artifact with photons. Once the image is ready,
I'll post it.
Care to post the Golf-Ball? Maybe I could have do some experiments with it.
Tim
PS: You might have noticed that I'm pretty enthused with this image... :-)
Tim Nikias v2.0
> until then).
> What do you think ?
> Nico
that
> > #if (Photon_Pass)
> > #else
> > #end
objects
Date: 17 Oct 2003 07:43:57
Message: <3f8fd5fd@news.povray.org>
The golf ball is posted in the new corrected version 2.
You're absolutely right about the two pass rendering, especially when
there is transparency and reflection (they can be shut down during the
first pass, right ?).
Concerning divided rendering, I don't see what could be interaction
between boxes since objects are fully within a box. If I tell povray to
render only top-left box (by specifying what image part to render), will
that be wrong in term of radiosity interaction ?
Concerning radiosity settings, they're more or less "random" since I do
not really understand them and get them from some file I have, so I'm
open to any sugestions (and already raised the nearest_count).
image... :-)
I sort of noticed :)
Thanks for all your help and advices.
Nico
> I'll post it.
> Regards,
> Tim
