POV-Ray : Newsgroups : povray.binaries.images : Balls collection (61k) - Contributions needed Server Time
16 Jul 2026 03:01:27 EDT (-0400)
  Balls collection (61k) - Contributions needed (Message 29 to 38 of 58)
Subject: Re: SSS_Candle
Date: 16 Oct 2003 13:05:43
Message: <3f8ecfe7$1@news.povray.org>
Update: A quick test revealed that the same occurs with difference spheres
instead of smoothly blobbed "difference", so it ain't a precision problem
with blobs. Hm.
Tim Nikias v2.0
Email: tim.nikias (@) gmx.de
> Another thing I just noticed: the black edge you referred to isn't
existant,
> that seems to be some side-effect of jpeg-conversion or such. In my
renders,
> even large ones, everything is fine except for the darker patch. Perhaps
its
> some floating point issue with blobs in conjunction with media? Need to
> check with a different object to prove that...
> Tim Nikias v2.0
> Homepage: http://www.digitaltwilight.de/no_lights
> Outgoing mail is certified Virus Free.
> Checked by AVG anti-virus system (http://www.grisoft.com).
> Version: 6.0.525 / Virus Database: 322 - Release Date: 09.10.2003
Date: 16 Oct 2003 17:00:26
Message: <3f8f06ea@news.povray.org>
"Tim Nikias v2.0" <tim.nikias (@) gmx.de> wrote in message
news:3f8ecfe7$1@news.povray.org...
> with blobs. Hm.
I rendered within a sky_sphere, nothing else in the scene and it didn't have
the darker place on that near upper edge. Then I realized I hadn't used a
camera high enough above the candle and once I lowered it I saw it too.
Turns out that it can be made less obvious if intervals is raised some.
Well, the original dark place disappears. I know media method 3 is supposed
to auto-adjust that for you but nothing is perfect, and you had it at
intervals 1 so I figured that was a good place to start changing things
around.
The dark place was the inside curvature, near as I can tell, and it looks
like it might take an increase in samples, density, intervals or some
combination of those in order to help eliminate it. Actually, from what I've
seen by trying that here, I can still see the inner dimple through the outer
shell. Might take a lot of tweaking on those things to get it looking okay.
Bob H.
http://www.3digitaleyes.com
Date: 16 Oct 2003 17:27:04
Message: <3f8f0d28@news.povray.org>
Hm, hadn't thought about that combination. AFAIK, method 3 is supposed to be
run with intervals on 1, and high sampling rate, whereas method 2 requires
intervals rather than samples. That's just a supposition of mine, if anyone
wants to correct me on that to a significant degree, I'd be happy to listen.
Tim Nikias v2.0
spheres
problem
> > with blobs. Hm.
have
supposed
> around.
I've
outer
okay.
> Bob H.
Date: 16 Oct 2003 18:26:41
Message: <3f8f1b21$1@news.povray.org>
Just uploaded the new file in PBSF, entitled "Subsurface spherical candle",
as reply to the "Ball Collection" thread. The outdated version was recalled,
though I'm not too sure if that works properly.
Tim Nikias v2.0
Version: 6.0.525 / Virus Database: 322 - Release Date: 10.10.2003
Subject: Re: Balls collection (61k) - Contributions needed
Date: 16 Oct 2003 19:46:39
Message: <Xns9416C8F75C65Dtomatimporg@204.213.191.226>
Nico <rou### [at] loriafr> wrote in news:3f8d6461@news.povray.org:
> Anyone interested ?
> Comments ? Ideas ?
> Nicolas
I love it.  Once I saw this, I had a vision of a much lager cupboard (9x9
cubbies?) with the center ones holding
    	P   O   V   -   R   A   Y
And printed out as a Poster
Tom
_________________________________
The Internet Movie Project
http://www.imp.org/
Date: 16 Oct 2003 20:16:25
Message: <3f8f34d9$1@news.povray.org>
That's a great idea! If we'd want it as a Poster though, perhaps some more
effort should be put into the different objects. E.g. Rune's Fur-Texture is
great for smaller objects, but doesn't stand for close scrutiny. Even though
I like the idea of different ideas and techniques being spread in the image,
the result should be near-photorealistic.
And, if the viewing angle permits, perhaps one of the lowest cubes should
get a nice checker texture as floor with a simple, reflective sphere? That
just shouts to be in there for a POV-Ray Poster...
Tim Nikias v2.0
> > Anyone interested ?
> > Comments ? Ideas ?
> > Nicolas
>     P   O   V   -   R   A   Y
> Tom
> http://www.imp.org/
Subject: Fix for Rear-Wall
Date: 16 Oct 2003 20:31:41
Message: <3f8f386d@news.povray.org>
I've looked into your code to properly test the candle in the actual
environment, and this is what I've found: you forgotten to move the plank by
z*plank_thickness in the end. The thickness points towards the camera and
thus extends from z=2.5 towards z=2.1, so I've just added plank_thickness in
the last translation. Below is the code, you can easily spot the difference
from your to my version:
// Rear plank
object {
  IW_Plank_RoundW  (
    17,
    (box_nx*box_x+(box_nx+1)*plank_thickness), plank_thickness,
box_ny*box_y+(box_ny+1)*plank_thickness,
    2, 0, 0.05, 0.0035,
    pigment { P_IW_10 color_map {CM_IW} scale 5} , Fin_W_02 , No_Normal, 2
  rotate x*-90
  translate -x*(box_nx*box_x+(box_nx+1)*plank_thickness)/2
  translate z*(box_z+plank_thickness) //  <= Updated here
Attached is the small snippet showing the candle from a 500x500 render with
only the candle traced. Required about 5 minutes on my 2.4Ghz XP+ and
shouldn't affect the rendering times of the others boxes as the lightsource
of the candle is pretty much contained in the box.
Tim
Tim Nikias v2.0
> Ooopps, didn't notice. I will try to fix the code.
> Nico
> Tim Nikias v2.0 wrote:
> > Perhaps I'll have another go with the ESR-Macro just to have some
results to
> > compare. During the process of creating the Subsurface-Scattering I've
> > noticed that the back of the balls intersect with the wooden board...
Care
> > to fix that?
Download 'sss_candle2.jpg' (7 KB)
Preview of image 'sss_candle2.jpg'
Date: 16 Oct 2003 20:50:01
Message: <web.3f8f3b8d92b544a7e36ee7270@news.povray.org>
Perhaps another of the boxes should include a Cornell's box as well! This
may be taking this too far, but what if each box had it's own simple
scene/theme rather than just a sphere. Each box would still showcase a
specific
technique or feature, as previously suggested.
Date: 17 Oct 2003 05:17:21
Message: <3f8fb3a1@news.povray.org>
Great Idea. This night I thought, maybe make enough cubes, make a few
statements which scenes are a MUST, and then have still enough room for
Users to volunteer to make one room. E.g. one room for Gilles, I'd like to
have one on a poster, etc. Votes if the room is acceptable should be made to
avoid scenes which don't fit to the overall Poster (atlhough some
Beginner-Images should be in there as well, for example). No limitations on
rendering times, but since everyone has to post his section at some point, I
think everyone will avoid too long rendering times anyways. Any takers?
Tim Nikias v2.0
"fitchn" <nomail@nomail> schrieb im Newsbeitrag
news:web.3f8f3b8d92b544a7e36ee7270@news.povray.org...
That
> specific
Date: 17 Oct 2003 05:23:14
Message: <3f8fb502@news.povray.org>
"fitchn" <nomail@nomail> wrote in message
That
> specific
And why stop at a still image? Animate!  :-)  Could then be hundreds of
office cubicles viewed from above and little POV-Ray Tracer work stations
where the creations are being made. Okay, maybe that's a bit too carried
away. If you have time take a look at
http://www.techtv.com/freshgear/pipeline/story/0,23008,3359171,00.html about
office cubicles, the video there is both interesting and weird.
BTW, the "collection" is already looking very good.
Bob H.
