POV-Ray : Newsgroups : povray.binaries.images : warp function test images (76k and 28k) Server Time
16 Jul 2026 01:19:51 EDT (-0400)
  warp function test images (76k and 28k) (Message 21 to 26 of 26)
Subject: Re: warp function test images (76k and 28k)
Date: 16 Oct 2003 13:28:51
Message: <5mktovkn5eq4udoebmu00ejhgt8da48eun@4ax.com>
On Thu, 16 Oct 2003 13:58:04 -0300, "Roberto A." <wol### [at] hot-mailcom>
wrote:
> > Sorry, this will never happen, simply because it is not possible (at
> > least not without an approximative root solver like in the isosurface
> > shape).
> That's sad. I stand corrected then.
No. You were wrong. POV _can_ do exactly the same what other packages - see
family of HF macros in shapes.inc where You can displace grid of triangles
using delivered function (kind of shader). You can do it on-the fly (like in
other packages) or write it to precalculated file. You have sources of it so
you can adjust it to your needs. You can even write macros to perform kind of
CSG with it.
And yes, POV can't do displacement on every primitive but afaik none other
package can do it as it was said in this thread.
ABX
Date: 16 Oct 2003 14:48:13
Message: <3f8ee7ed@news.povray.org>
ABX wrote:
> On Wed, 15 Oct 2003 18:56:23 +0100, David Burnett <var### [at] ntlworldcom> wrote:
>>I mean displacement in the renderman displacement shader sense which
>>is what Roberto was asking about, hence in this case 'true
>>displacement'. A function (in this case a shader)
>>applied to an object, sphere, mesh, plane etc which change its
>>geometry.
> Is that displacement on object/sphere/plane/mesh or is is only on meshes (if
> you know what I mean in my question)?
Displacement shaders can be applied to any sphere, however as RMAN,
BMRT etc always convert objects to micropolygons
(effectively sub 1 pixel in size depending on settings ) for shading
you could and probably should say its done on meshes.
Dave
Date: 16 Oct 2003 14:58:04
Message: <3f8eea3c$1@news.povray.org>
Christoph Hormann wrote:
  No, you don't have to modify the function as ABX already pointed out:
> #declare fn_Shape = function { ... }
> #declare fn_Iso = IC_Displace (fn_Shape)
> isosurface {
>   function { fn_Iso(x,y,z) }
And this our point of contention. I say
the isosurface here is the result of fn_Iso,
and not a displacement of fn_Shape and you
disagree.
Dave
Date: 16 Oct 2003 16:13:14
Message: <3f8efbd9@news.povray.org>
>> isosurface {
> disagree.
What if POV syntax were:
isosurface {
  function { fn_Shape(x,y,z) }
  displaced_by { IC_Displace }
... and it were internally translated to IC_Displace(fn_Shape) ?
Would it be different?
light_source{9+9*x,1}camera{orthographic look_at(1-y)/4angle 30location
9/4-z*4}light_source{-9*z,1}union{box{.9-z.1+x clipped_by{plane{2+y-4*x
0}}}box{z-y-.1.1+z}box{-.1.1+x}box{.1z-.1}pigment{rgb<.8.2,1>}}//Jellby
Date: 17 Oct 2003 14:27:04
Message: <3f903478$1@news.povray.org>
>>>isosurface {
>>disagree.
> isosurface {
> .... and it were internally translated to IC_Displace(fn_Shape) ?
Not really, syntactically it looks good but internally it would have to
work something like...
if shape(<x,y,z>) = threshold then
    <a,b,c> = ic_displace(<x,y,z>)
    value_for_point(<a,b,c>) = threshold
end if
Dave
Date: 25 Oct 2003 23:33:01
Message: <cjameshuff-1BC18C.23305925102003@netplex.aussie.org>
In article <3f903478$1@news.povray.org>,
I do not see how the internal implementation can matter. The only thing
of importance is the results.
I especially don't see how a mesh approximation of an object with the
vertices shifted around with the displacement function can be any more
"real" of a displacement than solving for a displaced version of the
actual shape.
http://tag.povray.org/
