POV-Ray : Newsgroups : povray.binaries.images : warp function test images (76k and 28k) Server Time
12 May 2026 22:54:29 EDT (-0400)
  warp function test images (76k and 28k) (Message 17 to 26 of 26)
Subject: Re: warp function test images (76k and 28k)
Date: 16 Oct 2003 10:12:43
Message: <3f8ea75b@news.povray.org>
> > I mean displacement in the renderman displacement shader sense which
> > is what Roberto was asking about, hence in this case 'true
> > displacement'.
> Renderman (at least the PRMan implementation) is not a raytracer.
There are Renderman compliant renderers with raytracing support that do true
displacement without problems (BMRT being one of them, and Pixie a more
current example). Of course, true displacement is best used with Reyes
renderers, since you have almost infinite precision with that particular
algorythm.
> No, it's simply wrong.  Isosurfaces are just a more general feature than
> a displacement shader.  Displacement there is limited to mesh
> geomentries since - as mentioned above - it has to work for a scanline
> renderer.  You can model a shape as an isosurface function and then
> displace it - just like with a shader.  The only difference is that with
> isosurfaces you can also do much more.
Displacement can be applied to any primitive that takes shaders on a
Renderman compliant renderer. The original object retains the same
geometry - it's only displaced by the shader when rendering. However, with
isosurfaces, you have to modify the original function, thus the original
object is modified before parsing or rendering. As David said, picky, but
true.
Both approaches have their weak and strong points. However, that doesn't
change the fact that I'd like to apply displacement on pure primitives on
POV, or even meshes without any workarounds. And I can't do that.
At least not for now (hint, hint). ;-)
Best regards,
Roberto
Date: 16 Oct 2003 10:31:14
Message: <tjatovgt46n2qavdlsbm24frt8rhjdb979@4ax.com>
On Thu, 16 Oct 2003 11:05:35 -0300, "Roberto A." <wol### [at] hot-mailcom>
wrote:
> > Is that displacement on object/sphere/plane/mesh or is is only on meshes (if
> > you know what I mean in my question)?
> Displacement on Renderman can be applied to any primitive that takes
> shaders, with the exception of points and curves. That means meshes,
> subsurface subdivision meshes, spheres, cones, etc.
From what I understand from
https://renderman.pixar.com/products/rispec/rispec_3_1/section12.html#Displacement.shaders
https://renderman.pixar.com/products/rispec/rispec_3_1/section4.html#RiDisplacement
https://renderman.pixar.com/products/rispec/rispec_3_1/section5.html#Quadrics
it doesn't mean that 'applied' = realized without conversion to mesh
ABX
Date: 16 Oct 2003 12:22:02
Message: <10t261-rfj.ln1@triton.imagico.de>
> algorythm.
There is no raytracer that can apply displacement to an analytically
solved shape.  That's not too bad of course because all non-raytracers
can't even render those shapes.  At the risk of repeating myself -
isosurfaces are as close to 'true displacement' as you can get.
This is simply wrong (see above).  What the renderer you have in mind
probably does is to approximate the shape with a mesh and displace that
- this is of course much less a 'true displacement' than an isosurface.
> However, with
> true.
No, you don't have to modify the function as ABX already pointed out:
#declare fn_Shape = function { ... }
#declare fn_Iso = IC_Displace (fn_Shape)
isosurface {
   function { fn_Iso(x,y,z) }
> POV,
Sorry, this will never happen, simply because it is not possible (at
least not without an approximative root solver like in the isosurface
shape).
Last updated 2 Sep. 2003 _____./\/^>_*_<^\/\.______
Date: 16 Oct 2003 12:58:05
Message: <3f8ece1d$1@news.povray.org>
Got it.
That's what it does internally, yes, but the effect has a 1-pixel
resolution, and thus is as close as defining a perfect displaced geometry as
possible. That's what I meant. I may be wrong, though.
> isosurface {
I was not aware of this possibility. My bad.
> shape).
That's sad. I stand corrected then.
Roberto
Date: 16 Oct 2003 13:28:51
Message: <5mktovkn5eq4udoebmu00ejhgt8da48eun@4ax.com>
On Thu, 16 Oct 2003 13:58:04 -0300, "Roberto A." <wol### [at] hot-mailcom>
> > shape).
No. You were wrong. POV _can_ do exactly the same what other packages - see
family of HF macros in shapes.inc where You can displace grid of triangles
using delivered function (kind of shader). You can do it on-the fly (like in
other packages) or write it to precalculated file. You have sources of it so
you can adjust it to your needs. You can even write macros to perform kind of
CSG with it.
And yes, POV can't do displacement on every primitive but afaik none other
package can do it as it was said in this thread.
ABX
Date: 16 Oct 2003 14:48:13
Message: <3f8ee7ed@news.povray.org>
ABX wrote:
> On Wed, 15 Oct 2003 18:56:23 +0100, David Burnett <var### [at] ntlworldcom> wrote:
>>displacement'. A function (in this case a shader)
>>applied to an object, sphere, mesh, plane etc which change its
>>geometry.
Displacement shaders can be applied to any sphere, however as RMAN,
BMRT etc always convert objects to micropolygons
(effectively sub 1 pixel in size depending on settings ) for shading
you could and probably should say its done on meshes.
Dave
Date: 16 Oct 2003 14:58:04
Message: <3f8eea3c$1@news.povray.org>
> isosurface {
And this our point of contention. I say
the isosurface here is the result of fn_Iso,
and not a displacement of fn_Shape and you
disagree.
Dave
Date: 16 Oct 2003 16:13:14
Message: <3f8efbd9@news.povray.org>
>> isosurface {
> disagree.
What if POV syntax were:
isosurface {
  function { fn_Shape(x,y,z) }
  displaced_by { IC_Displace }
... and it were internally translated to IC_Displace(fn_Shape) ?
Would it be different?
light_source{9+9*x,1}camera{orthographic look_at(1-y)/4angle 30location
9/4-z*4}light_source{-9*z,1}union{box{.9-z.1+x clipped_by{plane{2+y-4*x
0}}}box{z-y-.1.1+z}box{-.1.1+x}box{.1z-.1}pigment{rgb<.8.2,1>}}//Jellby
Date: 17 Oct 2003 14:27:04
Message: <3f903478$1@news.povray.org>
>>>isosurface {
>>disagree.
> isosurface {
> .... and it were internally translated to IC_Displace(fn_Shape) ?
Not really, syntactically it looks good but internally it would have to
work something like...
if shape(<x,y,z>) = threshold then
    <a,b,c> = ic_displace(<x,y,z>)
    value_for_point(<a,b,c>) = threshold
end if
Dave
Date: 25 Oct 2003 23:33:01
Message: <cjameshuff-1BC18C.23305925102003@netplex.aussie.org>
In article <3f903478$1@news.povray.org>,
I do not see how the internal implementation can matter. The only thing
of importance is the results.
I especially don't see how a mesh approximation of an object with the
vertices shifted around with the displacement function can be any more
"real" of a displacement than solving for a displaced version of the
actual shape.
http://tag.povray.org/
