POV-Ray : Newsgroups : povray.binaries.images : warp function test images (76k and 28k) Server Time
15 Jul 2026 23:44:26 EDT (-0400)
  warp function test images (76k and 28k) (Message 11 to 20 of 26)
<<< Previous 10 Messages Goto Latest 10 Messages Next 6 Messages >>>
Subject: Re: warp function test images (76k and 28k)
Date: 14 Oct 2003 13:58:25
Message: <3f8c3941@news.povray.org>
Christopher James Huff wrote:
> In article <3f8af3ec$1@news.povray.org>,
>  David Burnett <var### [at] ntlworldcom> wrote:
>>It's an isosurface using the noise subtracted, from f_r(),
>>which is as close to displacement that POV gets.
> I'd say true displacement is as close to true displacement as POV gets...
> Warping a function also qualifies as true displacement...
Hmmmm, I'm personally not sure *I'd* count anything done in a
isofunction true displacement (you're just changing the function
or the function input so for me its still the 'original' shape)
but do I see what you're getting at.
Dave
Date: 14 Oct 2003 15:14:02
Message: <k9st51-i02.ln1@triton.imagico.de>
And i am not sure whether you can clearly define what you understand as
'true displacement'.  As Chris Huff said you can't really get much
closer to true displacement than with isosurfaces.
Last updated 2 Sep. 2003 _____./\/^>_*_<^\/\.______
Date: 15 Oct 2003 13:59:08
Message: <3f8d8aec@news.povray.org>
I mean displacement in the renderman displacement shader sense which
is what Roberto was asking about, hence in this case 'true
displacement'. A function (in this case a shader)
applied to an object, sphere, mesh, plane etc which change its
geometry.
As I stated IMHO isosurfaces are not displacement as there is no
original object expect the one created by the function. It doesn't
matter what you do within that function what you get is still the
'original' object not a displaced one.
Picky, oh yes.
Dave.
Date: 15 Oct 2003 14:19:03
Message: <vd3rovceub43tpufk8pn31vshh537vpls4@4ax.com>
On Wed, 15 Oct 2003 18:56:23 +0100, David Burnett <var### [at] ntlworldcom> wrote:
> geometry.
Is that displacement on object/sphere/plane/mesh or is is only on meshes (if
you know what I mean in my question)?
Thinking that way displacement of mesh surface is only new mesh (even if it is
calculated on the fly). You can work with displacement on
functions/isosurfaces were efficient way if you have tools like:
http://www-public.tu-bs.de/~y0013390/pov/ic/docu02.html#Displace
ABX
Date: 15 Oct 2003 17:22:02
Message: <18q061-5lk.ln1@triton.imagico.de>
> displacement'.
Renderman (at least the PRMan implementation) is not a raytracer.
> geometry.
> Picky, oh yes.
No, it's simply wrong.  Isosurfaces are just a more general feature than
a displacement shader.  Displacement there is limited to mesh
geomentries since - as mentioned above - it has to work for a scanline
renderer.  You can model a shape as an isosurface function and then
displace it - just like with a shader.  The only difference is that with
isosurfaces you can also do much more.
Date: 16 Oct 2003 10:05:38
Message: <3f8ea5b2@news.povray.org>
> > geometry.
(if
Displacement on Renderman can be applied to any primitive that takes
shaders, with the exception of points and curves. That means meshes,
subsurface subdivision meshes, spheres, cones, etc.
Roberto
Date: 16 Oct 2003 10:12:43
Message: <3f8ea75b@news.povray.org>
> > displacement'.
There are Renderman compliant renderers with raytracing support that do true
displacement without problems (BMRT being one of them, and Pixie a more
current example). Of course, true displacement is best used with Reyes
renderers, since you have almost infinite precision with that particular
algorythm.
Displacement can be applied to any primitive that takes shaders on a
Renderman compliant renderer. The original object retains the same
geometry - it's only displaced by the shader when rendering. However, with
isosurfaces, you have to modify the original function, thus the original
object is modified before parsing or rendering. As David said, picky, but
true.
Both approaches have their weak and strong points. However, that doesn't
change the fact that I'd like to apply displacement on pure primitives on
POV, or even meshes without any workarounds. And I can't do that.
At least not for now (hint, hint). ;-)
Best regards,
Roberto
Date: 16 Oct 2003 10:31:14
Message: <tjatovgt46n2qavdlsbm24frt8rhjdb979@4ax.com>
On Thu, 16 Oct 2003 11:05:35 -0300, "Roberto A." <wol### [at] hot-mailcom>
From what I understand from
https://renderman.pixar.com/products/rispec/rispec_3_1/section12.html#Displacement.shaders
https://renderman.pixar.com/products/rispec/rispec_3_1/section4.html#RiDisplacement
https://renderman.pixar.com/products/rispec/rispec_3_1/section5.html#Quadrics
it doesn't mean that 'applied' = realized without conversion to mesh
ABX
Date: 16 Oct 2003 12:22:02
Message: <10t261-rfj.ln1@triton.imagico.de>
> algorythm.
There is no raytracer that can apply displacement to an analytically
solved shape.  That's not too bad of course because all non-raytracers
can't even render those shapes.  At the risk of repeating myself -
isosurfaces are as close to 'true displacement' as you can get.
This is simply wrong (see above).  What the renderer you have in mind
probably does is to approximate the shape with a mesh and displace that
- this is of course much less a 'true displacement' than an isosurface.
> However, with
> true.
No, you don't have to modify the function as ABX already pointed out:
#declare fn_Shape = function { ... }
#declare fn_Iso = IC_Displace (fn_Shape)
isosurface {
   function { fn_Iso(x,y,z) }
> POV,
Sorry, this will never happen, simply because it is not possible (at
least not without an approximative root solver like in the isosurface
shape).
Date: 16 Oct 2003 12:58:05
Message: <3f8ece1d$1@news.povray.org>
Got it.
That's what it does internally, yes, but the effect has a 1-pixel
resolution, and thus is as close as defining a perfect displaced geometry as
possible. That's what I meant. I may be wrong, though.
> isosurface {
I was not aware of this possibility. My bad.
> shape).
That's sad. I stand corrected then.
Roberto
